- Posted on
Tue Dec 19, 2017 4:05 pm
Johnfowles
offline
Here are two log segments:
The first is after using the save and reload config, the second after reloading the plugin completely. In the first one, it never displays the ready to use message.
19 déc. 2017 à 23:02:26
EPS - Homebridge Buddy Building configuration for 'HomebridgeBuddy'
# SUMMARY #
# Devices for Homebridge to parse : 26 #
# Included devices that Homebridge can use : 11 #
# Devices over 99 that won't work : 0 #
EPS - Homebridge Buddy Debug {
"bridge": {
"name": "HomebridgeBuddy",
"username": "DD:22:3D:E3:CE:38",
"port": 51826,
"pin": "031-45-154"
"description": "Homebridge-Indigo configuration generated by EPS Homebridge Buddy on 2017-12-19 23:02:26 for device HomebridgeBuddy",
"platforms": [
"platform": "Indigo",
"protocol": "http",
"host": "127.0.0.1",
"port": "8176",
"path": "",
"username": "*****",
"password": "*****",
"includeActions": false,
"includeIds": ["39529999", "1857750551", "1722475616", "1353956685", "352841105", "1472567402", "1870001529", "1288948458", "29711212", "93816250", "1255257619"],
"treatAsSwitchIds": ["1722475616", "1288948458"],
"invertOnOffIds": ["1722475616"],
"thermostatsInCelsius": true,
"accessoryNamePrefix": ""
"accessories": [
EPS - Homebridge Buddy Debug Saving '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/homebridge/590842620/config.json'
EPS - Homebridge Buddy Warning Stopping the Homebridge server 'HomebridgeBuddy'
EPS - Homebridge Buddy Starting the Homebridge server 'HomebridgeBuddy', do not try to use Siri until you get a message that the server has started
19 déc. 2017 à 23:03:29
Reloading plugin "EPS - Homebridge Buddy 1.0.1"
Stopping plugin "EPS - Homebridge Buddy 1.0.1" (pid 38766)
Stopped plugin "EPS - Homebridge Buddy 1.0.1"
Starting plugin "EPS - Homebridge Buddy 1.0.1" (pid 38790)
EPS - Homebridge Buddy Debug Refreshing plugin information
Started plugin "EPS - Homebridge Buddy 1.0.1"
EPS - Homebridge Buddy Debug Adding HomebridgeBuddy to cache
EPS - Homebridge Buddy Debug Automatically adding watched device 'Chauffage' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Grille-pain' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Sapin' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Console' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Balustrade' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Facade' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Terrasse' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Buffet' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Lampadaire' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Table' to cache as a watched item
EPS - Homebridge Buddy Debug Automatically adding watched device 'Mediacenter ' to cache as a watched item
EPS - Homebridge Buddy EPS - Homebridge Buddy is loaded and ready to use
