ZWave Scene Controller
Thu Jan 26, 2017 2:26 am
Re: ZWave Scene Controller
Can you resync / exclude / include - I think Autolog had same problem before.
Thu Jan 26, 2017 2:32 am
yassi offline
I will try and contact Jon (autolog), I saw his post.
Used the "L" button to include it - as stated in his post.
He found out that there are some glitches with the documentation.
Yassi
Wed Feb 15, 2017 1:04 am
bluefightingcat offline
Is there a way to use this Scene Controller to turn scenes on and off?
E.g. I have a situation where I want to create a scene, where if I walk into the room and my motion sensor triggers, the lights turn on. However, I only want this to happen when I have manually activated the scene using a switch.
So if the Switch is turned on, the motion sensor will trigger the lights.
If the Switch is turned off, nothing will happen.
Would this be possible?
Wed Feb 15, 2017 1:29 am
Yes.
Create an trigger for your motion detector that turns on the lights as normal.
Now create a trigger for "Zwave Scene Controller > Button1 Clicked" that does Server action > Enable Trigger > Motion detection.
And another trigger for "Zwave Scene Controller > Button1 DoubleClicked" that does Server action > Disable Trigger > Motion detection.
Now when you press button 1, the motion detection will trigger the lights; when you double-click it will stop motion detection.
Wed Feb 15, 2017 1:55 am
Great. Thanks
Sun Feb 19, 2017 9:18 am
Gusten offline
Hi
I saw Glenns post, and i have the same issue.
I have a fibaro The button before, and thats working. But the new one, i get this error
19 feb. 2017 16:13:55
Z-Wave received "Knappen Sovrum" scene 1
Zwave Scene Controller Debug -----
Zwave Scene Controller Debug Central Scene Command received:
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 1F 05 5B 03 04 80 01 37
Zwave Scene Controller Debug Node: 31
Zwave Scene Controller Debug Button: 1
Zwave Scene Controller Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 89, in zwaveCommandReceived
IndexError: list index out of range
Did you find anything about this error?
Thanx Martin
Mon Feb 20, 2017 3:16 am
Oops, I don't know if I looked. :-(
I'll try and look sometime this week.
Peter
Mon Feb 20, 2017 6:30 am
Gusten offline
Thanxs :)
Mon Feb 20, 2017 10:38 am
Ok, I know what the problem is - and I think I must have looked at it before because I remember the problem!
I'll sort it asap; I'm involved in theatre production all week so running here and there.
Peter
Tue Mar 14, 2017 3:43 am
I've just tidied up this subforum to match my others so I'm locking this thread as it covers a multitude of areas that have mostly been sorted.
The 'index out of bounds' error will be sorted this week.
Please start new topics if you have further questions not addressed in the new announcement post.
Peter
