Error
Sat Dec 24, 2016 10:07 am
farberm offline
Error
Have homebridge working but get the following error with Buddy?
Any help would be appreciated
Dec 24, 2016, 11:04:45 AM
Reloading plugin "EPS - Homebridge Buddy 0.17"
Starting plugin "EPS - Homebridge Buddy 0.17" (pid 68591)
EPS - Homebridge Buddy Error Error in plugin execution InitializeMain:
File "plugin.py", line 60, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/eps.py", line 87, in loadLibs
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 58, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 543, in refresh
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 848, in _parseDevicesXML
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 966, in _parseConfigUINode
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/lib/plugcache.py", line 643, in _getElementAttribute
ValueError: XML attribute 'hidden' in file /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/iFindStuff.indigoPlugin/Contents/Server Plugin/Devices.xml has a value that starts with invalid characters: ''false' (should begin with A-Z or a-z):
<Field defaultValue="20" hidden="'false" id="UDist" type="textfield">
<Label>Distance device can be moved and be at same address (ft or m)?</Label>
</Field>
Stopping plugin "EPS - Homebridge Buddy 0.17" (pid 68591)
Stopped plugin "EPS - Homebridge Buddy 0.17"
Sat Dec 24, 2016 10:55 am
Colorado4Wheeler offline
Re: Error
The problem is with iFindStuff, the devices.xml is malformed and that's why HBB is having problems. Try disabling the plugin. HBB reads in other plugins because the wrappers integrate with them.
