How to disable a HomeBridge Custom Installation running
Mon Oct 30, 2017 3:09 pm
nclemmons offline
I have Homebridge Buddy running and have upgraded to 7.1 Indigo.
I had some earlier challenges getting Homebridge working earlier this month but now have it working. However, I'm not sure why it is starting up a custom installation and how to remove this.
Can you help me resolve this error in my logs?
EPS - Homebridge Buddy Custom installation of Homebridge found, adding a custom server to Indigo
EPS - Homebridge Buddy Error Exception in plugin.homebridgeDiscovery line 1448: local variable 'json_data' referenced before assignment
CODE: for platform in json_data['platforms']:
Thank you!
neil
Wed Dec 13, 2017 2:46 pm
nclemmons offline
Re: How to disable a HomeBridge Custom Installation running
Anybody with help on how to disable a custom installation?
Thanks -
Sun Dec 17, 2017 9:30 am
echiang offline
In Indigo under Devices, can you search for "Homebridge Custom Server" and delete the device?
Mon Dec 18, 2017 2:42 pm
Colorado4Wheeler offline
I'm the author of HBB. The reason why you got a custom installation is because you implemented the original Homebridge for Indigo and when you install HBB it detects that so you don't lose your old stuff while migrating to the new. You should be able to delete the Custom server and that will take care of it, but I recommend you take the other out of your startup and rename the ~/.hb folder as well.
