Device won't start
Mon Dec 05, 2016 2:16 pm
durosity online
Device won't start
So i've had a pre-existing setup running (and oops i didn't backup the config file and it's been wiped.. never mind :)
I don't seem to be getting errors, but for some reason the Server device that i created just won't start:
5 Dec 2016, 19:02:33
   Enabling plugin "EPS - Homebridge Buddy 0.12"
   Starting plugin "EPS - Homebridge Buddy 0.12" (pid 55978)
   EPS - Homebridge Buddy Debug    Refreshing plugin information
   Started plugin "EPS - Homebridge Buddy 0.12"
   EPS - Homebridge Buddy Debug    Adding Server - Home Bridge to cache
   EPS - Homebridge Buddy          EPS - Homebridge Buddy is loaded and ready to use
5 Dec 2016, 19:03:21
# EPS - Homebridge Buddy                                            #
# Plugin Version      : 0.12                                        #
# Template Version    : 3.2.1                                       #
# Core Engine Version : 2.9                                         #
# Indigo Version      : 7.0.2                                       #
# Indigo API Version  : 2.0                                         #
# Alphas, Betas and Pre-Releases can be downloaded from:            #
#    https://github.com/Colorado4Wheeler                            #
# All support inquiries, questions or comments go to:               #
#    http://forums.indigodomo.com/viewforum.php?f=192               #
# Copyright (c) 2016 - Colorado4Wheeler & EPS                       #
5 Dec 2016, 19:04:25
   EPS - Homebridge Buddy          Debug logging enabled
   EPS - Homebridge Buddy          Starting the Homebridge server 'Server - Home Bridge', do not try to use Siri until you get a message that the server has started
   EPS - Homebridge Buddy          sent "Server - Home Bridge" on
   EPS - Homebridge Buddy Warning  The Homebridge server 'Server - Home Bridge' has stopped
   Z-Wave                          sent "zzLounge - slats tilt" status request
   Z-Wave                          sent "zzLounge - slats tilt" energy status request
   EPS - Homebridge Buddy Debug    Plugin device 'Server - Home Bridge' configuration field changed
5 Dec 2016, 19:06:02
   EPS - Homebridge Buddy Debug    Validating action parameters on device
   EPS - Homebridge Buddy Debug    Automatically adding watched device 'Bedroom 1 - Claire's Light' to cache as a watched item
   EPS - Homebridge Buddy Warning  'Server - Home Bridge' has had a configuration change, restarting the Homebridge server now
   EPS - Homebridge Buddy          Building configuration for 'Server - Home Bridge'
# SUMMARY                                                           #
# Devices for Homebridge to parse          : 312                    #
# Included devices that Homebridge can use : 1                      #
# Devices over 99 that won't work          : 0                      #
   EPS - Homebridge Buddy Debug    {
   "bridge": {
      "name": "Server - Home Bridge",
      "username": "CC:22:3D:E3:CE:30",
      "port": 51826,
      "pin": "031-45-154"
   "description": "Homebridge-Indigo configuration generated by EPS Homebridge Companion on 2016-12-05 19:06:14 for device Server - Home Bridge",
   "platforms": [
         "platform": "Indigo",
         "protocol": "http",
         "host": "127.0.0.1",
         "port": "8176",
         "path": "",
         "username": “XXX”,
         "password": “XXX”,
         "includeActions": false,
         "includeIds": ["832644544"],
         "thermostatsInCelsius": true,
         "accessoryNamePrefix": ""
   "accessories": [
   EPS - Homebridge Buddy Debug    Found '/Users/Mike/.homebridge/config.json', saving the Homebridge configuration
   EPS - Homebridge Buddy          Homebridge configuration for 'Server - Home Bridge' saved
   EPS - Homebridge Buddy Warning  Stopping the Homebridge server 'Server - Home Bridge'
5 Dec 2016, 19:06:53
5 Dec 2016, 20:02:31
# SUMMARY                                                           #
   "bridge": {
      "port": 51826,
      "pin": "031-45-154"
   "description": "Homebridge-Indigo configuration generated by EPS Homebridge Companion on 2016-12-05 20:02:44 for device Server - Home Bridge",
   "platforms": [
         "protocol": "http",
         "port": "8176",
         "path": "",
         "username": “XXX”,
         "password": “XXX”,
   "accessories": [
5 Dec 2016, 20:06:14
5 Dec 2016, 20:06:40
   EPS - Homebridge Buddy Threaddebug Plugin device 'Server - Home Bridge' command sent
   EPS - Homebridge Buddy Threaddebug Raising onDeviceCommandTurnOn in plugin.py from call to actionControlDimmerRelay
   EPS - Homebridge Buddy Threaddebug Plugin device 'Server - Home Bridge' has been updated
   EPS - Homebridge Buddy Threaddebug Raising onAfter_pluginDeviceUpdated in plugin.py from call to pluginDeviceUpdated
   EPS - Homebridge Buddy Threaddebug Plugin device 'Server - Home Bridge' has had one or more state changes
   EPS - Homebridge Buddy Threaddebug Plugin device 'Server - Home Bridge' has had one or more attribute changes
   EPS - Homebridge Buddy Threaddebug 'Server - Home Bridge' is cached, checking for changes
I've tried deleting the device and re-creating it but no joy. Also restarting the plugin.
