Question on what is needed for install
Sun Sep 24, 2017 7:19 am
norcoscia offline
Hi all, I'd like to give HB Buddy a try but I'm unclear about the correct process to follow for the initial install - the sticky say some time in the future HB Buddy will be updated and install everything needed to run but that note was not updated to say if that is the case now.
What is confusing me is one of the posts below says the install does in fact do everything (since I'm not an expert on the terminal line I would like to know what the correct process is) Does the sticky just need an update or do I need to figure out how to install HB Indigo first? The two post have conflicting info :-(
Thanks in advance for any help...
_______
Norm
Sun Sep 24, 2017 7:58 am
Colorado4Wheeler offline
Re: Question on what is needed for install
HBB is completely self contained now, you can download the plugin and install it and you should be good to go. I'll look over the docs and clean them up, thanks for pointing it out.
Sun Sep 24, 2017 8:00 am
norcoscia offline
Thank you Sir - I just got a new apple watch and Siri is very talkative - figured I would put it to work :D
_______
Norm
Sun Sep 24, 2017 8:02 am
Haha! I just updated to WatchOS 4 and am still getting used to her being vocal on my wrist rather than only my phones and pads.
Sun Sep 24, 2017 8:22 am
norcoscia offline
Trying to do the install but unclear as to what goes in the server path or how I figure out where to find the info?
Assuming it needs this since I got the error below when I closed the configuration box and left the path empty
   Started plugin "EPS - Homebridge Buddy 1.0.1"
   EPS - Homebridge Buddy Error    Exception in plugin.onBefore_startup line 164: 'key host not found in dict'
                      CODE: if self.pluginPrefs["host"] == "":
_______
Norm
Sun Sep 24, 2017 8:26 am
norcoscia offline
Is it looking for something like this
/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer
_______
Norm
Sun Sep 24, 2017 8:30 am
You need to go to Plugins -> Homebridge Buddy -> Configure and put in the IP address of the Indigo server as well as the port (usually 8176). If yo u secured Indigo with a user and password then add those as well.
Sun Sep 24, 2017 8:33 am
norcoscia offline
Yes - I did all that - but unsure what to put in the server path part (in the .png image I uploaded above) and can't find it in docs - sorry I'm not very smart :-(
_______
Norm
Sun Sep 24, 2017 8:42 am
That's only if you have a proxy for your Indigo web server, leave it blank otherwise.
Sun Sep 24, 2017 11:28 am
norcoscia offline
OK, I have everything running (I think) - I picked one device (a light on/off wall switch). I can't seem to get Siri to think anything is connected in my house - I can turn the switch on and off via the home bridge alias I created within Indigo but when I ask Siri to do it he/she says I don't have anything connected in my home - I must be missing something simple but not sure what it is.
This is my first time doing anything with Siri with all the stuff I have in indigo so it is likely something stupid I'm forgetting to do - if anyone has any ideas I'm all ears...
_______
Norm
Sun Sep 24, 2017 1:11 pm
CliveS offline
You are not alone, their are a few great plugins like this that have changed over time and in some cases just got so complex that starting off now from zero is so confusing I just gave up.
I won't name them because it would not be right but don't think you are the only one who is also lost at times...I expect you and I am not alone either.......
Thanks for asking the questions, I also was not clear on how to install as the messages were conflicting but now I might also join you and try HBB in a few days.
CliveS
CliveS
Sun Sep 24, 2017 4:21 pm
I've just done my first install of HBB this evening.
At first, I was in the same boat as you, not knowing what to do where, bemoaning the mixture of old and new threads, and general lack of instructions.
Then I found the Docs folder in the GitHub download - which guides you through exactly what to do! :oops:
Siri is now very helpfully turning on my lights etc, and in particular warming my car up in the morning!
Mon Sep 25, 2017 5:47 am
norcoscia offline
OK, got it working - I did not see any info on setting up your phone to point to the HomeKit on Indigo - that is what I was missing - also needed to add the PIN so it would work - like I said -- first time running with home kit so dumb mistake - thanks goodness for google :-)
_______
Norm
Mon Sep 25, 2017 7:33 am
I'll try to update the docs soon - the birth of this product was on the back of the other HB system that is used with Indigo - in fact the HB built into HBB is built by Webdeck, so some of those instructions are lacking in the documentation and I didn't think of it until this thread.
Mon Sep 25, 2017 7:38 am
norcoscia offline
No worries - heck - it looks to be a fantastic plug-in and I really appreciate you taking the time to share your work and knowledge with a non programer like me. Looking forward to messing with it and having fun!
_______
Norm
