Homebridge-Camera Device
Wed Dec 07, 2016 1:17 pm
Colorado4Wheeler offline
Re: Homebridge-Camera Device
Did you save your HBB configuration? Can you post your config.json contents?
Wed Dec 07, 2016 1:31 pm
Yeah saved it, also done it manually. Also added in the foscam feed and no change so looks like it's definitely my setup. Here's the contents:
   "bridge": {
      "name": "Server - Home Bridge",
      "username": "CC:22:3D:E3:CE:30",
      "port": 51826,
      "pin": "031-45-154"
   "description": "Homebridge-Indigo configuration generated by EPS Homebridge Companion on 2016-12-07 19:27:37 for device Server - Home Bridge",
   "platforms": [
         "platform": "Indigo",
         "protocol": "http",
         "host": "127.0.0.1",
         "port": "8080",
         "path": "",
         "username": "XXX",
         "password": "XXX",
         "includeActions": false,
         "includeIds": ["1747818794", "903409983", "1893185272", "136136704", "832644544", "1504274358", "1458472882", "1438736097", "1094631462", "1159431216", "1258203071", "118835937", "828126709", "1603291262", "1043566512", "1815938212", "1394633455", "1498113616", "349034576", "593139059", "806935063", "833541116", "640572580", "45084841", "722666402", "1504828744", "1678342115", "834967335", "1396191405", "518346600", "1851596327", "1392715560", "1320899512", "757234648", "1369527300", "1142787873", "109163097", "1414137297", "954622017", "1774424663", "1228943983", "1176322051", "1495173880", "1954335773", "48114592", "1537506722", "1325859424", "697909245", "1767498517", "768307754", "465349259", "1915866049", "180103134", "1715314285", "410653507", "1918773385", "1419287329", "1737320729", "946675027", "77828771", "32493139", "310068663", "844221872", "83629978", "484474353", "576516964", "272952928", "784430289", "1935638702", "63603030"],
         "treatAsSwitchIds": ["1747818794", "136136704", "1458472882", "1603291262", "349034576", "593139059", "1504828744", "834967335", "1851596327", "1320899512", "1774424663", "1228943983", "1495173880", "1954335773", "1715314285", "784430289"],
         "treatAsLockIds": ["1142787873", "1414137297", "32493139", "310068663"],
         "treatAsDoorIds": ["63603030"],
         "treatAsGarageDoorIds": ["1396191405"],
         "treatAsWindowIds": ["118835937"],
         "treatAsWindowCoveringIds": ["1094631462", "1258203071", "1815938212", "1498113616", "722666402", "757234648", "465349259", "410653507", "272952928"],
         "thermostatsInCelsius": true,
         "accessoryNamePrefix": ""
         "platform": "Camera-ffmpeg",
         "cameras": [
               "name": "Camera",
               "videoConfig": {
                  "source": "-re -i http://192.168.1.27/videostream.asf?usr=[admin]&pwd=[XXX]",
                  "stillImageSource": "-i http://my_camera_ip/optional_image_name.jpg",
                  "maxStreams": 2,
                  "maxWidth": 160,
                  "maxHeight": 320,
                  "maxFPS": 30
   "accessories": [
Wed Dec 07, 2016 1:38 pm
I have all of my Foscams set up and they are working quite well, I'm not sure why yours are not.
               "name": "Roving 2",
               "videoConfig": {
                  "source": "-re -i http://10.1.200.194/videostream.cgi?user=admin&pwd=XXX",
                  "stillImageSource": "-i http://10.1.200.194/snapshot.cgi?user=admin&pwd=XXX",
                  "maxStreams": 2,
                  "maxWidth": 160,
                  "maxHeight": 320,
                  "maxFPS": 30
Wed Dec 07, 2016 1:39 pm
Hold on, you don't have it as [admin] in that config do you? If so get rid of the brackets.
Wed Dec 07, 2016 1:41 pm
And configure the snapshot as well because that's what gives you the thumbnail in HomeKit.
No tried that already. Strangely in safari it works both with and without!
Wed Dec 07, 2016 1:47 pm
Ah I skipped over that as the npm documentation suggested it was optional.
Wed Dec 07, 2016 2:02 pm
Nope no joy. I'm perplexed. I'll try removing ffmpeg and the homebridge plugin and reinstall them, see if that helps.
I'm curious if someone else who has it working were to change their camera URL to an invalid address, does it still show up when you launch homebridge as an accessory?
Wed Dec 07, 2016 2:17 pm
I can tell you that it does, I went through several "try to break it" iterations and that was one of them.
I can also tell you that HBB is not the cause of the issue, it could be ffmpeg or homebridge-camera-ffmpeg but the plugin is only writing to the config file, nothing more.
Wed Dec 07, 2016 3:06 pm
Yeah that confirms what i feared!
oh of course, i wasn't implying that it was.. i'd actually tried setting this up the other day but had the same issue.. only reason i posted here is frankly this forum is full of nice helpful people. The internet is full of.. weirdos. ;)
Stripping and reinstalling didn't help. Very strange. Just like me!
Wed Dec 07, 2016 3:10 pm
What is the make and model of your camera?
Wed Dec 07, 2016 3:12 pm
In this case it's a Foscam 8918 but I don't think it's anything to do with the camera, it's not even getting as far as connecting.
Wed Dec 07, 2016 3:15 pm
8918 or 8918W?
Wed Dec 07, 2016 3:17 pm
8918E (PoE model)
Wed Dec 07, 2016 3:24 pm
Here are some variations to try and see which may work - the 8918 has several generations and they differ in their setup. Another thing I see is inconsistency in the query parameters, sometimes it's "&usr=" and sometimes "&user", also sometimes "&pwd" and sometimes "&password" (although it seems if it's "usr" then it's "pwd" and if it's "user" then it's "password").
"source": "-re -i http://192.168.1.27/video.cgi?usr=[admin]&pwd=[XXX]",
"source": "-re -i http://192.168.1.27/videostream.cgi?usr=[admin]&pwd=[XXX]",
"source": "-re -i http://192.168.1.27/video.cgi?user=[admin]& password =[XXX]",
"source": "-re -i http://192.168.1.27/videostream.cgi?user=[admin]&password=[XXX]",
If you are convinced it's RTSP (my documentation says it is not, but worth a try):
"source": "-re -i rtsp://192.168.1.27/videostream.asf?usr=[admin]&pwd=[XXX]",
"source": "-re -i rtsp://192.168.1.27/videostream.cgi?usr=[admin]&pwd=[XXX]",
"source": "-re -i rtsp://192.168.1.27/videostream.asf?user=[admin]& password =[XXX]",
"source": "-re -i rtsp://192.168.1.27/videostream.cgi?user=[admin]& password =[XXX]",