here's the data dump in case it helps :)
= CACHE                                                             =
= Cache Summary                                                     =
= Items: 2                                                          =
+ Cache Details                                                     +
- Devices                                                           -
+ Type:        Device                                               +
+ Name:        Bedroom 1 - Claire's Light                           +
+ ID:          832644544                                            +
+ Address:     4                                                    +
+ Device Type: zwDimmerType                                         +
+ Plugin:      com.perceptiveautomation.indigoplugin.zwave          +
+ Watched By:                                                       +
+    ID: 1077229354                                                 +
+       Attributes:                                                 +
+          name                                                     +
+ Type:        Device                                               +
+ Name:        Server - Home Bridge                                 +
+ ID:          1077229354                                           +
+ Address:     SERVER @ Indigo Server                               +
+ Device Type: Homebridge-Server                                    +
+ Plugin:      com.eps.indigoplugin.homebridge                      +
+ Watching:                                                         +
+    ID: 832644544                                                  +
+       Attributes:                                                 +
+          name                                                     +
- Variables                                                         -
- Action Groups                                                     -
- Watched Devices                                                   -
- 'Bedroom 1 - Claire's Light' (832644544)                          -
! States                                                            !
! brightnessLevel = 0                                               !
! onOffState = False                                                !
! Attributes                                                        !
! address = 4                                                       !
! batteryLevel = None                                               !
! blueLevel = None                                                  !
! brightness = 0                                                    !
! buttonGroupCount = 0                                              !
! configured = True                                                 !
! defaultBrightness = 81                                            !
! description =                                                     !
! deviceTypeId = zwDimmerType                                       !
! displayStateId = brightnessLevel                                  !
! displayStateImageSel = DimmerOff                                  !
! displayStateValRaw = 0                                            !
! displayStateValUi = 0                                             !
! enabled = True                                                    !
! energyAccumBaseTime = None                                        !
! energyAccumTimeDelta = None                                       !
! energyAccumTotal = None                                           !
! energyCurLevel = None                                             !
! errorState =                                                      !
! folderId = 1730343820                                             !
! greenLevel = None                                                 !
! id = 832644544                                                    !
! lastChanged = 2016-12-05 19:23:57                                 !
! lastSuccessfulComm = 2016-12-05 19:23:57                          !
! ledStates = []                                                    !
! model = Dimmer Switch (FGD211)                                    !
! name = Bedroom 1 - Claire's Light                                 !
! onBrightensToDefaultToggle = False                                !
! onBrightensToLast = True                                          !
! onState = False                                                   !
! pluginId = com.perceptiveautomation.indigoplugin.zwave            !
! protocol = ZWave                                                  !
! redLevel = None                                                   !
! remoteDisplay = True                                              !
! subModel =                                                        !
! supportsAllLightsOnOff = False                                    !
! supportsAllOff = False                                            !
! supportsColor = False                                             !
! supportsRGB = False                                               !
! supportsRGBandWhiteSimultaneously = False                         !
! supportsStatusRequest = True                                      !
