Key ID not found in database
PostPosted: Wed Aug 30, 2017 9:29 am
by polycron
I just ran into an issue with the new 3.05 version. I had an insteon switch go bad and it had to be replaced. I tossed a zwave switch in its place. The original switch was setup in the Alexa-Hue-Bridge and now when I go in to edit the devices, no items are found in the Published Alexa Devices list. Additionally, I get the following error in my logs:
   Alexa-Hue Bridge Error          Error in plugin execution GetUiDynamicList:
  File "plugin.py", line 1373, in publishedAlexaDevicesList
KeyError: key id 407388196 not found in database
I'm assuming that the 407388196 is my old switch but I can not confirm that. Is there a way I can remove that from the bridge database? Or is it possible to trap for that error and automatically clean up the database for missing items?
Jeff
Re: Key ID not found in database
PostPosted: Wed Aug 30, 2017 10:57 am
by autolog
polycron wrote:
... Is there a way I can remove that from the bridge database? Or is it possible to trap for that error and automatically clean up the database for missing items?
Answers: No, Yes and Yes :D
The plugin should obviously handle this situation (the same probably goes for deleted Actions). :oops:
I'll work on a fix - might take 24 hours. :)
PostPosted: Thu Aug 31, 2017 1:17 pm
by autolog
I have uploaded an interim version that hopefully will resolve the problem: 3.0.6 Release - Requires Indigo 7
V 3.0.6 is marked as Pre-release so won't show up under the normal update checks.
Let me know if this resolves the issue?
I still have a bit more tidying up to do and I will be doing that in 3.0.7. :)
PostPosted: Fri Sep 01, 2017 5:19 am
by autolog
Version 3.0.7 (see announcement) which completes the fix for this problem. :)
PostPosted: Fri Sep 01, 2017 10:06 am
by polycron
This worked perfectly on my system and resolved my issues.
Jeff
