special character problem
Fri Jan 20, 2017 2:49 pm
lpraml offline
hi,
I have devices with special German characters like "ü" in "Küche" (kitchen) - the "ü" is just missing in the alexa-device-name...
unfortunately these devices are then unspeakable in German and even if I try Alex does not recognise my pronunciation...
any chance this might geht fixed any time soon?
kind regards,
lukas
Fri Jan 20, 2017 3:10 pm
Re: special character problem
Hi Lukas,
I wasn't aware of the problem - I am now. :wink:
I will try and take a look at it over the weekend - it might be unicode related (not one of my strong points!). :)
Sun Jan 22, 2017 3:41 am
lpraml offline
hi jon,
to clarify - my devicename is "küche", in the published device list in the configure dialog it still says küche but in the echo-app it says "kche".
in general alexa works with special characters like that because I have a sonos play5 named "sonos küche" via the yonomi-skill linked to alexa and there it works fine...
thx - have a nice weekend!
l
Sun Jan 22, 2017 10:01 am
I have just uploaded version 2.0.10 which should now handle special characters.
I can see that Alexa now knows about a device called küche on my test system but I either can't pronounce the word correctly or Alexa doesn't understand me, so I can't test that it actually works when I ask Alexa to turn it on. :D
Maybe you could let me know if it works or not?
Thanks. :)
Mon Jan 23, 2017 3:28 am
yassi offline
Thanks Jon, good to know.
Don't have the Echo Dot yet - waiting for one from the UK - I'm on the invitation list here in Germany since the beginning, but it seems so it goes very slow.
When I get it, I will test it too.
BTW, it seems so, that the Umlauts are a common issue in the plugins.
But as far as you guys can fix it, it's perfect!
Thank you!
Yassi
Mon Jan 23, 2017 12:01 pm
lpraml offline
Thanks. :)
i will be home again tomorrow and tell you asap. thx!
l
Gesendet von iPhone mit Tapatalk
Fri Jan 27, 2017 4:56 am
lpraml offline
dear Jon,
"küche" now works perfect!
thx!
l
Fri Jan 27, 2017 5:21 am
Thanks for the feedback - glad to hear it is working :D
Fri Jan 27, 2017 5:34 am
yassi offline
Oh, that's good - I will use this when my Echo Dot will finally arrive on Monday (was waiting for 4 months now here in Germany).
Yassi
Mon Jan 30, 2017 2:03 pm
yassi offline
Hi Folks,
well, I've installed the plugin and it seems so I have also the "Umlauts" issue.
I wanted to name a device "Wandbeleuchtung Büro" and I've got the error below:
30.01.2017 20:55:15
   Alexa-Hue Bridge Error          Error in plugin execution UiAction:
  File "plugin.py", line 871, in addDevice
UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 221: ordinal not in range(128)
BTW: can I use the plugin with the German language (to control the Echo Dot)
Yassi
Mon Jan 30, 2017 6:17 pm
Hi Yassi,
Picked up your message as I was heading to bed, thought I would take a quick look and I found the error.
The previous solved Special Character problem was with the device name field, this one is with the Alternate name field.
I have just uploaded a new pre-release version (2.0.11) which should fix the problem. :)
Please try it out and let me know if it works. I'll check back tomorrow (actually later today as it is after midnight :wink: ) and see how you got on. :)
EDIT: I assume you can use the German language as long as the umlaut issue is resolved. :)
Tue Jan 31, 2017 12:14 am
yassi offline
Hi Jon!
Thank you very much!
I will try it and report back.
Seems so, I can use it so, was not able to discover devices via voice, had to do it via the App.
But the discovered device (with a German name) can be now controlled.
Yassi
Tue Jan 31, 2017 12:50 am
yassi offline
Jon, it's perfect!
Works.
Thank you very much for your quick fix!
Yassi
Tue Jan 31, 2017 1:39 am
Hi Yassi,
Thanks for the quick feedback - I will now make V2.0.11 an official release and announce it accordingly. :)
Tue Jan 31, 2017 1:43 am
yassi offline
Ok, Jon, thank you!
Yassi