! supportsTwoWhiteLevels = False                                    !
! supportsTwoWhiteLevelsSimultaneously = False                      !
! supportsWhite = False                                             !
! supportsWhiteTemperature = False                                  !
! version = 2.02                                                    !
! whiteLevel = None                                                 !
! whiteLevel2 = None                                                !
! whiteTemperature = None                                           !
= PLUGIN DEVICES                                                    =
* 'Server - Home Bridge' (1077229354)                               *
+ Attributes                                                        +
+ address = SERVER @ Indigo Server                                  +
+ batteryLevel = None                                               +
+ buttonGroupCount = 0                                              +
+ configured = True                                                 +
+ description =                                                     +
+ deviceTypeId = Homebridge-Server                                  +
+ displayStateId = onOffState                                       +
+ displayStateImageSel = PowerOff                                   +
+ displayStateValRaw = False                                        +
+ displayStateValUi = off                                           +
+ enabled = True                                                    +
+ energyAccumBaseTime = None                                        +
+ energyAccumTimeDelta = None                                       +
+ energyAccumTotal = None                                           +
+ energyCurLevel = None                                             +
+ errorState =                                                      +
+ folderId = 1862834123                                             +
+ id = 1077229354                                                   +
+ lastChanged = 2016-12-05 20:06:44                                 +
+ lastSuccessfulComm = 2016-12-05 20:06:44                          +
+ ledStates = []                                                    +
+ model = Homebridge Server                                         +
+ name = Server - Home Bridge                                       +
+ onState = False                                                   +
+ pluginId = com.eps.indigoplugin.homebridge                        +
+ protocol = Plugin                                                 +
+ remoteDisplay = True                                              +
+ subModel =                                                        +
+ supportsAllLightsOnOff = False                                    +
+ supportsAllOff = False                                            +
+ supportsStatusRequest = True                                      +
+ version = None                                                    +
+ Configuration                                                     +
+ accessory =                                                       +
+ actexclude = actexclude : (list)
     Item : -none- (string)      +
+ actinclude = actinclude : (list)
+ auto_hbuser = False                                               +
+ celsius = True                                                    +
+ computerip = 192.168.1.1                                          +
+ devexclude = devexclude : (list)
+ devinclude = devinclude : (list)
     Item : 832644544 (string)   +
+ hbpin = 031-45-154                                                +
+ hbuser = CC:22:3D:E3:CE:30                                        +
+ hideWrappedItems = True                                           +
+ indigoServer = True                                               +
+ itemcount = 103                                                   +
+ name = My Indigo Server                                           +
+ password = password                                               +
+ password2 = password                                              +
+ show_hbuser = False                                               +
+ totalcount = 103                                                  +
+ treatasdoor = treatasdoor : (list)
+ treatasdrapes = treatasdrapes : (list)
+ treatasgarage = treatasgarage : (list)
+ treataslock = treataslock : (list)
+ treatasswitch = treatasswitch : (list)
+ treataswindows = treataswindows : (list)
+ username = administrator                                          +
+ view = server                                                     +
+ wrappercount = 0                                                  +
+ States                                                            +
+ lastHealthCheck = 2016-12-05 20:06:43                             +
+ onOffState = False                                                +
+ restartPending = False                                            +
+ restartTime =                                                     +
+ statedisplay =                                                    +
Mon Dec 05, 2016 2:20 pm
Colorado4Wheeler offline
Re: Device won't start
Try to start Homebridge from the command line and see if it works. The device in Indigo is only a shortcut to try to start/stop/restart what's already installed on your system and isn't required to actually START the HBB daemon in the first place.
If HB starts on its own then the Indigo device should reflect that.
Mon Dec 05, 2016 2:39 pm
durosity online
Ah, now.. that DIDN'T load because the config file had reset to the original indigo port (i have to make it run on 8080 for boring reasons)
BUT that hasn't stopped it loading. I changed the port in Plugins > Buddy > Settings. Now when i launch it from terminal it shows up with the one item i've configured using the GUI, so it's definitely writing to the config file, but as soon as i try 'turn on' the server item in indigo it immediately turns off.
