Alexa control of Airfoil
Sun Dec 11, 2016 3:29 am
Benwin offline
Is it possible to add AirFoil speakers to the Alexa-Hue Bridge so we can turn them on and off and set the volume using the "Alexa set <Bedroom Speakers> to 75%" command?
Sun Dec 11, 2016 6:12 am
marketability offline
Re: Alexa control of Airfoil
I had some success trying that by creating a virtual on/off device with the relevant action groups
I had some issues with Indigo updating speaker status but the echo/alexa bit worked fine
Mon Dec 12, 2016 11:12 am
Speakers aren't dimmer devices, which is what Alexa is expecting when you say 75%. Virtual On/Off devices are just that - on/off (relay) so they don't support dimming either (though you should be able to connect/disconnect them using one). It would be possible, but only if there were a virtual dimmer device which could then map brightness onto volume. I don't recall there being a 3rd party plugin that could do something like that.
Mon Dec 12, 2016 12:42 pm
I could probably be convinced to add that to the Masquerade plugin. I guess I'd have to get Airfoil running for that to happen.
Mon Dec 12, 2016 1:01 pm
Virtual Dimmer devices are - tricky. Once you start thinking about the issues around them, it quickly gets a bit overwhelming. It's on our todo list for the Virtual Devices Interface but hasn't quite gotten enough demand.
Tue Dec 13, 2016 12:00 pm
This should enable you to control Airfoil Pro speaker volume from Alexa:
viewtopic.php?f=216&t=17402&p=130515#p130515
It does On/Off, but only by setting the volume to 0 or 100, which is probably not the right approach. I need to look into that a little more.
Thu Mar 23, 2017 1:06 pm
bkmar1192 offline
I am using the Meta Device plugin to control my AirFoil speakers. I have set them up as meta dimmer devices. I can turn them on/off and say "Alexa, set main speaker to 70%".
Works like a charm!
Sat Mar 25, 2017 1:22 am
bkmar1192 offline
Works like a charm!
BTW - Meta device can be found here: viewtopic.php?t=7980
And my speaker actions are:
Speaker Volume:
theVolume = int(indigo.devices[**ID of Meta Device**].states['brightnessLevel'])+1
airfoilPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.airfoilpro")
if airfoilPlugin.isEnabled():
        result = airfoilPlugin.executeAction('setVolume', deviceId=**ID of Airfoil Speaker**, props={'volume': theVolume}, waitUntilDone=True)
    except Exception, e:
        print "Exception occurred: %s" % unicode(e)
Speaker On:
indigo.dimmer.setBrightness(**ID of Meta Device**, value=20)
theVolume = int(indigo.devices[**ID of the Meta Device**].states['brightnessLevel'])+1
      result2 = airfoilPlugin.executeAction("connect", deviceId=**ID of Speaker**, waitUntilDone=True)  # ID of Speaker device
      result = airfoilPlugin.executeAction('setVolume', deviceId=**ID of Speaker**, props={'volume': theVolume}, waitUntilDone=True)
Speaker Off:
        result = airfoilPlugin.executeAction("disconnect", deviceId=**ID of Speaker**, waitUntilDone=True)  # ID of Speaker device
