Update for iOS 11 and Home Out of sync
Mon Sep 25, 2017 6:37 am
Dlucas10 offline
Hello!
Great plugin! I updated it last night to support iOS 11 and I thought everything was working fine.
It seems that when a light is turned off not via the Home app, that it doesn't update. It's updated immediately in Indigo, but when looking at Home it doesn't. I haven't tried to wait to see if ever updates, but I would expect it to be immediate. Would this have anything to do with naming? I changed some of the lights names in Home to be more understandable. Is it because the Names don't match that it's causing this?
Dave
Mon Sep 25, 2017 7:29 am
rehafer offline
Re: Update for iOS 11 and Home Out of sync
Does this happen regularly or occasionally? I will have a device get out of sync once in awhile but a few taps has it back.
Mon Sep 25, 2017 7:31 am
Colorado4Wheeler offline
I haven't had this happen on my HB setup, I'll keep a close eye on it in case it's something that's happening with IOS 11.
Mon Sep 25, 2017 8:12 am
Dlucas10 offline
It seems to do it consistently. I tested it again, if I stay in the Home app and turn off the light (either via Indigo or Manually), it doesn't update the status in Home. If I switch between apps - I did this to try to capture a screen shot of it being off in Indigo but on in Home, home updates right when it's brought to the foreground.
Along my testing, I did the same for Hue (I apologize I didn't do this first) which Home is talking directly to the Hue Bridge and not through HB and it seems to have the same issue. So maybe it's a iOS11 issue with Home not refreshing correctly.
I would expect Home to get updated right away... maybe I'm expecting too much! :lol:
Dave
Mon Sep 25, 2017 8:23 am
rehafer offline
The Home app updates itself every time it’s opened. (My non-Indigo Elgato take awhile to update so I can tell) It may be the only it updates status, or there might be a schedule also. I’m always flitting between apps so I’ve never noticed.
Mon Sep 25, 2017 9:40 am
rehafer offline
I did a little experiment on my own. With Home app on one device and Indigo Touch on another, I also saw no change in status while Home app stayed open. My Logitech pop button, on the other hand, when used to turn on an Indigo-HBB device, changed status as I watched. There must be a difference in the way the commands are sent/received/acknowledged when implemented by the different developers.
Edit: Or the difference is sending commands directly to HomeKit instead of the device.
