- IndigoPluginDownload.png (14.88 KiB) Viewed 29408 times
IntroductionPlease note that this is BETA and while it's very stable please know that some functionality may be missing or incomplete - although it's been used in production by several users for months without too many issues. Also, the documentation is a work in progress, I'll be updating it as soon as possible.This allows you to have an IF-Then-Else command set within Indigo. It will dynamically read in the parameters of other plugins to try, to the best of it's ability, to allow you to use any method from either Indigo or other plugins to create a conditional statement.
As a BETA I have not yet gotten the documentation even begun yet, but it's pretty self explanatory. This is not a device, it's an action - so you can use this in triggers, schedules or action groups as you see fit. Since there was some recent demand for this plugin and it's been running in my system successfully for quite some time I figured I would go ahead and post it here as a BETA and let folks play with it.
Download and InstallationInstall
according to the Indigo documentation.
Download Plugin (GitHub) and extract the ZIP file.
Screen Shots
- Screen Shot 2017-01-03 at 9.58.33 AM.png (115.47 KiB) Viewed 29408 times
Configuration and UseNo documentation as of yet, just use this as an action in your triggers, actions groups or schedules (and yes, you can have this as a conditional trigger to provide even MORE conditions).
#Version|1.0#
