Alexa Only Discovering Some of My Devices
Wed Dec 14, 2016 5:08 pm
Colorado4Wheeler offline
I just got a dot to try it out - pretty cool so far and your plugin is very cool too! One problem, though, I have added 17 devices to my Alexa Hue Plugin and only 8 are picked up by the dot. I've "forgotten" the devices multiple times and it always picks up the same 8 of 17. What can I post that will be helpful in figuring out the problem?
Wed Dec 14, 2016 5:36 pm
Re: Alexa Only Discovering Some of My Devices
I'm actually not sure how that works anymore since autolog updated it to support bridge devices - I think he'll have to jump in here.
Thu Dec 15, 2016 8:13 am
OK - I am jumping in :D
I have just taken a quick look at the code and can't see anything obvious as to why some are found and not others :?
Are your devices all defined in one Hub?
Maybe the best way would be for me to take a look at some debugging logs.
If you could turn all debug logging on in the plugin config, stop and restart the plugin and then when it is all up and running, ask Alexa to run a discovery. Once she has completed the task, stop the plugin and then PM me the plugin.log file from the opensource.alexa-hue-bridge folder in the Indigo Logs folder.
I'l take a look at the log and see if I can spot anything. :)
Thu Dec 15, 2016 9:24 am
Well, it would seem that restarting the plugin resolved the problem. I had turned on debugging and did a discover and got the same 8, then reloaded the plugin and discovered again and it came up with all 17.
Thu Dec 15, 2016 10:07 am
I have noticed this from time-to-time but it isn't something I have been able to pin down (yet). Maybe it is something not being fully updated when the discovery devices are saved? :?
Did you by any chance add in the 8 devices that were found first and then do a subsequent add for the further 9?
Just trying to see if there is any logic behind what is happening - there usually is. :wink:
Thu Dec 15, 2016 10:25 am
I think the order that I added things were 1, then 4 then 17. The 1 and 4 worked fine.
Thu Dec 15, 2016 10:37 am
OK - obviously must be something else then. :?
Fri Dec 16, 2016 1:24 pm
It's a bug :oops:
The good news is that I have coded a change that seems too work, and the bad news is that I need to do a bit more testing which won't happen until tomorrow now. :)
The work-around is once you have configured your devices and saved them is to reload the plugin before asking Alexa to discover your devices.
So not a terminal error but annoying none the less. :|
Sun Dec 18, 2016 9:14 am
clawmd offline
Trying really hard to get this to work (Indigo 7.0.2, bridge 2.0.2)
I have added a device, saved and reloaded the Plugin. In devices I see the device, port 8178. At the bottom of the window under Device Details I see "Discovery: Off." When I ask Alexa to discover devices, I am asked "If you have Phillips Hue, press the button on the bridge." Discovery fails every time, including trying to do it from the app. Not sure what to do now.
Sun Dec 18, 2016 9:23 am
If discovery is 'off' then you won't get anything discovered by Alexa. :wink:
Turn on discovery by using Turn On button for the device in the Indigo devices window UI.
It might be necessary to reload the plugin once you have done this?
I have completed the change to the plugin to improve discovery. I am awaiting on some info from Matt / Jay as to how to update Github with the new release. :)
So hopefully it will be available for you to try out before too long. :)
Sun Dec 18, 2016 10:24 am
clawmd offline
Doesn't seem like anything I do changes the "On State Discovery:Off" situation
Sun Dec 18, 2016 11:17 am
OK - The new version should be available before too long (hopefully) so I think the best plan is to install that (when available) and we can take it from there. :)
Sun Dec 18, 2016 12:11 pm
Just released the new version (2.0.7) which is available on Github :)
Sun Dec 18, 2016 2:39 pm
clawmd offline
Tried with the update 2.0.7, no Luck
Reloading plugin "Alexa-Hue Bridge 2.0.7"
Stopping plugin "Alexa-Hue Bridge 2.0.7" (pid 15330)
Stopped plugin "Alexa-Hue Bridge 2.0.7"
Starting plugin "Alexa-Hue Bridge 2.0.7" (pid 15392)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder
Started plugin "Alexa-Hue Bridge 2.0.7"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Lights' has one device published
Alexa-Hue Bridge Starting Hue Bridge 'Lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge 'new device' has one device published
Alexa-Hue Bridge Starting Hue Bridge 'new device' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'new device' discovery thread as 'Auto Start Discovery' requested
I can't get any devices to be discovered, and nothing is listed in the log during the attempt to discover devices. Tried reloading, power cycling echo dot, Voice commands as well as through the app
Sun Dec 18, 2016 2:57 pm
This is going to sound like a dumb question, but the Alexa AND Indigo are on the same network, right? Alexa is WiFi so if it's still in setup mode then it's on it's OWN WiFi network until you configure it.
