I'm just not getting it
Fri Jun 02, 2017 10:28 am
rgspb offline
I've installed HBB and it appears that it's running. I've been able to setup the Homebridge Server in Indigo. I've been able to add that server to Home on my iPhone. So now how do I add my Insteon devices to the Home app? None of them show up. In setting up HBB I've told it to include ALL my devices but none show up in the Home app. I really wish there was a VERY simple step by step setup for all this without all the programming language...with pictures. I realize there is something kinda close as far as setting up the plugin, but then nothing about actually setting up each device or adding them to the Home app.
Fri Jun 02, 2017 10:34 am
rgspb offline
Re: I'm just not getting it
Also I'm getting this when I Reload the plugin:
Jun 2, 2017, 12:33:41 PM
Reloading plugin "EPS - Homebridge Buddy 0.20"
Stopping plugin "EPS - Homebridge Buddy 0.20" (pid 420)
Stopped plugin "EPS - Homebridge Buddy 0.20"
Starting plugin "EPS - Homebridge Buddy 0.20" (pid 1065)
EPS - Homebridge Buddy Debug Refreshing plugin information
Started plugin "EPS - Homebridge Buddy 0.20"
EPS - Homebridge Buddy Custom installation of Homebridge found, adding a custom server to Indigo
EPS - Homebridge Buddy Error Exception in plugin.homebridgeDiscovery line 1437: local variable 'json_data' referenced before assignment
CODE: for platform in json_data['platforms']:
EPS - Homebridge Buddy Starting the Homebridge server 'Homebridge Server', do not try to use Siri until you get a message that the server has started
EPS - Homebridge Buddy Debug Adding Homebridge Server to cache
EPS - Homebridge Buddy EPS - Homebridge Buddy is loaded and ready to use
Fri Jun 02, 2017 2:34 pm
steinis offline
you are not alone, same problem here :P
Fri Jun 02, 2017 4:19 pm
rgspb offline
Also I get this message too:
Jun 2, 2017, 4:15:10 PM
EPS - Homebridge Buddy Warning Stopping the Homebridge server 'Homebridge Server'
EPS - Homebridge Buddy Warning The Homebridge server 'Homebridge Server' has stopped
WebServer access denied "http://127.0.0.1:8176/devices.json" from Randall Glass @ 127.0.0.1
EPS - Homebridge Buddy The Homebridge server 'Homebridge Server' is back up
I'm the only administrator on this machine, how am I being denied access?
Wed Jun 07, 2017 9:24 pm
rgspb offline
Chirp...chirp...chirp...chirp...
Thu Jun 08, 2017 10:33 am
In the homebridge buddy device did you specify your indigo login details or your Mac login details?
Thu Jun 08, 2017 8:55 pm
rgspb offline
It's running on the same computer, do I need to give it a login for my computer?
Fri Jun 09, 2017 4:02 am
No you need to give it the indigo server login details!
Fri Jun 09, 2017 12:57 pm
rgspb offline
Oh! Wow that's been running so long I'm not sure I even remember what that is. I know it's written down so I'll give that a try. Thanks!
Fri Jun 09, 2017 3:47 pm
Colly offline
Try this topic http://forums.indigodomo.com/viewtopic.php?f=204&t=17874&hilit=homebridge+server+doesn%27t - it was a help to me when recently setting up HBB.
In particular this part...
Should the server path be filled. If so, is this the indigo path?
No, you should not be filling in the server path - that's the issue.
I had filled in the server path and was going nowhere fast.
Although it sounds like your problem may be a different one. Hope you get sorted.
Fri Jun 09, 2017 4:40 pm
rgspb offline
Great, thank you!
Sat Jun 10, 2017 7:28 pm
rgspb offline
So I was able to get this to work...on a different machine in a different home. I think I've really screwed up the install at my main computer which I am away from right now. I did manage to log into that Mac and uninstall the HBB plugin and then reinstall it. I got an error in the log from the plugin starting up and there's really no way to try to set up the Home app while I'm not at that house so I'm kind of on hold for now.
Sun Jun 18, 2017 4:14 pm
rgspb offline
OK so I'm back home to my main computer. I reinstalled the plugin and here's what I get. Can you shed any light on what may be happening?
Stopping plugin "EPS - Homebridge Buddy 0.20" (pid 92488)
Starting plugin "EPS - Homebridge Buddy 0.20" (pid 92890)
EPS - Homebridge Buddy Starting the Homebridge server 'SP Homebridge Server', do not try to use Siri until you get a message that the server has started
EPS - Homebridge Buddy Debug Adding SP Homebridge Server to cache
EPS - Homebridge Buddy Debug Automatically adding watched device 'Family Room Water Light' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched action group 'Good Evening' to cache as a watched item
Sun Jun 18, 2017 4:26 pm
rgspb offline
And if I select Show Homebridge Log I get this. It looks like there may be a conflicting plugin installed??
