mgolden50 wrote:Maybe you can set it up so that if so that if Handle DIM as ON/OFF is selected ,the need to set up a DIM variable would be filled in as N/A
mgolden50 wrote:Now I hadn't installed your latest fix. So that may be the issue.
Mar 11, 2018 at 5:46:27 PM
Alexa-Hue Bridge Error Unable to access 'Fireplace' from 'Alexa Hub (Upstairs)', associated device #9341080 not found
Alexa-Hue Bridge Error Unable to access 'Bedroom Curtains' from 'Alexa Hub (Rooms)', associated device #228365860 not found
Alexa-Hue Bridge Error Unable to access 'Side Curtains' from 'Alexa Hub (Rooms)', associated device #969031306 not found
Alexa-Hue Bridge Error Unable to access 'Back Curtains' from 'Alexa Hub (Rooms)', associated device #1848934248 not found
Alexa-Hue Bridge Error Unable to publish 'Fireplace' from 'Alexa Hub (Upstairs)', associated device #9341080 not found
Alexa-Hue Bridge Error Unable to publish 'Bedroom Curtains' from 'Alexa Hub (Rooms)', associated device #228365860 not found
Alexa-Hue Bridge Error Unable to publish 'Dinner Table' from 'Alexa Hub (Upstairs 2)', associated device #452846569 not found
Alexa-Hue Bridge Error Unable to publish 'Back Curtains' from 'Alexa Hub (Rooms)', associated device #1848934248 not found
Alexa-Hue Bridge Error Unable to publish 'Ceiling Fan' from 'Alexa Hub (Upstairs 2)', associated device #1776418132 not found
Alexa-Hue Bridge Error Unable to publish 'Side Curtains' from 'Alexa Hub (Rooms)', associated device #969031306 not found
Alexa-Hue Bridge Error getHueDeviceJSON exception:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/hue_listener.py", line 338, in getHueDeviceJSON
alexaDeviceNameKey = PLUGIN.globals['alexaHueBridge'][ahbDevId]['hashKeys'][alexaDeviceHashedKey]
KeyError: '843c743e599d0397f18102a3ecb344c57194ed070d3cc5cdb87e37dfff5c4467'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'Alexa Hub (Admin)'. Line '186' has error='must be string or buffer, not None'
Alexa-Hue Bridge Error Unable to access 'Dinner Table' from 'Alexa Hub (Upstairs 2)', associated device #452846569 not found
Alexa-Hue Bridge Error Unable to access 'Ceiling Fan' from 'Alexa Hub (Upstairs 2)', associated device #1776418132 not found
Colorado4Wheeler wrote:I don't have to set up the Echo's as devices, right, I can continue to run as normal and that's an optional new feature if I read it right. Oh and all those device errors, none of them were on the same device for which I just added a new Indigo device, it was all a different AHB server device.
Users browsing this forum: No registered users and 18 guests
