No log output
Thu Feb 15, 2018 3:28 pm
new2me07 offline
No log output
I'm trying to get all this figured out as I have about 5 evolve scene controller I used to use with vera. Just a simple single gang momentary switch. Everything seems straight forward enough except the logs show nothing. I enabled logging on the Zwave interface and can see the button presses, but no button ID or anything. I can see the scene controller enabling debugging in the log, it just doesn't print anything to it.
Any ideas?
Z-Wave Scene Controller Debug logging enabled
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 29 03 20 01 FF 06
Z-Wave Debug . . basicSetState: node 041, endpoint None, value 255 (no node dispatch)
Thu Feb 15, 2018 3:48 pm
Re: No log output
Hi there.
It looks like the device is sending setBasicState() commands which I've not written into the plugin - in fact I've not seen them before.
The plugin supports both Basic Scene and Central Scene commands, which are the two types of Scene commands.
I can look at Basic State commands in due course but it will be a couple of weeks at the earliest.
Peter
Thu Feb 15, 2018 3:56 pm
Re: No log output
(I've just quickly looked at specs - it's using the Basic command class which wouldn't normally be used for "Scene control" as such, but I can see with this model it will be useful to operate it in this way so I'll get support added.)
Peter
Thu Feb 15, 2018 3:58 pm
new2me07 offline
Re: No log output
In case this helps this is the Zwave output when I press and hold the "up" toggle.
Z-Wave Debug RCVD dimmerLevelChangeStop: 01 08 00 04 00 29 02 26 05 FB
Z-Wave Debug . . dimmerLevelChangeStop: node 041, endpoint None
Z-Wave Debug RCVD basicGetState: 01 08 00 04 00 29 02 20 02 FA
Z-Wave Debug . . basicGetState: node 041, endpoint None
Thu Feb 15, 2018 3:59 pm
new2me07 offline
Re: No log output
Thank you very much Sir!
Thu Feb 15, 2018 5:16 pm
Re: No log output
Can you also re-sync it in Indigo (no debug logging needed please) and copy/paste the log results into a reply for me? I'd like to get the details on how that module is identifying itself.
Thu Feb 15, 2018 5:53 pm
Re: No log output
As well as Matts request, do you know the model no and have a link to manual?
If not we’ll get it from Matts info.
If you can press each button and paste logs again that would also help.
Mon Feb 19, 2018 6:01 pm
new2me07 offline
Re: No log output
Log output from Re-sync
Z-Wave Syncing - started for "041 - Remote Switch"
Z-Wave Syncing - retrieved module neighbors list: 3, 5, 6, 7, 9, 10, 13, 14, 15, 17, 19, 21, 22, 23, 24, 26, 27, 28, 30, 31, 32, 38, 39
Z-Wave Syncing - assigning return route to "041 - Remote Switch"
Z-Wave Syncing - retrieved manufacture and model names: Evolve - 0113, Remote Switch - 54573033
Z-Wave Syncing - retrieved protocol version 3.36, app version 5.30
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Remote Switch : -- (04 : 12 : 00, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 26v1 87v1 27v1 70v1 72v1 86v1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - complete
Mon Feb 19, 2018 6:06 pm
new2me07 offline
Re: No log output
Button Press results
Up
Held in up Position
Z-Wave Debug RCVD dimmerLevelChangeStart: 01 0A 00 04 00 29 04 26 04 20 63 BD
Z-Wave Debug . . dimmerLevelChangeStart: node 041, endpoint None, brightening
Down
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 29 03 20 01 00 F9
Z-Wave Debug . . basicSetState: node 041, endpoint None, value 0 (no node dispatch)
Held Down
Z-Wave Debug RCVD dimmerLevelChangeStart: 01 0A 00 04 00 29 04 26 04 60 01 9F
Z-Wave Debug . . dimmerLevelChangeStart: node 041, endpoint None, dimming
Mon Feb 19, 2018 6:11 pm
new2me07 offline
Re: No log output
It's an Evolve LTM-5 switch. All the manuals I found were just two pages. I don't think they will help.
Wed Feb 28, 2018 11:03 am
new2me07 offline
Re: No log output
Is there anyway to make a trigger based on the raw zwave output?
Wed Feb 28, 2018 12:45 pm
Re: No log output
Yes, there's a Z-wave trigger for matching raw output from a specific device.
Mon Mar 05, 2018 5:04 pm
new2me07 offline
Re: No log output
Every other device that seems to be the case but the Evolve Scene Switches (because they're not defined, I imagine) don't have any options available as being set up as a trigger. Any relatively easy work arounds that may work?
Mon Mar 05, 2018 5:10 pm
Re: No log output
You sure you're looking in the right place? The trigger is "Z-Wave command received". Then after you pick the device, you want "Match Raw Packet".
Mon Mar 05, 2018 5:43 pm
new2me07 offline
Re: No log output
Yes Sir, thats exactly where. Theres simply no options available at all from those devices. All others populate with at least that option.
