Error on saving config
Sat Jan 06, 2018 8:55 pm
MattDinOC offline
I'm new to homebridge and HBB, but not new to Indigo. :) I am trying to set up HBB, and running across this error when I try to save my HBB config:
Jan 6, 2018, 6:44:45 PM
   EPS - Homebridge Buddy          Building configuration for 'Indigo'
# SUMMARY                                                           #
# Devices for Homebridge to parse          : 52                     #
# Included devices that Homebridge can use : 25                     #
# Devices over 99 that won't work          : 0                      #
   EPS - Homebridge Buddy Debug    {
   "bridge": {
      "name": "Indigo",
      "username": "CC:22:3D:E3:CE:30",
      "port": 51826,
      "pin": "031-45-154"
   "description": "Homebridge-Indigo configuration generated by EPS Homebridge Buddy on 2018-01-06 18:44:45 for device Indigo",
   "platforms": [
         "platform": "Indigo",
         "name": "Indigo",
         "protocol": "http",
         "host": "127.0.0.1",
         "port": "8176",
         "path": "",
         "username": "[redacted]",
         "password": "[redacted]",
         "includeActions": true,
         "includeIds": ["614745064", "588283228", "228456643", "1784269267", "1498623590", "1791206213", "1667134434", "1000876139", "14940856", "1839069720", "275557157", "1111393994", "815750184", "410861352", "346408797", "402980985", "427876900", "1648819275", "1430328283", "272073437", "843886362", "1849999791", "1887545500", "135502029", "1317646674"],
         "thermostatsInCelsius": false,
         "accessoryNamePrefix": ""
   "accessories": [
   EPS - Homebridge Buddy Error    Exception in plugin.homebridgeSaveConfig line 1622: Expecting , delimiter: line 20 column 22 (char 436)
                      CODE: json_data = json.loads(config)
I'm running the latest Indigo (7.1.1) and HBB (1.0.1) releases. Anything I can do on my end to resolve this? Or is it a bug in the plugin code?
Matt
Sun Jan 07, 2018 8:49 am
Colorado4Wheeler offline
Re: Error on saving config
It's a bug, I can see it in your config where it added a comma to look for another platform. That's a tricky part of the code that has been problematic to work around and needs to be redone (on the list). In the meantime you can turn on the iTunes option for your server as it will plug the hole until I release an update as it'll add another platform there.
Sun Jan 07, 2018 8:56 am
Matt, you can also try downloading the latest dev release from Git, work was already done in that section a couple of times and likely resolved the issue.
Sun Jan 07, 2018 4:35 pm
MattDinOC offline
Thanks for the quick response! I tried turning on iTunes, and then installed the dev build, but neither seems to help. Here's the current log when I try to save the config:
Jan 7, 2018, 2:32:54 PM
# SUMMARY                                                           #
   "bridge": {
      "name": "Indigo",
      "port": 51826,
      "pin": "031-45-154"
   "description": "Homebridge-Indigo configuration generated by EPS Homebridge Buddy on 2018-01-07 14:32:54 for device Indigo",
   "platforms": [
         "name": "Indigo",
         "protocol": "http",
         "port": "8176",
         "path": "",
         "platform": "iTunes"
   "accessories": [
   EPS - Homebridge Buddy Error    Exception in plugin.homebridgeSaveConfig line 1694: Expecting , delimiter: line 20 column 22 (char 436)
Matt
Sun Jan 07, 2018 4:38 pm
MattDinOC offline
Oh and for completeness:
Jan 7, 2018, 2:37:32 PM
# EPS - Homebridge Buddy                                            #
# Plugin Version      : 1.0.6                                       #
# Template Version    : 3.2.1                                       #
# Core Engine Version : 2.3.1                                       #
# Indigo Version      : 7.1.1                                       #
# Indigo API Version  : 2.0                                         #
# Alphas, Betas and Pre-Releases can be downloaded from:            #
#    https://github.com/Colorado4Wheeler                            #
# All support inquiries, questions or comments go to:               #
#    http://forums.indigodomo.com/viewforum.php?f=192               #
# Copyright (c) 2018 - Colorado4Wheeler & EPS                       #
Sun Jan 07, 2018 5:24 pm
MattDinOC offline
OK, great news! I found the problem! My Indigo server password contains a double-quote character. Since I "cleverly" redacted that info from my log dump that I posted here, there was no way you could have known that. I have now updated my password to remove that double-quote, and I'm past the error. This is a perfectly fine solution for me. :)
So I guess you might want to add a low-priority enhancement to your list to handle such cases, in case anyone runs into the same error in the future.
Thanks again for the help!
Matt
Mon Jan 08, 2018 9:20 am
Yup, that would do it all right. I've added it to the wish list for a future release to test for that condition.
