Homebridge-Camera Device
Sun Dec 11, 2016 2:26 pm
brlandy offline
Re: Homebridge-Camera Device
Hi, I'm having a similar problem, cameras I'm adding are not showing up. I see in the homebridge log, however, that the devices are being excluded:
[12/11/2016, 3:20:47 PM] Loaded plugin: homebridge-camera-ffmpeg
[12/11/2016, 3:20:47 PM] Registering platform 'homebridge-camera-ffmpeg.Camera-ffmpeg'
[12/11/2016, 3:20:47 PM] ---
[12/11/2016, 3:20:48 PM] Loaded plugin: homebridge-indigo
[12/11/2016, 3:20:48 PM] Registering platform 'homebridge-indigo.Indigo'
[12/11/2016, 3:20:48 PM] ---
[12/11/2016, 3:20:48 PM] Loaded config.json with 0 accessories and 2 platforms.
[12/11/2016, 3:20:48 PM] Loading 2 platforms...
[12/11/2016, 3:20:48 PM] [Homebridge Server (percy)] Initializing Indigo platform...
[12/11/2016, 3:20:48 PM] [Homebridge Server (percy)] Indigo base URL is http://127.0.0.1:8040
[12/11/2016, 3:20:48 PM] Initializing Camera-ffmpeg platform...
[12/11/2016, 3:20:48 PM] Loading 0 accessories...
[12/11/2016, 3:20:48 PM] Camera is running on port 59709.
[12/11/2016, 3:20:48 PM] Camera is running on port 59710.
[12/11/2016, 3:20:48 PM] [Homebridge Server (percy)] Indigo request: http://127.0.0.1:8040/devices/Brendan%27s%20Camera.json
[12/11/2016, 3:20:48 PM] [Homebridge Server (percy)] Discovered Homebridge Camera (ID 912212441): Brendan's Camera
[12/11/2016, 3:20:48 PM] [Homebridge Server (percy)] Ignoring excluded ID 912212441
[12/11/2016, 3:20:49 PM] [Homebridge Server (percy)] Indigo request: http://127.0.0.1:8040/devices/Camera.json
[12/11/2016, 3:20:49 PM] [Homebridge Server (percy)] Discovered Homebridge Camera (ID 28380292): Camera
[12/11/2016, 3:20:49 PM] [Homebridge Server (percy)] Ignoring excluded ID 28380292
I have HBB set to manually include specific Homebridge friendly devices, and have not specified anything on the exclusion list. The Homebridge Cameras are not selectable for inclusion (same as Aliases and Wrappers). Aliases and Wrappers, however, are automatically included just fine.
Maybe this is the same problem others are having on the thread? As best as I can tell I have ffmpeg installed properly and am using the correct URLs for video and image streams.
Brian
Sun Dec 11, 2016 3:24 pm
Colorado4Wheeler offline
This appears normal to me:
It's precisely what I see on my load up. Bear in mind that HBB is doing nothing more than adding the lines to the configuration, it's not managing ffmpeg or Homebridge-Camera-FFMpeg, it's just a means to add the devices to the configuration. It could be that it just needs time to catch up like it did with blysik.
Sun Dec 11, 2016 4:12 pm
brlandy offline
It was my misunderstanding. I was expecting the devices to appear automatically in the default room (like adding a light), not as an accessory that needed to be added from "Add Accessory."
Tue Dec 20, 2016 4:42 pm
Ok, while the plugin still has the HB-Camera plugin support it will now ONLY use the manually installed version of HB as of RC6. In RC6 there is the "built in" HB that is for Indigo pretty much exclusively and you can still use your ~/.homebridge version for other stuff, including cameras.
Sun Feb 05, 2017 10:14 pm
echiang offline
With the new version of HBB with Homebridge built-in I have no problems with insteon/z-wave devices working with the IOS Home app and Siri. However, it's not clear to me how to setup IPCams. I can't get my IPcams working and I suspect I don't have the 2nd Homebridge setup correctly.
I have Indigo with HBB running on an old 2007 Core 2 Duo MacMini. I have a 2nd instance of Homebridge running on a 2010 Core i5 MacMini. FFMpeg is installed on this Core i5 MacMini as is homebridge-camera-ffmpeg. Also installed is Homebridge-magichome to control a Flux WiFi lightbulb. I know that Core I5's Homebridge is working since I can control the Flux WiFi in the IOS Home App and Siri.
I have 6 IPCams which I have define in the config.json on the Core I5. The Homebridge username and pin are slightly different than the username and pin used in HBB.
Questions:
Should this 2nd instance of Homebridge automatically be setup by HBB as an Indigo device or do I have to set it up in Indigo as a custom Homebridge setup? If it's automatically, then it's not showing up in Indigo. I do see the 2nd Homebridge in the IOS Home app.
Do I need to setup Homebridge-camera devices in Indigo? I can already see the IPcams as available devices in the IOS Home app. I did add one of the IPCams and the IOS Home app briefly connects to the IPCam since I can get snapshot of the video. However, there is no live video feed.
Any help is appreciated.
Ed
Thu Apr 20, 2017 12:27 am
haavarda offline
Just a little thing I have been thinking about as I am about to start to try to add camera to my homebridge install.
Has anyone tried to get a securityspy feed running with ffmpeg?
That would save a connection to my ip camera...
Håvard
Sun May 28, 2017 8:02 pm
@haavarda .. did you ever get it working with securityspy? I know I did back months ago.. but I’m not able to re-create my sucess from back then.. I can get the device to create but it doesn’t even connect to security spy I remember I did get it working and transcoding the video but for the love of me I just can’t get it to do it now. Im sure the url I used was of the format “http://user:pass@server.local/++hls?cameraNum=5&auth=TWlrZTpRaVeee2NzViekU= but doesn’t seem to give me joy now.
Sun May 28, 2017 10:06 pm
haavarda offline
Nope, never got it to work...
Håvard
Mon May 29, 2017 3:06 am
Bummer. Well I'll keep at it and I'll post when I find it again... if I do!
Wed Aug 30, 2017 5:43 am
qcvictor offline
Hi C4W
When I created the device for setup my cam, I'm unable to select the "homebridge server" do I need to create a new one ?
Wed Aug 30, 2017 9:18 am
You need to have a CUSTOM server for Camera to work in that version (I'm working on incorporating this into the build-in HB), so if you don't have the original Webdeck install of HB-indigo then you cannot add a camera.
Wed Aug 30, 2017 12:47 pm
qcvictor offline
EPS - Homebridge Buddy Error Unable to find '/Users/indigo/.homebridge', are you sure Homebridge is installed? Unable to save configuration
When you expect release this feature ?
Wed Aug 30, 2017 4:07 pm
The error you posted is precisely what I was saying, you need to have the Webdeck hand-installed version of HB installed, this would put the config in the ~/.homebridge folder and that's what is required for the camera.
I'll have an interim release in the next week or so for IOS 11, it MAY have camera support if I can get everything working.
Sat Jan 13, 2018 2:38 pm
martinc offline
Got a still shot working into HomeKit!
I am having trouble with the stream and I have used many of these without success;
http://www.ispyconnect.com/man.aspx?n=Foscam
Anyone have a working Foscam R2 stream?
Sat Jan 13, 2018 3:33 pm
You have it working with an HBB server or an HB server?
