- Posted on
Mon Dec 19, 2016 4:13 pm
Colorado4Wheeler
offline
Something doesn't seem right there, that config file does not appear to have been generated by HBB but is still the default config.json file. Can you try backing up the config.json file, then saving it through the HBB plugin and seeing if that changes anything? If not, post the new config here and I'll see if it's off.
Also, a new version that totally changes this is due to release very soon - probably the next day or two, so if you want to hold off until then that might work better for you since the new version of HBB will have HB-Indigo entirely integrated into it and won't be as persnickety (hopefully).
