Whats wrong?
Thu Nov 12, 2020 12:54 pm
Bildhauer offline
Whats wrong?
Hello,
what's wrong. I am suffering in getting the Switch work together with your plug in.
Indigo Z-Wave Version: 7.4.1
Node ID: 179
Model: Remote Double Switch (ZME-WALLC-S)
Model ID: 01000101
Manufacturer: Duwi
Manufacturer ID: 0115
Protocol Version: 3.92
Application Version: 1.01
Model Definition Version: 1
Library Type: 3
Class Name: Basic Wall Controller
Class Hierarchy: 04 : 18 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 8Ev1 8Fv1 98v1 59v1 5Av1 5Bv1 5Ev1 20v1 2Dv1 70v1 72v1 73v1
Features: routing, battery, beaming, security, waking
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1] 4:[1] 5:[1]
Config Values: 1:0 2:1 11:8 12:8 13:8 14:8 21:255 22:0 24:0 30:1
received "Taster Büro" scene 3 (0003)
Z-Wave received "Taster Büro" scene 1 (0001)
Remote Desktop Bild 12. November 2020 um 13.52.05 MEZ.jpg (309.86 KiB) Viewed 3714 times
Remote Desktop Bild 12. November 2020 um 13.49.06 MEZ.jpg (258.81 KiB) Viewed 3714 times
Thu Nov 12, 2020 3:22 pm
Re: Whats wrong?
Hi Bildhauer,
A couple of things:
1) You have made a change to the Office Switch (Taster Büro) that is still pending (the red "change pending" in the device list).
2) If you are using the four buttons for Scene Control (which it looks like) then I would change the "Button 2 and 4 mode" to be Independent, the same as "Button 1 and 3"
Once you've done those, and waited for the switch to wakeup and accept the changes, give it another try.
If you don't get anywhere, download my ZWave Watcher plugin, create a ZWave Watcher device and point it at your switch, then press some buttons on your switch.
If the switch is sending anythinig, it will show in the Indigo log what it's sending then I can decode it and help you further.
Peter
Fri Nov 13, 2020 6:18 pm
Bildhauer offline
Re: Whats wrong?
I've done what you said. Pressing the buttons of the witch the log tells me:
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 65 00 01 7C
Z-Wave received "Taster Büro" scene 6 (0006)
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 66 00 06 78
Z-Wave received "Taster Büro" scene 5 (0005)
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 67 00 05 7A
Sun Nov 15, 2020 4:17 pm
Re: Whats wrong?
That all looks correct.
I'm not sure how you're receiving scene 6 or 5 from that device since it only has four buttons, but a trigger on Button (1, 5 or 6) with Click action is correct.
You can turn on debug mode for the ZWave Scene Controller but it will only tell you what i've just said.
Peter
Mon Nov 16, 2020 5:57 am
Bildhauer offline
Re: Whats wrong?
Hello Peter,
but the Scene Controller doesn't do the expected action (light on or off).
IS the switch itself setup wrongly (see attachment)?
Best regards
Bildhauer
Mon Nov 16, 2020 10:56 am
Re: Whats wrong?
That’s a different device to the one you sent before I think?
I would have buttons 1&3 and 2&4 set to Independent like I suggested for the office switch, but the rest looks ok.
Turn Zwave scene controller debug on. (Interfaces > plugins > Zwave scene controller > configure > debug)
Then send button clicks again and see what shows.
Peter
Tue Nov 17, 2020 12:35 pm
Bildhauer offline
Re: Whats wrong?
This is the outcome with "debug on":
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 8A 00 01 93
Z-Wave received "Taster Büro" scene 3 (0003)
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 8B 00 03 90
Z-Wave received "Taster Büro" scene 2 (0002)
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 8C 00 02 96
Z-Wave received "Taster Büro" scene 4 (0004)
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 8D 00 04 91
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 66.80 W
The actions to be done when button 1 has been clicked is not working.
Tue Nov 17, 2020 2:02 pm
Re: Whats wrong?
Ah, apologies!!!
I completely forgot that you need a ZWave Scene Controller device before you can use the triggers.
Please create a Device > Zwave Scene Controller > Scene Controller and pick your switch from the list.
Then try again.
There's quite a bit of info in the debug that I need to tidy up, but the top bit tells you the buttons and actions.
Peter
Wed Nov 18, 2020 1:24 pm
Bildhauer offline
Re: Whats wrong?
I think that was the issue. After creating this device the log shows:
Z-Wave Scene Controller Debug Node ID 181 found in controllerIDs
Z-Wave Watcher Debug Raw command received (Node 181): 01 0B 00 04 00 B5 05 5B 03 91 00 01 88
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Version: 1.0.40
Z-Wave Scene Controller Debug Central Scene Command received:
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 B5 05 5B 03 91 00 01 88
Z-Wave Scene Controller Debug Node: 181
Z-Wave Scene Controller Debug Button: 1
Z-Wave Scene Controller Debug ActionID: 0
Z-Wave Scene Controller Debug Action: Click
Z-Wave Scene Controller Debug dA: B5
Trigger Testrigger
Z-Wave Scene Controller Debug Skipping 1 as Triggered
Z-Wave Scene Controller Debug Skipping 2 as Triggered
Z-Wave Scene Controller Debug Skipping 3 as Triggered
Z-Wave Scene Controller Debug Skipping 4 as Triggered
Z-Wave Scene Controller Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 257, in zwaveCommandReceived
File "plugin.py", line 421, in triggerEvent
AttributeError: 'NoneType' object has no attribute 'ownerProps'
Wed Nov 18, 2020 4:58 pm
Re: Whats wrong?
Hi
Grab https://github.com/howartp84/ZWaveScene ... tag/1.0.41
It's so long since I wrote that code (and left the code a mess) that it needs tidying.
The above version will let me see what's happening.
Sat Nov 21, 2020 7:43 am
Bildhauer offline
Re: Whats wrong?
Is this an official update?
Best regards
Bildhauer
Sat Nov 21, 2020 1:58 pm
Re: Whats wrong?
I don’t know what you mean by official but I wouldn’t have told you to install it if it wasn’t to be installed.
Peter