Now interestingly when it's running in the terminal log events are coming through to indigo:
   EPS - Homebridge Buddy          The Homebridge server 'Server - Home Bridge' is back up
   WebServer                       request to turn on device "Bedroom 1 - Claire's Light" from 127.0.0.1
   Z-Wave                          sent "Bedroom 1 - Claire's Light" on
   WebServer                       request to set device "Bedroom 1 - Claire's Light" brightness from 127.0.0.1
   Z-Wave                          sent "Bedroom 1 - Claire's Light" set brightness to 38
   EPS - Homebridge Buddy Threaddebug 'Bedroom 1 - Claire's Light' is cached, checking for changes
   Z-Wave                          sent "Bedroom 1 - Claire's Light" set brightness to 52
   Z-Wave                          sent "Bedroom 1 - Claire's Light" set brightness to 81
   Z-Wave                          sent "Bedroom 1 - Claire's Light" set brightness to 90
   WebServer                       request to turn off device "Bedroom 1 - Claire's Light" from 127.0.0.1
   Z-Wave                          sent "Bedroom 1 - Claire's Light" off
Mon Dec 05, 2016 2:41 pm
durosity online
Oh and i just noticed as soon as i launch home bridge in the terminal the device turns on.. so it must just be an issue with it starting the service.
Mon Dec 05, 2016 2:44 pm
That port is important! It looks like everything is good now. The "is alive" state of the device is based on, essentially, pinging that port number and see if it replies, if it does then HBB thinks the service is alive and well - so if you had something else on that port then HBB would have gotten a false positive.
Mon Dec 05, 2016 2:49 pm
durosity online
Ah, So does that mean i still have to run HB in the background in the terminal?
Mon Dec 05, 2016 2:53 pm
Yes, for now until the next (hopefully) release comes out that incorporates the entirety of managing HB and HB-Indigo into it. Think of the device in HBB as a bookmark to the already operational HB system you already have in place, so follow Webdecks instructions on auto-starting HB with your Mac. Or, alternatively, you can not do that and just hand-start the device in Indigo if you want, it should start it now that you have the ports figured out.
Mon Dec 05, 2016 3:02 pm
durosity online
Coolio! I was just assuming that turning it ON would also run the service in the background :)
Now to start the task of adding all the devices and assigning them to rooms! :)
Mon Dec 05, 2016 3:15 pm
durosity online
Ah, spoke too soon!
now just getting this repeatedly in the log:
if i kill it and start again it stops but then returns after a few mins!
Mon Dec 05, 2016 3:22 pm
Frakke offline
Hmm, having exactly the same..
Need something of logs or something?
Regards
Mon Dec 05, 2016 3:26 pm
This will come up as you make changes to the devices associated with Homebridge and it is by design. So, if you change the name of a device, create an alias, create a wrapper or change the config in any way this will happen. Alternatively you can do it by hand via the top menu system and disable automatic behavior by going into the configuration and turning off the auto restarts.
Mon Dec 05, 2016 3:39 pm
durosity online
I'm not sure how but it seemed to get into a bad state. Disabling the plugin, disabling home bridge, restarting the plugin then restarting homebridge seems to have stopped it from happening.
Mon Dec 05, 2016 3:55 pm
durosity online
So just to clarify.. as i'm going through setting devices to "treatas" items.. nothing shows up automatically until i go into terminal and kill homebridge then restart it.. that's expected behaviour right? (I'm just paranoid of getting this all setup again only to find something's not right and have to do it alllllll again!)
Mon Dec 05, 2016 4:01 pm
No, that's not supposed to be it at all :shock: . It should be that the only things that show up in the Treat As lists are devices that you have INCLUDED into Homebridge from the first option, that way you don't try to add stuff that you didn't want in there in the first place.
See screen shots and notes.
Only the devices or actions I INCLUDED are showing up in Treat As
I've included the highlighted devices but NOT the others
Mon Dec 05, 2016 4:04 pm
durosity online
Sorry i'll rephrase :) .. nothing i CHANGE will appear on homebridge apps until disable homebridge in the terminal and reload it? As in i've got 70 odd devices showing now all as lights. If i go and assign a door lock to the treatas to get it to show as a door lock in the home app i need to terminate homebridge in the terminal, then reload it?
