"I'm not quite sure what went wrong".
Mon Jul 31, 2017 12:18 pm
macrhino offline
I posted this at the end of another topic but felt it would be more appropriate here.
I have been using the Hue Bridge to link to virtual devices with Amazon Echos. This has worked fine until yesterday. Now, whenever I issue a "turn on" or any command which requires interaction with the Hue Bridge plugin I get the error from Alexa:
The plugin is running and nothing appears in the Indigo log. When I issue the "Discover devices" command, the Indigo log shows the devices being discovered and they work in Indigo.
The echos also control other hubs in my home. Only this one part has failed but since this is my interface to Indigo, it is the bulk of my automation. the version of the plug in 2.0.11 and Indigo 7.0.3.
I would appreciate any assistance.
Mon Jul 31, 2017 1:29 pm
autolog offline
Re: "I'm not quite sure what went wrong".
Have you changed anything in your network setup / added new devices at the point it started going wrong?
As jay suggested in reply to your original (now duplicated post), have you restarted your Echo Dots. It might also be worthwhile restarting your Apple Mac as well.
I haven't heard of or experienced this issue. :?
You can turn on all the debug logging and attach the log output to a reply in this thread for us to have a look at. Suggest you reload the plugin and then try and get the error, then post the log.
See the first sticky thread on how to access the log. :)
Tue Aug 01, 2017 6:31 am
macrhino offline
I have restarted the Dots and Echos (4 of them). I did not add any devices or make any changes that I am aware of.
Here is the LOG
Aug 1, 2017, 8:20:26 AM
   Starting Indigo Server version 7.0.3 (Mac OS X 10.12.6)
   Loading attachments
   "device target attachment.scpt" script loaded
   "group target attachment.scpt" script loaded
   "growl attachment.scpt" script loaded
   "iTunes attachment.scpt" script loaded
   "scenes attachment.scpt" script loaded
   "time stamp attachment.scpt" script loaded
   Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/My House.indiDb"
   Loading plugin "Action Collection 2.0.4"
   Starting plugin "Action Collection 2.0.4" (pid 485)
   Loading interface "INSTEON Commands 2.0.10"
   Starting interface "INSTEON Commands 2.0.10" (pid 486)
   Loading interface "Z-Wave 2.0.68"
   Starting interface "Z-Wave 2.0.68" (pid 487)
   Loading plugin "Alexa-Hue Bridge 2.0.11"
   Starting plugin "Alexa-Hue Bridge 2.0.11" (pid 488)
   Loading plugin "Ecobee 1.0.0"
   Starting plugin "Ecobee 1.0.0" (pid 489)
   Loading plugin "Timers and Pesters 2.0.2"
   Starting plugin "Timers and Pesters 2.0.2" (pid 490)
   Loading interface "Virtual Devices 2.0.4"
   Starting interface "Virtual Devices 2.0.4" (pid 491)
   Found disabled plugin "Airfoil Pro 1.0.7"
   Found disabled plugin "Airfoil 1.1.14"
   Found disabled plugin "DIRECTV DVR Control 1.1.1"
   Found disabled plugin "EasyDAQ Relay Card 2.0.3"
   Found disabled plugin "Global Property Manager 2.0"
   Found disabled plugin "Growl 2.0.2"
   Found disabled plugin "iCal Alarm Processor 2.0.1"
   Found disabled plugin "iTunes 2.0.4"
   Found disabled plugin "NEST Home 2.0.25"
   Found disabled plugin "Nest Thermostat 1.0.3"
   Found disabled plugin "NOAA Weather 2.0.1"
   Found disabled plugin "SQL Logger 2.0.5"
   Found disabled plugin "Vera Bridge 1.0.10"
   Found disabled plugin "WeatherSnoop 2.1.2"
   Bonjour registered "Indigo - My House"
   Reflector                       starting reflector connection to https://myhome.indigodomo.net
   WebServer client connected
   WebServer                       started on port 8176 -- digest authentication enabled
   Started interface "Virtual Devices 2.0.4"
   Alexa-Hue Bridge                Alexa-Hue Bridge initialising . . .