Jun 18, 2017, 6:23:37 PM
EPS - Homebridge Buddy [6/18/2017, 6:23:36 PM] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-indigo' since we already loaded the same plugin from '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge-indigo'.
[6/18/2017, 6:23:36 PM] Loaded plugin: homebridge-indigo
[6/18/2017, 6:23:36 PM] Registering platform 'homebridge-indigo.Indigo'
[6/18/2017, 6:23:36 PM] ---
[6/18/2017, 6:23:36 PM] Loaded config.json with 0 accessories and 1 platforms.
[6/18/2017, 6:23:36 PM] Loading 1 platforms...
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Initializing Indigo platform...
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo base URL is http://127.0.0.1:8176
[6/18/2017, 6:23:36 PM] Loading 0 accessories...
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices.json/
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Christmas ... rland.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 1140574832): Christmas Front Garland
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1140574832
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered Outdoor Appliance (2634-222) (ID 647985853): Christmas Rear Garland
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 647985853
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Christmas%20Tree.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 150455060): Christmas Tree
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 150455060
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Accent.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 413095153): Dining Accent
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 413095153
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Accent%202.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 1813327782): Dining Accent 2
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1813327782
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20 ... binet.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 1243188502): Dining China Cabinet
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1243188502
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Entry%20Accent%201.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered LampLinc (dual-band) (ID 1671807443): Entry Accent 1
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1671807443
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Entry%20Accent%202.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered LampLinc (dual-band) (ID 97378100): Entry Accent 2
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 97378100
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Family%20 ... 0Lamp.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ICON Appliance (ID 134698988): Family Rm Bird Lamp
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 134698988
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Family%20 ... Lamps.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered LampLinc (ID 1628886842): Family Rm Pineapple Lamps
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1628886842
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Family%20 ... Light.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 345423669): Family Room Water Light
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20Keypad.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered KeypadLinc Relay (ID 1273100891): Kitchen Keypad
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1273100891
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Lanai%20Lights.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 623061454): Lanai Lights
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 623061454
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Laundry%2 ... witch.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered SwitchLinc Relay (ID 1879077196): Laundry Room Light Switch
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1879077196
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20 ... 0Lamp.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered LampLinc (ID 1740231335): Living Rm Palm Tree Lamp
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1740231335
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20 ... Lamps.json
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Discovered LampLinc V2 (ID 1036273990): Living Rm Seahorse Lamps
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Ignoring excluded ID 1036273990
[6/18/2017, 6:23:36 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20 ... ccent.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered ApplianceLinc (ID 318960561): Living Rm Vase Accent
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 318960561
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Outside%2 ... rhead.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1227774662): Outside Carport Overhead
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 1227774662
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1300675009): Outside Front Door Overhead
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 1300675009
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Outside%2 ... ights.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Micro Module Dimmer (dual-band) (ID 600793848): Outside Front Lights
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 600793848
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/SP%20Home ... erver.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Homebridge Indigo Server (ID 446519552): SP Homebridge Server
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 446519552
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions.json/
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Bedtime.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 409663927): Bedtime
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 409663927
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Christmas ... 20Off.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 686900877): Christmas All Off
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 686900877
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Christmas%20All%20On.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 1330488639): Christmas All On
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 1330488639
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Early%20AM%20OFF.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 973684353): Early AM OFF
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 973684353
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Early%20AM%20ON.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 1213121854): Early AM ON
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 1213121854
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Good%20Evening.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 1821713518): Good Evening
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Movie%20Time%20OFF.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 1543380069): Movie Time OFF
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 1543380069
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Indigo request: http://127.0.0.1:8176/actions/Movie%20Time%20On.json
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Discovered Action (ID 664287318): Movie Time On
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Ignoring excluded ID 664287318
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Created 2 accessories
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Initializing platform accessory 'Family Room Water Light'...
[6/18/2017, 6:23:37 PM] [SP Homebridge Server] Initializing platform accessory 'Good Evening'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
events.js:160
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
at Object.exports._errnoException (util.js:1022:11)
at exports._exceptionWithHostPort (util.js:1045:20)
at Server._listen2 (net.js:1262:14)
at listen (net.js:1298:10)
at Server.listen (net.js:1376:9)
at EventedHTTPServer.listen (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
at HAPServer.listen (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
at Bridge.Accessory.publish (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:496:16)
at Server._publish (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge/lib/server.js:114:16)
at Server.<anonymous> (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v7.2.1-darwin-x64/lib/node_modules/homebridge/lib/server.js:372:14)
Mon Jun 19, 2017 5:37 pm
rgspb offline
I've really been working on this, trying all sorts of things including copying the entire Indigo 7 folder from the other Mac to this Mac. Still no dice. I just can't get past this error and I believe that's what's keeping the server from showing up in the Home app. Any help is greatly appreciated!!
