Utilising Button held command
Thu Feb 09, 2017 5:06 pm
colinpartridge offline
Wondering whether I could use the button held command to control volume of Sonos device. I'm thinking along the lines of volume changing whilst button is held. I imagine this would involve some kind of python script with a loop, but could do with some pointers to get me started...or tell me that it won't work.
Colin
Thu Feb 09, 2017 8:22 pm
Re: Utilising Button held command
That's already supported, depending on your device.
Devices that use Central Scene class include Hold and Release commands.
Hold will fire every (second?) that you're holding the button, then Release will fire once when you let go.
Not sure if it's every second or what it is - that's down to Zwave spec/implementation, not my choosing.
Fri Feb 10, 2017 7:30 am
Thanks Howard, I'm using a ZRC-90 controller, but it looks like the hold down time will be too long to get a decent response ( 2 seconds mentioned in the manual). Works well recalling sonos presets though.
Colin
Fri Feb 10, 2017 8:04 am
I have just tried holding down the button on a ZRC-90. There is a slight delay before Indigo starts putting messages in the Event Log that the button is being held down and then they come thick and fast until you let go of the button and get the Release message. :)
Fri Feb 10, 2017 8:29 am
Ok, cool, better than I thought, haven't looked at it closely just yet. Just need to get a bit of python script together for the Volume up/down loop. Something for the weekend.
Colin
Sat Feb 11, 2017 3:58 am
You don't need any a scripting.
Trigger: Button held down
Action: Lower volume by 5%
Press and hold the button, the volume will keep decreasing.
Sat Feb 11, 2017 4:55 am
Sorry Howard, I'm being dumb but I don't see a Lower Volume By 5% Sonos action, just Volume up, Volume Down. :(
Colin
