error ascii
Sun Sep 03, 2017 4:40 am
lpraml offline
error ascii
hi,
first: GREAT plugin!
but...
I have a problem..
log says
Alexa-Hue Bridge Error StandardError detected in retrievePublishedDevices for 'Alexa Bridge one'. Line '685' has error=''ascii' codec can't encode character u'\xfc' in position 1: ordinal not in range(128)'
and I think it then stops converting the v2 to v3 process... because they never get converted.
any help - or did I do something wrong?
thx
lukas
Sun Sep 03, 2017 6:29 am
Re: error ascii
I will take a look at it. :)
I presume you have some special characters is some of your device names?
What version of the plugin are you running?
I need to know so I can inspect the relevant version's code.
Sun Sep 03, 2017 6:56 am
lpraml offline
Re: error ascii
hi,
I am on 3.0.7 - yes, special characters from German: e.g. ü, ä, ö
regards,
l
Sun Sep 03, 2017 7:18 am
Re: error ascii
Hi Lukas,
I have just uploaded a pre-release version to Github ( Version 3.0.8 ) ; https://github.com/IndigoDomotics/alexa-hue-bridge/releases/tag/3.0.8
Can you try it and see if it now works for you? :)
Sun Sep 03, 2017 8:57 am
lpraml offline
Re: error ascii
hi,
installed it - does not work yet ;-)
log:
3 Sep 2017, 16:56:08
Alexa-Hue Bridge Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 929, in alexaDevicesListGlobal
UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 1: ordinal not in range(128)
File "plugin.py", line 1084, in alexaDevicesListLocal
3 Sep 2017, 16:56:29
Alexa-Hue Bridge Error Error in plugin execution UiValidate:
File "plugin.py", line 780, in validateDeviceConfigUi
ValueError: need more than 1 value to unpack
regards,
l
Sun Sep 03, 2017 9:38 am
Re: error ascii
Thanks for testing. :)
The good news is that I think it has got through the conversion. It is now failing when trying to display the converted data.
I can reproduce this error this by trying to add a device with these umlaut characters.
I will work on a fix. :)
Sun Sep 03, 2017 11:00 am
Re: error ascii
Hi Lukas,
I have just uploaded another pre-release version to Github ( Version 3.0.9 ) ; https://github.com/IndigoDomotics/alexa-hue-bridge/releases/tag/3.0.9
Can you try this new version and see if it now works for you? :)
Sun Sep 03, 2017 11:07 am
lpraml offline
Re: error ascii
it works fine!
great response-times ;-) thank you!
regards,
lukas
Sun Sep 03, 2017 11:09 am
Re: error ascii
Hi Lukas,
Thanks for letting me know - I will now make this the official release. :)
