Installing Buddy on top of a working HomeBridge setup?
Tue Dec 06, 2016 1:09 pm
berkinet offline
Re: Installing Buddy on top of a working HomeBridge setup?
Ok.. All is well and my home bridge server is up and running. I did encounter one minor glitch you might want to address in the documentation... In the HBB plugin configuration window there is a field for Indigo server path. In my original installation of home bridge-indigo I just left that blank. However, while trying having problems trying to install HBB I had added a positive value:
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7 in the config dialog.
The json parser did not like that at all
Error: Parse error on line 17:
...: "8176",      "path": " /Library/Applicati
Expecting 'STRING', 'NUMBER', 'NULL', 'TRUE', 'FALSE', '{', '[', got 'undefined'
Deleting the field value in the config dialog fixed it. The field is discussed briefly in the homebridge-indigo instructions, But, other users, especially who use the HBB plugin for their first config, might make the same mistake I did.
Tue Dec 06, 2016 2:22 pm
Colorado4Wheeler offline
Interesting that I have not had that pop up in my testing, thanks for pointing it out!
Sun Dec 11, 2016 7:11 pm
rehafer offline
Installed HBB today and it's mostly working well. The only problem is that I've always run Homebridge via Terminal. Can someone point the way launch HB so that HBB can start and stop it?
Sun Dec 11, 2016 8:30 pm
Follow Webdecks instructions on installation, at the end is how to set it up for launchctl.
Mon Dec 12, 2016 1:58 pm
rehafer offline
Thanks, project for next day off
