I have restarted the Dots and Echos (4 of them). I did not add any devices or make any changes that I am aware of.
Here is the LOG
Aug 1, 2017, 8:20:26 AM
Starting Indigo Server version 7.0.3 (Mac OS X 10.12.6)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/My House.indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 485)
Loading interface "INSTEON Commands 2.0.10"
Starting interface "INSTEON Commands 2.0.10" (pid 486)
Loading interface "Z-Wave 2.0.68"
Starting interface "Z-Wave 2.0.68" (pid 487)
Loading plugin "Alexa-Hue Bridge 2.0.11"
Starting plugin "Alexa-Hue Bridge 2.0.11" (pid 488)
Loading plugin "Ecobee 1.0.0"
Starting plugin "Ecobee 1.0.0" (pid 489)
Loading plugin "Timers and Pesters 2.0.2"
Starting plugin "Timers and Pesters 2.0.2" (pid 490)
Loading interface "Virtual Devices 2.0.4"
Starting interface "Virtual Devices 2.0.4" (pid 491)
Found disabled plugin "Airfoil Pro 1.0.7"
Found disabled plugin "Airfoil 1.1.14"
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.2"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NEST Home 2.0.25"
Found disabled plugin "Nest Thermostat 1.0.3"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.0.5"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "WeatherSnoop 2.1.2"
Bonjour registered "Indigo - My House"
Reflector starting reflector connection to
https://myhome.indigodomo.net WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Started interface "Virtual Devices 2.0.4"
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge No debugging requested
Started plugin "Timers and Pesters 2.0.2"
Started plugin "Alexa-Hue Bridge 2.0.11"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge Hue Bridge 'Hue_Bridge' Host: 10.0.1.23
Started plugin "Action Collection 2.0.4"
Started interface "INSTEON Commands 2.0.10"
Alexa-Hue Bridge 'Hue_Bridge' has 19 devices published
Alexa-Hue Bridge Starting Hue Bridge 'Hue_Bridge' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Hue_Bridge' discovery thread as 'Auto Start Discovery' requested
Started interface "Z-Wave 2.0.68"
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave found module included in controller with no matching device (missing or disabled): 002 - Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 005 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 010 - Basic Repeater Slave
Z-Wave found module included in controller with no matching device (missing or disabled): 011 - Relay Scene Switch
Ecobee Error pyecobee: not authenticated to Ecobee servers
Ecobee Error request status code: 500
Ecobee Error Ecobee device requires authentication; open plugin configuration page for info
Started plugin "Ecobee 1.0.0"
Ecobee added remote sensor Y4DJ
Ecobee added smart thermostat 311039562925
Ecobee added remote sensor BD86
Ecobee added smart thermostat 311062237623
Ecobee added remote sensor Y3ZJ
Ecobee added remote sensor BLPH
Aug 1, 2017, 8:20:40 AM
Emails on POP server pop.gmail.com will be scanned every 1 minutes
Aug 1, 2017, 8:20:42 AM
Connected to PowerLinc 2413U interface on port usbserial-A60335IH
PowerLinc address 33.E1.B8, firmware version 9.14
Indigo Cocoa client connected
(Start a discovery request here.)Aug 1, 2017, 8:23:23 AM
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 1] ...
Alexa-Hue Bridge + Publishing device 'Bathroom Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Bright Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Front Fence Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Front hallway Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Garage Door' to Alexa
Alexa-Hue Bridge + Publishing device 'Garage Overheads' to Alexa
Alexa-Hue Bridge + Publishing device 'Greeting lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Kitchen Hallway Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Mao mao light' to Alexa
Alexa-Hue Bridge + Publishing device 'Master Fifty Percent' to Alexa
Alexa-Hue Bridge + Publishing device 'Office Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Pantry' to Alexa
Alexa-Hue Bridge + Publishing device 'Reading Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Sunroom Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'TV Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Viewing Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'West Side Light' to Alexa
Alexa-Hue Bridge + Publishing device 'master thirty percent' to Alexa
Alexa-Hue Bridge + Publishing device 'my bedtime lights' to Alexa
Alexa-Hue Bridge ... 19 devices discovered by Alexa on Alexa-Hue Bridge 'Hue_Bridge'.
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 2] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 3] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 4] ...
(ENABLE DEBUGGING LOGGING HERE)Aug 1, 2017, 8:24:19 AM
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
(Request to turn off 'viewing lights' [seen above])Error from Alexa. "I"m not sure what went wrong here"(Start a discovery request AGAIN.)Aug 1, 2017, 8:24:44 AM
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 5] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 6] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 7] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'Hue_Bridge' responding to Alexa discovery [request id: 8] ...
