ZWave Scene Controller
Sun Nov 13, 2016 7:58 am
This is an Indigo 7 plugin that I wrote early in the Indigo 7 beta process when developers had access to Zwave APIs but the UI hadn't been updated to support scene control. I'm throwing it out there if anyone wants to use it.
I'm still using my version as:
  • I prefer my UI
  • I can support new Zwave devices that come out, without needing a device profile to be written by Matt/Jay
  • I'm hoping to add support for multiple remotes to one trigger - say if you've a large living room with two of the same Zwave remote that you want to perform the same functions, without having to duplicate and maintain two sets of triggers.
Matt is also working on (in due course) enabling me to filter the device list to just devices that support scenes.
Download link: https://www.dropbox.com/sh/cnhjecvs93gs ... Yb0ja?dl=1
Peter
Sun Nov 13, 2016 2:26 pm
Fordy offline
Re: ZWave Scene Controller
Hey Peter,
I had a go, but it appears to fail for me, any clues what I did wrong? :)
Zwave Scene Controller Debug Stop processing trigger Button-Test
Zwave Scene Controller Debug Start processing trigger Button-Test
Zwave Scene Controller Debug -----
Zwave Scene Controller Debug Model ID:251727872
Z-Wave received "MasterRm-Button" scene 31769
Zwave Scene Controller Debug Central Scene Command received:
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 11 80 01 FF
Zwave Scene Controller Debug Node: 40
Zwave Scene Controller Debug Button: 1
Zwave Scene Controller Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 89, in zwaveCommandReceived
IndexError: list index out of range
Remote address I set to their paired device.
Button ID I set to 1 as that's what showed in the debut output.
Set the action to click.
Sun Nov 13, 2016 2:36 pm
That's interesting...
Mine's working ok; I did update the code last night to add support for quintuple-click (ie 5 clicks) but single click should be straight off.
Use this version and paste me the debug log again - I need the ActionID which should now appear after the Node and Button lines.
https://www.dropbox.com/sh/7rj7w9q11x0k ... Gqjaa?dl=1
Peter
Sun Nov 13, 2016 2:40 pm
Actually, the action ID is in the command string you posted - it's sending action ID 80 - the supported actions are 00 through 07 for the Fibaro Button. :?
Are you using encrypted mode or non-encrypted?
Peter
Sun Nov 13, 2016 2:43 pm
Fordy offline
Encrypted mode - I was excited about having encryption so figured I'd bang it on, but have no idea how that actually works at ground level yet! The magic successfully hid it. :)
Sun Nov 13, 2016 2:45 pm
Right.
Can you send me the log when you do a Click, a Double Click, a Triple Click, a Quad Click and a Quint Click?
I need to see what actions IDs it sends.
Use whichever version you've got installed.
Peter
Sun Nov 13, 2016 3:02 pm
andarv offline
Plugin works great with my NodOn - tanx!
Sun Nov 13, 2016 3:21 pm
Excellent!
Unfortunately my Fibaro Button has just died - probably the battery, but I haven't got round to ordering any spares yet! :(
Peter
Sun Nov 13, 2016 4:13 pm
andarv offline
My NodOn was dead this morning when I was super exited to get it working, one battery down the drain while waiting in a drawer....
Mon Nov 14, 2016 11:58 am
Fordy offline
Heya Peter,
Here they are from each of the 1,2,3,4,5 clicks:
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 26 80 01 FF
Z-Wave received "MasterRm-Button" scene 32537
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 27 83 01 FF
Z-Wave received "MasterRm-Button" scene 32793
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 28 84 01 FF
Z-Wave received "MasterRm-Button" scene 33049
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 29 85 01 FF
Z-Wave received "MasterRm-Button" scene 33305
Zwave Scene Controller Debug Raw command: 01 0B 00 04 00 28 05 5B 03 2A 86 01 FF
Mon Nov 14, 2016 7:03 pm
Strange that it's sending 80+ action IDs instead of 01-6.
I should be able to code that this week, but busy next two nights.
Mon Nov 14, 2016 7:16 pm
I'll be releasing a new installer for Indigo shortly that fixes it for the Fibaro Button, but the fix you'll want (based on the spec) for your plugin is to only use the last 3 bits to determine the click count:
actionID = (actionID & 0x07)
Mon Nov 14, 2016 7:18 pm
Cool, thanks Matt.
Tue Nov 15, 2016 1:20 pm
Fordy offline
Awesome that works perfectly! Thanks very much for getting a proper fix out so quickly, impressed! :)
Tue Nov 15, 2016 1:21 pm
Fordy offline
(I now have an evil "house wideshutdown" button. Muahwuahwuahwuahwuah!)
