Bug in function variableDeleted in version 1.0.6?
Mon Jun 04, 2018 1:57 pm
macpro offline
I'm running version 1.0.6 which I downloaded from GitHub.
When I use your plugin together with the UniFi plugin, I get these errors a couple of times per day:
EPS - Homebridge Buddy Error Error in plugin execution ServerRemovedElem:
File "plugin.py", line 4967, in variableDeleted
---8<--- that line repeats and repeats and repeats until ---
RuntimeError: maximum recursion depth exceeded
I looked into plugin.py and noticed these lines around line 4967:
   # INDIGO VARIABLE EVENTS
   # Basic comm events
   def variableCreated(self, var): return eps.plug.variableCreated(var)
   def variableUpdated (self, origVar, newVar): return eps.plug.variableUpdated (origVar, newVar)
   def variableDeleted(self, var): return self.variableDeleted(var)
The last line is actually line 4967 and it returns self.variableDeleted.
Changed that to return eps.plug.variableDeleted and the errors are gone.
Mon Jun 04, 2018 2:21 pm
Re: Bug in function variableDeleted in version 1.0.6?
Just FYI if you’re interested you might want to check out HomeKit Bridge, which is effectively the replacement for HKB.
Mon Jun 04, 2018 5:01 pm
Colorado4Wheeler offline
This. Except it's the direct replacement for HBB (Homebridge Buddy) and not for HKB (HomeKit Bridge) :).
Tue Jun 05, 2018 7:30 am
Oops that’s what’s I meant to say. I get confused
