[SOLVED] Are Cameras supposed to show up twice?
Thu Dec 08, 2016 8:30 pm
blysik offline
I switched to creating camera devices via HBB. I was then able to add the cameras as camera accessories. However, I ALSO have a "light bulb" device for each camera showing up separately., which fail to do anything. Is this expected behavior?
Thanks.
Thu Dec 08, 2016 8:45 pm
Colorado4Wheeler offline
Re: [question] Are Cameras supposed to show up twice?
They don't do that for me, and I haven't gotten any word that others are having that issue either. Can you post a screen shot? You add just one camera device from HBB, I don't know how another device could possibly add itself without your asking the plugin to do so.
Thu Dec 08, 2016 8:56 pm
blysik offline
It's showing up via the Homebridge accessory bridge. I'll try to get a screen shot.
Thu Dec 08, 2016 9:01 pm
blysik offline
This is what happens when I try to turn it on / off:
[12/8/2016, 6:58:22 PM] [Homebridge Server] Frontlawn Cam: setLightOnState(1)
[12/8/2016, 6:58:22 PM] [Homebridge Server] Frontlawn Cam: setOnState(1)
[12/8/2016, 6:58:22 PM] [Homebridge Server] updateStatus of Frontlawn Cam: {"isOn":1}
[12/8/2016, 6:58:22 PM] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Frontlawn%20Cam.json
[12/8/2016, 6:59:56 PM] [Homebridge Server] Frontlawn Cam: setLightOnState(0)
[12/8/2016, 6:59:56 PM] [Homebridge Server] Frontlawn Cam: setOnState(0)
[12/8/2016, 6:59:56 PM] [Homebridge Server] updateStatus of Frontlawn Cam: {"isOn":0}
[12/8/2016, 6:59:56 PM] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Frontlawn%20Cam.json
And the Indigo log:
Dec 8, 2016, 6:58:22 PM
WebServer request to turn on device "Frontlawn Cam" from 127.0.0.1
EPS - Homebridge Buddy Error send "Frontlawn Cam" on failed
Dec 8, 2016, 6:59:56 PM
WebServer request to turn off device "Frontlawn Cam" from 127.0.0.1
EPS - Homebridge Buddy Error send "Frontlawn Cam" off failed
Thu Dec 08, 2016 9:05 pm
blysik offline
And here's how it looks in the Home app. Note the two cameras (Driveway Cam, and Frontlawn Cam) and you can see that two of the lights above them are the same names. (Hard to see that.)
http://imgur.com/a/e5gUE
Thu Dec 08, 2016 9:13 pm
I still have no idea, please post a copy of config.json.
Thu Dec 08, 2016 9:32 pm
blysik offline
$ more config.json
"bridge": {
"name": "Homebridge Server",
"username": "CC:22:3D:E3:CE:30",
"port": 51826,
"pin": "031-45-154"
"description": "Homebridge-Indigo configuration generated by EPS Homebridge Companion on 2016-12-08 18:54:42 for device Homebridge Server",
"platforms": [
"platform": "Indigo",
"protocol": "http",
"host": "127.0.0.1",
"port": "8176",
"path": "",
"username": "XXX",
"password": "XXX",
"includeActions": false,
"excludeIds": ["1509182177", "919224661", "1454708109", "942428811"],
"thermostatsInCelsius": false,
"accessoryNamePrefix": ""
"platform": "Camera-ffmpeg",
"cameras": [
"name": "Backyard Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.214:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.214/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"name": "Driveway Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.215:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.215/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"name": "Frontdoor Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.218:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.218/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"name": "Frontlawn Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.219:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.219/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"name": "Sideyard 1 Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.217:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.217/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"name": "Sideyard 2 Cam",
"videoConfig": {
"source": "-re -i rtsp://XX:XX@192.168.55.216:554/Streaming/Channels/2",
"stillImageSource": "-i http://XX:XX@192.168.55.216/Streaming/c ... /1/picture",
"maxStreams": 2,
"maxWidth": 640,
"maxHeight": 360,
"maxFPS": 15
"accessories": [
Thu Dec 08, 2016 10:11 pm
blysik offline
I can replicate this by removing the homebridge devices and the camera accessories. Then, re-add the homebridge accessory. As it steps through each of its devices to add, the ffmpeg-camera devices will be shown as light switches.
Thu Dec 08, 2016 10:33 pm
I am at a loss unless your HomeKit database is messed up, that's not how HBB, HB or HB Indigo work.
Thu Dec 08, 2016 11:31 pm
blysik offline
I even tried deleting my Home in iCloud. Same thing when added the homebridge server accessory back. Definitely seeing odd stuff.
Fri Dec 09, 2016 8:09 am
Different Computers offline
Is the camera also a motion sensor perhaps?
Fri Dec 09, 2016 10:33 am
blysik offline
So I've managed to find a workaround that prevents it from happening. Previously I had 'include all friendly devices'. I switched to not include anything by default, and then I went and manually included all the devices I wanted in Homekit. That worked.
Fri Dec 09, 2016 11:45 am
That's not a workaround, that's the intended design. If you included everything in Indigo then it would all show up in HomeKit - well at least up to 99 devices it would. That was the main intent of the plugin was so you could easily cherry pick the stuff you want to send over and ignore the rest.
Fri Dec 09, 2016 1:06 pm
blysik offline
I was assuming that it would ignore devices that weren't switches or dimmers. I.e., it would ignore anything that wasn't obviously a device HomeKit could represent.
Fri Dec 09, 2016 1:09 pm
No, the HB-Indigo does not discriminate at all unless it's really wonky, so you'll get everything and it will all be a switch by default.
