Can Alexa dim 2 different lights in a Action Group
Mon Sep 25, 2017 2:07 pm
siclark offline
The spotlights in my kitchen are on 2 circuits, and I have a qubino dimmer on each. I can get Alexa to turn both on together as I have setup an Action Group for the lights, one for on and one for off. I have created one for the Dim command, but how do I put the Dim variable that is updated by Alexa into the Set Brightness control for each light?
Or is this something I will finally have to look at Python for?
Mon Sep 25, 2017 2:26 pm
Re: Can Alexa dim 2 different lights in a Action Group
Use the Match Brightness action on a trigger that fires whenever the light that's controlled by the Alexa changes.
Mon Sep 25, 2017 3:08 pm
siclark offline
Thanks, I had thought about that but there will be times when I want one off and the other dimmed for example. Can I set brightness to equal a variable in script?
Mon Sep 25, 2017 4:01 pm
Yes:
brightness = int(indigo.variables[VARIDHERE].value)  # ID of the variable that has the brightness
indigo.dimmer.setBrightness(DIMMERIDHERE, value=brightness)
repeat the second line for each dimmer by inserting the correct ID. If you enter something that's not an integer in the variable value, you'll get an error like:
   Trigger                         Set brightness to var value
   Script Error                    embedded script: invalid literal for int() with base 10: 'asdfs'
     embedded script, line 1, at top level
ValueError: invalid literal for int() with base 10: 'asdfs'
And, in the spirit of learning more about Python scripts: you can add some error checking to your script to make errors more clear:
my_var = indigo.variables[1237552327]
    brightness = int(my_var.value)
    indigo.dimmer.setBrightness(1367948060, value=brightness)
except:
    indigo.server.log("Variable '{}' does not contain a valid integer ({})".format(my_var.name, my_var.value), isError=True, type="Set Brightness Trigger")
Which will result in this in the Event Log when there's a non-integer value in the variable:
   Set Brightness Trigger Error    Variable 'brightness' does not contain a valid integer (al;ksjdflasdkjf)
