Install errors, not sure if I need iTunes.indigoPlugin
Wed Jan 10, 2018 3:12 pm
CliveS offline
Well thanks to you I got my python script working so decided to install Homebridge Buddy and got the following error.
I have removed iTunes.indigoPlugin and several other plugins I don't use and placed them in a 'plugins (disabled) Copy' folder so they don't show up.
Do I need to reinstall iTunes? and is the other error on line 1622 also associated with iTunes?
10 Jan 2018, 20:46:56
   Installing and enabling plugin EPS - Homebridge Buddy v1.0.1
   Loading plugin "EPS - Homebridge Buddy 1.0.1"
   Starting plugin "EPS - Homebridge Buddy 1.0.1" (pid 27834)
   Started plugin "EPS - Homebridge Buddy 1.0.1"
   EPS - Homebridge Buddy          Automatically creating and configuring the first Homebridge server
   SQL Logger                      creating table device_history_1623570568 for "Homebridge for Indigo"
   EPS - Homebridge Buddy          Building configuration for 'Homebridge for Indigo'
   EPS - Homebridge Buddy Error
# WARNING                                                           #
# You have 128 items for Homebridge but it only supports 99, you    #
# will be unable to use some of your items!                         #
# SUMMARY                                                           #
# Devices for Homebridge to parse          : 203                    #
# Included devices that Homebridge can use : 128                    #
# Devices over 99 that won't work          : 29                     #
   EPS - Homebridge Buddy Error    Exception in plugin.buildServerConfig line 4234: 'key itunes_control not found in dict'
                      CODE: if server.pluginProps["itunes_control"] == 1:
   EPS - Homebridge Buddy Error    Exception in plugin.homebridgeSaveConfig line 1622: Expecting object: line 23 column 29 (char 561)
                      CODE: json_data = json.loads(config)
   EPS - Homebridge Buddy          Starting the Homebridge server 'Homebridge for Indigo', do not try to use Siri until you get a message that the server has started
# WARNING                                                           #
# SUMMARY                                                           #
   EPS - Homebridge Buddy          EPS - Homebridge Buddy is loaded and ready to use
CliveS
Wed Jan 10, 2018 3:15 pm
Colorado4Wheeler offline
Re: Install errors, not sure if I need iTunes.indigoPlugin
First off, that's an upgrade misfire and if you go into your Homebridge Buddy server(s) and simply save them then that error will go away (it mainly happens on startup only). You can also upgrade to the latest development release that should address that issue as of 1.0.6 (latest dev release) as it was a known bug at the time.
Wed Jan 10, 2018 3:25 pm
CliveS offline
Upgraded and all now working fine, just need to RTFM now.
CliveS
Wed Jan 10, 2018 3:32 pm
CliveS wrote:
RTFM
LMAO!
Wed Jan 10, 2018 4:10 pm
Note that since the iTunes plugin is included with Indigo, the next time you run an installer it will put it back in the normal 'Plugins (Disabled)' folder.
Wed Jan 10, 2018 4:32 pm
CliveS offline
Jay I look forward to 7.1.2 or 7.2 (or even 8.0) so I can move them all again, I use a copy of the Disabled folder so they don't get seen in the menus.
Just thought that moving iTunes might have caused problems but all is working fine now with the dev release except trying to get the Yale lock to unlock is causing grief but not HBB's problem.
CliveS
