howartp wrote:Hi Ben
01 0B 00 04 00 0F 05 5B 03 49 80 01 6A
The 80 01 there is "Clicked button 1" (ie the top button). (The 80 is decimal 128, which is reduced by 127 to give decimal 1)
Node: 0F = 16
Button: 1 or 2
ActionID: 1 or 80 = 1 or 128
Action = Click
Button should always therefore be 1 or 2; you shouldn't get up to buttons 7, 8 or 9.
The last digit 6A and I think the 49 before it will keep increasing but that's fine; they're like a checksum value.
Can you paste some more recent copies of the output?
Peter
Right. I see. I had used the button decoding from the wrong command. This is a "Central Scene"... And you are correct. Once I fixed that, it's always button 1...
I haven't dug far enough to see why it's not calling the triggers?
Z-Wave Scene Controller Debug startup called -- subscribing to all incoming Z-Wave commands
Z-Wave Scene Controller Debug Start processing trigger Catherine light
Z-Wave Scene Controller Debug Start processing trigger Catherine light copy
Z-Wave received "Rec Room - Catherine Light - zw 15" scene 1 (0001)
Z-Wave Scene Controller Debug Button: 1
Z-Wave Scene Controller Debug Bytes 7 & 8: 5B 03
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 6F 80 01 4C
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 6F 80 01 4C
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 70 80 01 53
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 70 80 01 53
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 71 80 01 52
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 71 80 01 52
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 72 80 01 51
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 72 80 01 51
Z-Wave received "Rec Room - Catherine Light - zw 15" scene 2 (0002)
Z-Wave Scene Controller Debug Button: 2
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 73 80 02 53
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 73 80 02 53
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 74 80 02 54
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 74 80 02 54
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 75 80 02 55
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 75 80 02 55
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 76 80 02 56
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 76 80 02 56
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 77 80 02 57
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 77 80 02 57
Z-Wave Scene Controller Debug Raw Node 85 command: 01 0B 00 04 00 0F 05 5B 03 78 80 02 58
Z-Wave Watcher Debug Raw command received (Node 15): 01 0B 00 04 00 0F 05 5B 03 78 80 02 58
