Battery Charting Script
Tue Jan 14, 2020 2:59 pm
McJohn offline
Re: Battery Charting Script
Thanks for the colorful information, great tool!
plt.figure(figsize=(0.5,0.5))
What is the smallest circle which could be made?
Because 0.1,01 give a square.
Tue Jan 14, 2020 3:37 pm
It's probably not a square per se; it's probably plotting a circle that's larger than the figure area.
If you reduce the figure size, you need to reduce the plot size too. Try playing with the s=300 bit.
Wed Jan 15, 2020 3:20 am
McJohn offline
Thanks for the hint!
Wed May 06, 2020 1:53 pm
mikkyo offline
I figured I'd try this, haven't done any scripting within Indigo yet..
Indigo 7.4.1
macOS Catalina 10.15.4
Created a New Schedule
Under Action Execute Script (Scripts and File Actions)
Copied the script from the git hub repo, tried it in an embedded script, got Invalid Syntax
Saved it to a file battery-charting-script.py in the /Library/Application Support/PerceptiveAutomation/Scripts, and choose it as the file to run, got
Script Error battery-charting-script.py: invalid syntax
Script Error around line 349 - "print(s, file=self.fileo)"
Wed May 06, 2020 2:14 pm
Indigo 7.4.1
Which script did you use? The one linked to in post 1 of this thread is only 143 lines long and I don't think it contains any print statements.
Thu May 07, 2020 3:47 pm
mikkyo offline
That one for the first post.
https://github.com/DaveL17/indigo-scrip ... -script.py
yes it is only 143 lines long, very confusing.
Thu May 07, 2020 7:27 pm
I think something strange may be happening with the code that you pasted into the script window. I just copied the script from Github into a new embedded script window, changed the image file save path to Indigo 7.4 for my version, and selected run. The script ran without error and generated an image file to the target folder. Try copying this script instead:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
    import sys
    import matplotlib.pyplot as plt
    import numpy as np
except ImportError, e:
    sys.exit(u"The matplotlib and numpy modules are required to use this script.")
# =================== User Settings ===================
output_file = '/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/battery_test.png'  # Indigo 7 installs
chart_title = 'Battery Health'
x_axis_title = ''
y_axis_title = ''
background_color = '#000000'
chart_height = 4.5
chart_width = 6
font_color = '#FFFFFF'
font_name = 'Lato Light'
font_size = 9
grid_color = '#888888'
grid_style = 'dotted'
show_data_labels = True
title_font_size = 9
battery_full_color = '#0000CC'
battery_caution_color = '#FFFF00'
battery_low_color = '#FF0000'
battery_caution_level = 10
battery_low_level = 5
# =================== kwarg Settings ===================
k_bar_fig = {'align': 'center',
             'alpha': 1.0,
             'height': 0.5,
             'zorder': 3
k_grid_fig = {'which': 'major',
              'color': grid_color,
              'linestyle': grid_style,
              'zorder': 0
k_plot_fig = {'bbox_extra_artists': None,
              'bbox_inches': 'tight',
              'dpi': 100,
              'edgecolor': background_color,
              'facecolor': background_color,
              'format': None,
              'frameon': None,
              'orientation': None,
              'pad_inches': 0.1,
              'papertype': None,
              'transparent': True,
k_title_fig = {'fontname': font_name,
               'fontsize': title_font_size,
               'color': font_color,
               'position': (0.35, 1.0)
bar_colors = []
device_dict = {}
x_values = []
y_values = []
# Create a dictionary of battery powered devices and their battery levels
    for dev in indigo.devices.itervalues():
        if dev.batteryLevel is not None:
            device_dict[dev.name] = dev.states['batteryLevel']
    if device_dict == {}:
        device_dict['No Battery Devices'] = 0
except Exception, e:
    indigo.server.log(u"Error reading battery devices: %s" % e)
