Plugin stopped working after upgrade
Mon Feb 27, 2017 12:44 am
mediabox offline
from 1.0.3 to 2.0.11.
After attempting to restore it by: resetting the Echo, rebooted the Mini, Re-installed Indigo 7.0.3, and wiping out all the devices in the Alexa app, "Discover devices" command always yields: "I couldn't find any more smart home devices"
I have the plugin enabled but lsof shows:
sh-3.2# lsof -i :1900
sh-3.2#
My logs show:
Feb 27, 2017, 12:05:14 AM
   Alexa-Hue Bridge                Alexa-Hue Bridge initialising . . .
   Started plugin "Scale Adapters 0.1.0"
   Started interface "Virtual Devices 2.0.4"
   Started plugin "Action Collection 2.0.4"
   Started plugin "Timers and Pesters 2.0.2"
   Started plugin "NOAA Weather 2.0.1"
   Started plugin "iTunes 2.0.4"
   Bonjour unregistered previous server name
   Bonjour registered "Indigo - My House"
   Alexa-Hue Bridge                Alexa discovery request logging enabled
   Alexa-Hue Bridge Warning        Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
   Started plugin "Alexa-Hue Bridge 2.0.11"
   Alexa-Hue Bridge                Alexa-Hue Bridge initialization complete
   Started interface "Z-Wave 2.0.68"
   Z-Wave                          connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
   Z-Wave Error                    device "Outside Gazebo Lights" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 054 - Binary Sensor (routing)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 057 - Multilevel Sensor (routing)
   Emails on POP server mail.comcast.net will be scanned every 1 minutes
Feb 27, 2017, 12:05:17 AM
   Trigger                         Startup1
   Action Group                    startup
   Action Group                    email, bootup notification
   Action Group                    safari close tabs
<snip, restaring plugin here>
Feb 27, 2017, 12:14:57 AM
   Reloading plugin "Alexa-Hue Bridge 2.0.11"
   Stopping plugin "Alexa-Hue Bridge 2.0.11" (pid 6558)
   Stopped plugin "Alexa-Hue Bridge 2.0.11"
   Starting plugin "Alexa-Hue Bridge 2.0.11" (pid 6580)
   Schedule                        Housekeep minutely
   Action Group                    update vars (landscape, deck status)
   Action Group                    set local time
   Action Group                    set uptime var
   Schedule                        Housekeep minutely (light status only)
Feb 27, 2017, 12:15:21 AM
   Z-Wave                          received "031 - Kitchen - Motion" status update battery level 100%
2017-02-27 00:05:14.501   INFO           Plugin.general.__init__                  Alexa-Hue Bridge initialising . . .
2017-02-27 00:05:14.756   INFO           Plugin.general.closedPrefsConfigUi       Alexa discovery request logging enabled
2017-02-27 00:05:14.756   WARNING        Plugin.general.setDebuggingLevels        Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
2017-02-27 00:05:14.767   THREADDEBUG    Plugin.method.startup                   CLASS: Plugin
2017-02-27 00:05:14.767   INFO           Plugin.general.startup                   Alexa-Hue Bridge initialization complete
2017-02-27 00:05:14.768   DEBUG          Plugin.server.run                       Discovery Logging thread initialised.
2017-02-27 00:13:27.278   THREADDEBUG    Plugin.method.shutdown                  CLASS: Plugin
2017-02-27 00:13:27.278   DEBUG          Plugin.general.shutdown                  shutdown called
2017-02-27 00:13:30.040   INFO           Plugin.general.__init__                  Alexa-Hue Bridge initialising . . .
2017-02-27 00:13:30.151   INFO           Plugin.general.closedPrefsConfigUi       Alexa discovery request logging enabled
2017-02-27 00:13:30.151   WARNING        Plugin.general.setDebuggingLevels        Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
2017-02-27 00:13:30.160   THREADDEBUG    Plugin.method.startup                   CLASS: Plugin
2017-02-27 00:13:30.160   INFO           Plugin.general.startup                   Alexa-Hue Bridge initialization complete
2017-02-27 00:13:30.161   DEBUG          Plugin.server.run                       Discovery Logging thread initialised.
2017-02-27 00:14:57.114   THREADDEBUG    Plugin.method.shutdown                  CLASS: Plugin
2017-02-27 00:14:57.114   DEBUG          Plugin.general.shutdown                  shutdown called
2017-02-27 00:14:59.937   INFO           Plugin.general.__init__                  Alexa-Hue Bridge initialising . . .
2017-02-27 00:15:00.036   INFO           Plugin.general.closedPrefsConfigUi       Alexa discovery request logging enabled
2017-02-27 00:15:00.036   WARNING        Plugin.general.setDebuggingLevels        Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
2017-02-27 00:15:00.043   THREADDEBUG    Plugin.method.startup                   CLASS: Plugin
2017-02-27 00:15:00.043   INFO           Plugin.general.startup                   Alexa-Hue Bridge initialization complete
2017-02-27 00:15:00.044   DEBUG          Plugin.server.run                       Discovery Logging thread initialised.
sh-3.2#
Also my drop down menu for the plugin is missing "manage", and maybe others? See attachment.
Any suggestions? Thanks.
Screen Shot 2017-02-27 at 12.31.30 AM.png (52.66 KiB) Viewed 467 times
Mon Feb 27, 2017 2:41 am
Re: Plugin stopped working after upgrade
Have you read the documentation for the new version :?:
The whole point of the new version is to enable you to define multiple emulated Hue Hubs as Indigo devices in order to overcome the 27 devices per hub Alexa limit.
The documentation has got a whole section on Configuring the Emulated Hue Bridge including the help it will give you in trying to migrate your version 1 definitions.
If you have done what the documentation says then post back and I will try to help you further. :)
Mon Feb 27, 2017 1:15 pm
mediabox offline
Hi Autolog,
I haven't reviewed the documentation. Will do that.
Tue Feb 28, 2017 10:46 am
mediabox offline
Reading the documentation helps. I have 2 Echo's and 1 Dot, and no issue. Actually works better than before, as my Dot previously could never find any devices. Another thing the older version did was Alexa would say "the device xxxx is not responding" for some of my (virtual) devices - I have my fingers crossed that issue is gone. Thank you!!
