Battery Charting Script
Sun Jun 19, 2016 4:15 am
Re: Battery Charting Script
Request:
Can someone with a battery-powered Insteon device please run the following script against one device and post (or PM) the result?
Thanks.
Dave
dev = indigo.devices[DEVICE ID GOES HERE]
indigo.server.log(unicode(dev))
Sun Jun 19, 2016 5:41 am
jalves offline
deleted. thought you asked for z-wave. Will be back with correct info shortly. ;)
Jeff
Sun Jun 19, 2016 5:45 am
jalves offline
OK, here is the output from an Insteon motion sensor:
  Script                          address : 23.24.0A
allowOnStateChange : True
allowSensorValueChange : False
batteryLevel : None
buttonGroupCount : 3
configured : True
description : Motion Sensor in Jeff's Closet
deviceTypeId :
displayStateId : onOffState
displayStateImageSel : MotionSensor
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1937631029
lastChanged : 2016-06-19 06:23:07
model : Motion Sensor
name : Jeff Closet Motion Sensor
onState : False
pluginId :
protocol : Insteon
remoteDisplay : True
sensorValue : None
states : States : (dict)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : 65
Jeff
Sun Jun 19, 2016 6:36 am
There's the trouble. The device is reporting a batteryLevel: None. I don't see anything in that dict that shows the status of the battery. I'll do a bit more digging to see if there's a way to check the battery level of Insteon devices in some universal way.
Thanks for the help.
Dave
Sun Jun 19, 2016 6:48 am
Sun Jun 19, 2016 2:53 pm
I don't believe there are any Insteon devices that actually report battery level. Mostly they have a special group that turns on when the battery gets low.
Mon Jul 11, 2016 7:49 pm
Moderator's Note: Moved to the Dave's Scripts forum.
Sun Nov 13, 2016 8:47 am
Bollar offline
Don't forget to change that path to Indigo 7. :D
Sun Nov 13, 2016 9:35 am
Done!
Thanks for the reminder.
Mon Jan 13, 2020 9:45 am
McJohn offline
Thanks for this nice script. Works perfect!
Is it possible to make a script per selected Indigo device?
For example only for the battery level of 1 motion sensor in the main control page?
(with nice green status leds :D ) , like the device details in the Indigo Device window)
Kind regards,
John
Mon Jan 13, 2020 11:38 am
Glad the script is working for you.
Unfortunately, there's no easy way to do what you want with the existing script. But I whipped together a silly script that should get pretty close to what you want. You'll need to customize it for each device (device ID, image file name, etc.). You can also customize the various cut-offs for the color of the image if you like. It places the resulting image file into the static images folder.
import matplotlib.pyplot as plt
image_name = 'circle'
dev = indigo.devices[557779026]
battery_level = dev.states['batteryLevel']
path_name = indigo.server.getInstallFolderPath()
if battery_level <= 5:
   indicator = 'red'
elif battery_level <= 10:
   indicator = 'yellow'
   indicator = 'green'
plt.figure(figsize=(0.5,0.5))
plt.scatter(3, 9, s=300, color=indicator)
plt.axis('off')
plt.savefig('{0}/IndigoWebServer/images/controls/static/{1}.png'.format(path_name, image_name), transparent=True)
Mon Jan 13, 2020 12:17 pm
McJohn offline
Thank you so much for the fast feedback!
We shall give it a try.
PS: works perfect! beautiful yellow circle! :D
Thumbs up!
Mon Jan 13, 2020 1:12 pm
Glad to be of help.
Cheers!
Tue Jan 14, 2020 9:51 am
McJohn offline
Tue Jan 14, 2020 10:31 am
McJohn wrote:
FYI, Matplotlib will also accept hex color codes as strings. For example,
Red = '#FF0000'
Green = '#00FF00'
Blue = '#0000FF'
White = '#FFFFFF'
Black = '#000000'
Greys = '#111111' - '#999999'
Using hex gives access to all 16.7 million colors. You can use the Mac Colors picker (for example through my Multitool plugin) which will show you the hex value of any color you choose. Using hex is my preference.
Screen Shot 2020-01-14 at 10.28.40 AM.png (54.55 KiB) Viewed 12557 times
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
