Homebridge Server Doesn't seem to work
Wed Jan 25, 2017 2:19 pm
Albatros offline
Re: Homebridge Server Doesn't seem to work
Homebridge log
EPS - Homebridge Buddy [1/25/2017, 7:50:08 PM] Loaded plugin: homebridge-indigo
[1/25/2017, 7:50:11 PM] Registering platform 'homebridge-indigo.Indigo'
[1/25/2017, 7:50:11 PM] ---
[1/25/2017, 7:50:11 PM] Loaded config.json with 0 accessories and 1 platforms.
[1/25/2017, 7:50:11 PM] Loading 1 platforms...
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Initializing Indigo platform...
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Path prefix is /Library/Application Support/Perceptive Automation
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Indigo base URL is http://127.0.0.1:8176
[1/25/2017, 7:50:11 PM] Loading 0 accessories...
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Indigo request: http://127.0.0.1:8176/Library/Application Support/Perceptive Automation/devices.json/
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Error parsing Indigo response for /Library/Application Support/Perceptive Automation/devices.json/
Exception: SyntaxError: Unexpected token < in JSON at position 0
Response: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
<head>
<title>Indigo Home Control Server</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<link rel="stylesheet" media="screen" type="text/css" href="/css/global4.css" />
<link rel="stylesheet" media="screen" type="text/css" href="/css/indigo4.css" />
<link rel="stylesheet" media="screen" type="text/css" href="/css/fonts.css" />
</head>
<body>
<center>
undefined page requested
</center>
</body>
</html>
<head>
</head>
<body>
<center>
</center>
</body>
</html>
[1/25/2017, 7:50:11 PM] [Homebridge for Indigo] Created 0 accessories
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[1/25/2017, 7:50:12 PM] Homebridge is running on port 51826.
Homebridge config
EPS - Homebridge Buddy {
"accessories": [],
"bridge": {
"username": "DD:22:3D:E3:CE:30",
"name": "Homebridge for Indigo",
"pin": "031-45-154",
"port": 51826
"description": "Homebridge-Indigo configuration generated by EPS Homebridge Buddy on 2017-01-25 19:54:02 for device Homebridge for Indigo",
"platforms": [
"username": "XYZ",
"protocol": "http",
"includeActions": false,
"platform": "Indigo",
"host": "127.0.0.1",
"thermostatsInCelsius": false,
"path": "",
"password": "XYZ",
"accessoryNamePrefix": "",
"port": "8176"
Thu Jan 26, 2017 11:57 am
Albatros offline
Does the above give any clue
Fri Jan 27, 2017 7:07 am
Albatros offline
I removed the plugin for the third time. And downloaded the plugin again. Did a install. Funny enough it did not install the "automatic Homebridge Server Device" so I created one myself, After a couple of times putting the server on off it stayed on.
For some reason it kept the "server path" in memory/config.json when I removed the plugin and did a reinstall of the plugin. Maybe first removing the plugin and and doing a complete restart of the mac mini removed the "server path" reference.
For next installers:
- (could not find this in the docs) but normally automatically a Indigo Homedbridge Device is created. Look in the general Indigo device list for it so no need for creating one yourself
- Fill in your Indigo Username and Password
- DO NOT put a server path if you are a first installer of homebridge buddy or any other homebridge install
Fri Jan 27, 2017 8:39 am
jalves offline
I'm a bit confused. In my installation I've wound up with two servers. One is "Homebridge for Indigo" and the other is "Homebridge Custom Installation". Only the Homebridge for Indigo is actually on. Everything seems to work correctly. Do I need the custom installation instance?
Jeff
Sat Jan 28, 2017 9:14 am
Colorado4Wheeler offline
The custom installation is just in case you installed extra Add-Ons, if you only used the HB-Indigio you don't have to have it. This is only created if it detects that you have a config file in ~/.homebridge.
Sat Jan 28, 2017 9:20 am
jalves offline
Thanks. I don't think I have a custom installation that I know about so I'll delete it.
Jeff