# Parse the battery device dictionary for plotting.
    for key, value in sorted(device_dict.iteritems(), reverse=True):
            x_values.append(float(value))
        except ValueError:
            x_values.append(0)
        y_values.append(key.replace(' - ', '\n'))  # This line is specific to my install, as I name devices "Room - Device Name"
        # Create a list of colors for the bars based on battery health
            battery_level = float(value)
        except ValueError:
            battery_level = 0
        if battery_level <= battery_low_level:
            bar_colors.append(battery_low_color)
        elif battery_low_level < battery_level <= battery_caution_level:
            bar_colors.append(battery_caution_color)
            bar_colors.append(battery_full_color)
    indigo.server.log(u"Error parsing chart data: {0}".format(e))
# Create a range of values to plot on the Y axis, since we can't plot on device names.
y_axis = np.arange(len(y_values))
# Plot the figure
plt.figure(figsize=(chart_width, chart_height))
# Adding 1 to the y_axis pushes the bar to spot 1 instead of spot 0 -- getting it off the axis.
plt.barh((y_axis + 1), x_values, color=bar_colors, **k_bar_fig)
if show_data_labels:
    for ii in range(len(y_axis)):
        plt.annotate("%3d" % x_values[ii], xy=((x_values[ii] - 5), (y_axis[ii]) + 0.88), xycoords='data', textcoords='data', fontsize=font_size, color=font_color)
# Chart
plt.title(chart_title, **k_title_fig)
plt.grid(**k_grid_fig)
# X Axis
plt.xticks(fontsize=font_size, color=font_color)
plt.xlabel(x_axis_title, fontsize=font_size, color=font_color)
plt.gca().xaxis.grid(True)
plt.xlim(xmin=0, xmax=100)
# Y Axis
# The addition of 0.05 to the y_axis better centers the labels on the bars
# (for 2-line labels.) For 1 line labels, change 1.05 to 1.0.
plt.yticks((y_axis + 1.05), y_values, fontsize=font_size, color=font_color)
plt.ylabel(y_axis_title, fontsize=font_size, color=font_color)
plt.gca().yaxis.grid(False)
plt.ylim(ymin=0)
# Output the file
plt.savefig(output_file, **k_plot_fig)
plt.close()
Fri May 08, 2020 4:12 pm
mikkyo offline
Got the same error,
Maybe something to do with how Indigo is mapping running scripts in python and outputting the error info?
Fri May 08, 2020 4:26 pm
What version of Indigo are you running?
Also, please provide the entire error message. There's no print statement in the script, so I need more to go on.
Fri May 08, 2020 8:20 pm
mikkyo offline
I think I figured it out..
leftover file from homebrew.
~/Library/Python/2.7/lib/python/site-packages /homebrew.pth
Removed that and it is working!
Now that I get an image, I assume I have to add a Control Page that uses that image or something?
Fri May 08, 2020 9:56 pm
Glad to hear you were able to find the cause of the problem. I would likely have never been able to figure out Homebrew was the culprit.
The purpose of the script is to generate an image for control pages, but that's not necessarily the only way to use the product of the script. For example, you could add the image as a shortcut to Safari (for periodic inspection), or email the image to yourself every so often using the Better Email plugin.
Thu Sep 02, 2021 12:55 pm
pxzel offline
Edited: Whats the best way to get the script results (png) automatically sent through email?
Figured it out.... easy as drag and drop file location to email attachment entry.
Thu Sep 02, 2021 2:01 pm
Glad you were able to figure it out.
[Weirdly, I didn't get a notice of the post at 1:55 CT, but I did get one at 2:45 CT--presumably when you edited your original post.]
Sat Sep 04, 2021 1:32 pm
ryanbuckner offline
This worked for me right out of the box. I just updated for 2021.1 path
1 question, what if I wanted to sort the order by battery level low --> high ?
Sat Sep 04, 2021 1:57 pm
ryanbuckner offline
I was able to achieve this by editing 1 line:
    for key, value in sorted(device_dict.iteritems(), key = lambda x : x[1], reverse=True):   # Edited this line to sort by battery level value
