Alexa Error
Fri May 11, 2018 12:18 pm
ckeyes888 offline
Alexa Error
Just started getting these errors today.
.0.20"
   Stopping plugin "Alexa-Hue Bridge 3.0.20" (pid 24761)
   Alexa-Hue Bridge                Alexa-Hue Bridge shutdown requested
   Stopped plugin "Alexa-Hue Bridge 3.0.20"
   Starting plugin "Alexa-Hue Bridge 3.0.20" (pid 25112)
   Alexa-Hue Bridge                Alexa-Hue Bridge initialising . . .
   Alexa-Hue Bridge                Plugin Host IP Address is discovered as: '192.168.1.80'
   Alexa-Hue Bridge                Alexa discovery request logging disabled
   Alexa-Hue Bridge                No debugging requested
   Started plugin "Alexa-Hue Bridge 3.0.20"
   Alexa-Hue Bridge                Alexa-Hue Bridge initialization complete
   Alexa-Hue Bridge                Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
   Alexa-Hue Bridge                Alexa-Hue Bridge network access check to www.google.com successfully completed.
   Alexa-Hue Bridge                Alexa-Hue Bridge checking for Plugin update
   Alexa-Hue Bridge                Checking for updates...
   Alexa-Hue Bridge Error          Error in plugin execution runConcurrentThread:
  File "plugin.py", line 350, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 955, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 989, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 951, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 811, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 773, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1158, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 372, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 134, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 296, in do_handshake
SSLError: [Errno 1] _ssl.c:503: error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
   Alexa-Hue Bridge Error          plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
May 11, 2018 12:12:36 PM
Any idea what may be happening?
Also tried downloading an update but the page won't load.
Carl
Sat May 12, 2018 2:21 am
Re: Alexa Error
The latest version (3.0.29) in the plugin store fixes this error: Alexa-Hue Bridge :)
Sat May 12, 2018 9:11 am
ckeyes888 offline
Re: Alexa Error
Thanks. I was able to get the update downloaded and it’s working fine.
Awesome plugin!
Carl