   Alexa-Hue Bridge                Alexa discovery request logging enabled
   Alexa-Hue Bridge                No debugging requested
   Started plugin "Timers and Pesters 2.0.2"
   Started plugin "Alexa-Hue Bridge 2.0.11"
   Alexa-Hue Bridge                Alexa-Hue Bridge initialization complete
   Alexa-Hue Bridge                Hue Bridge 'Hue_Bridge' Host: 10.0.1.23
   Started plugin "Action Collection 2.0.4"
   Started interface "INSTEON Commands 2.0.10"
   Alexa-Hue Bridge                'Hue_Bridge' has 19 devices published
   Alexa-Hue Bridge                Starting Hue Bridge 'Hue_Bridge' web server thread
   Alexa-Hue Bridge                Starting Hue Bridge 'Hue_Bridge' discovery thread as 'Auto Start Discovery' requested
   Started interface "Z-Wave 2.0.68"
   Z-Wave                          connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 002 - Keypad Door Lock
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 005 - Relay Power Switch
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 010 - Basic Repeater Slave
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 011 - Relay Scene Switch
   Ecobee Error                    pyecobee: not authenticated to Ecobee servers
   Ecobee Error                    request status code: 500
   Ecobee Error                    Ecobee device requires authentication; open plugin configuration page for info
   Started plugin "Ecobee 1.0.0"
   Ecobee                          added remote sensor Y4DJ
   Ecobee                          added smart thermostat 311039562925
   Ecobee                          added remote sensor BD86
   Ecobee                          added smart thermostat 311062237623
   Ecobee                          added remote sensor Y3ZJ
   Ecobee                          added remote sensor BLPH
Aug 1, 2017, 8:20:40 AM
   Emails on POP server pop.gmail.com will be scanned every 1 minutes
Aug 1, 2017, 8:20:42 AM
   Connected to PowerLinc 2413U interface on port usbserial-A60335IH
   PowerLinc address 33.E1.B8, firmware version 9.14
   Indigo Cocoa client connected
(Start a discovery request here.)
Aug 1, 2017, 8:23:23 AM
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 1] ...
   Alexa-Hue Bridge                + Publishing device 'Bathroom Light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Bright Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Front Fence Light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Front hallway Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Garage Door' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Garage Overheads' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Greeting lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Kitchen Hallway Light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Mao mao light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Master Fifty Percent' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Office Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Pantry' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Reading Light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Sunroom Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'TV Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'Viewing Lights' to Alexa
   Alexa-Hue Bridge                + Publishing device 'West Side Light' to Alexa
   Alexa-Hue Bridge                + Publishing device 'master thirty percent' to Alexa
   Alexa-Hue Bridge                + Publishing device 'my bedtime lights' to Alexa
   Alexa-Hue Bridge                ... 19 devices discovered by Alexa on Alexa-Hue Bridge 'Hue_Bridge'.
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 2] ...
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 3] ...
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 4] ...
(ENABLE DEBUGGING LOGGING HERE)
Aug 1, 2017, 8:24:19 AM
   Alexa-Hue Bridge Warning        Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
(Request to turn off 'viewing lights' [seen above])
Error from Alexa. "I"m not sure what went wrong here"
(Start a discovery request AGAIN.)
Aug 1, 2017, 8:24:44 AM
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 5] ...
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 6] ...
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 7] ...
   Alexa-Hue Bridge                Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 8] ...
Tue Aug 01, 2017 6:34 am
macrhino offline
I will note that the calls to the Echobee plugin still function.
Tue Aug 01, 2017 6:37 am
autolog offline
You have posted the Indigo Event Log. What I need to see is the Alexa-Hue bridge plugin debug log. You will need to attach it as a file to a reply to this post.
Please look at this Sticky post on how to get at and retrieve the log I need: Alexa-Hue Bridge Debug Logs + Port 1900 Check
Once I can see that, I might be able to help. :)
Tue Aug 01, 2017 11:35 am
macrhino offline
Here is the log file plugin.log
Is this the pertinent one?
The system only allows 512 KB and no zip files. the file I have attached is a zip file with extension removed. Just add it back and decompress.
plugin.log
(168.4 KiB) Downloaded 77 times
Tue Aug 01, 2017 12:08 pm
autolog offline
That's the correct log. :)
On an initial inspection, it doesn't seem that the Turn On / Off commands are getting through to the plugin as I can't see any evidence in the log.
This maybe means that there is a problem at the Echo end or with the network.
I will dig into this a bit deeper but it may take a while to do this.
Have you tried "forgetting" all the Alexa devices using the iOS Alexa App and then doing a rediscovery to see if this helps?
Sorry I can't be more positive at this stage. :|
Tue Aug 01, 2017 12:13 pm
macrhino offline
OK embarrassment.
It worked. I did a forget all and the Alexa started recognizing the commands.
Thanks a lot. I should have seen this myself.
Tue Aug 01, 2017 12:14 pm
autolog offline
No need to be embarrassed - I am glad it is now working for you. :D
Wed Aug 02, 2017 4:52 pm
Mayhem offline
I have this issue every few months and the only way I can get round it is to forget and re-learn the devices.
One day they are fine and the next nothing.
When I ask the Echo's to do something the Mac responds from Indigo confirming that it has done what Alexa has asked. (sad I know)
When this issue manifests itself there is no feed back from the Mac so I'm assuming the commands are not getting past the plugin or not to the plugin.
Looking at the debug logs for the plugin shows no activity.
Just an observation.
Cheers
