Gnuplot Scripts
Sat Jan 16, 2016 10:44 am
Re: Gnuplot Scripts
Hmmm. I'm afraid that I'm out at this point. You might want to hit the Googles to find out how to install legacy versions of this stuff (if it's even still possible.)
I'm behind the curve while running OS X 10.9.5 and Gnuplot 5.0.0 and, since everything seems to be quite stable and working the way that I want it to, I'm hesitant to change anything! :)
Dave
Sat Jan 16, 2016 10:56 am
ckeyes888 offline
Re: Gnuplot Scripts
Gotcha, thanks. Must be something out there....
Carl
Sat Jan 16, 2016 11:00 am
Re: Gnuplot Scripts
Good luck!
Dave
Mon Jan 18, 2016 1:09 pm
ckeyes888 offline
Re: Gnuplot Scripts
Well, definitely almost got it working. This script now draws the attached image.
It's missing the filled in areas beneath the temps.
#! /usr/bin/env gnuplot
# -*- coding: utf-8 -*-
reset
set terminal pngcairo enhanced background "#000000" font "Lato-Light,16" linewidth 2 rounded size 800,400
set output "/Users/TV/10DayForecast.png"
dataFileForecast = "/Users/TV/10DayForecast.csv"
set datafile separator ','
set timefmt "%Y-%m-%d"
stats dataFileForecast using 2:4 nooutput
freezeWarning = 32.
Yhigh = STATS_max_x + 10.
Ylow = STATS_min_y - 10.
freezeLabel = ((freezeWarning-Ylow) / (Yhigh-Ylow))
unset key
set border linetype rgb "#666666"
set boxwidth 0.25 relative
set style fill transparent solid 0.4
set style line 1 linetype rgb "#0066CC"
set style line 2 linetype rgb "#FFFFFF" pointtype 14 pointsize 2
set style line 3 linetype rgb "#666666"
set style line 4 linetype rgb "#FFFF00"
set style line 5 linetype rgb "#333333"
set label "°" right
unset mxtics
set tics textcolor rgb "#666666"
# X Axis
set xdata time
set xtics format "%a" nomirror
set autoscale xfix
set offsets 12*60*60,12*60*60,0,0
# Y Axis
set ytics format "%2f°" nomirror
set yrange [Ylow:Yhigh]
unset ytics
if (32 > Ylow) set label "32°" at graph 0.01,freezeLabel tc rgb "#FFFFFF" font ",10"
# Y2 Axis
set y2tics format "%2.0f%%" nomirror
set y2range [0:100]
plot dataFileForecast using 1:2 with filledcurves above y1=0,\
     dataFileForecast using 1:2:3 with labels textcolor rgb "#FFFFFF",\
     dataFileForecast using 1:4 with filledcurves above y1=0,\
     dataFileForecast using 1:4:5 with labels textcolor rgb "#FFFFFF",\
     dataFileForecast using 1:6 with impulses,\
     freezeWarning with filledcurves above y1=0 linecolor rgb "#0066CC"
I did install Cairo which I guessing is required for this type of chart.
Any idea what might have changed?
Carl
10DayForecast copy.png (26.27 KiB) Viewed 6657 times
Mon Jan 18, 2016 1:21 pm
Re: Gnuplot Scripts
Try making the temperature lines look more like the freezewarning line.
This:
plot dataFileForecast using 1:2 with filled curves above y1=0 linecolor "#333333" ,\
     dataFileForecast using 1:4 with filledcurves above y1=0 linecolor "#666666",\
Instead of this:
And so on.
Dave
Mon Jan 18, 2016 1:55 pm
ckeyes888 offline
Re: Gnuplot Scripts
I replaced that section of code but the result is a blank image.
reset
freezeWarning = 32.
unset key
set label "°" right
unset mxtics
# X Axis
set xdata time
set autoscale xfix
# Y Axis
unset ytics
# Y2 Axis
set y2range [0:100]
Carl
Mon Jan 18, 2016 2:10 pm
Re: Gnuplot Scripts
Gnuplot may be angry because there is an extra space at the end of the first plot line (between the double quote and the ,\ )
Dave
Mon Jan 18, 2016 2:15 pm
ckeyes888 offline
Re: Gnuplot Scripts
Fixed that and got a chart back but it's identical to the original issue.
Edit: Correction, must have been a cached image. Still a blank.
Carl
Mon Jan 18, 2016 4:42 pm
Re: Gnuplot Scripts
Missed it before.....on the first plot line "filled curves" should be "filledcurves".
Dave
Mon Jan 18, 2016 4:53 pm
ckeyes888 offline
Re: Gnuplot Scripts
That fix got the image back but unfortunately it still has no filled
areas below the temps.
plot dataFileForecast using 1:2 with filledcurves above y1=0 linecolor "#333333",\
Really appreciate the help Dave.
Carl
Mon Jan 18, 2016 5:54 pm
Re: Gnuplot Scripts
It does for me; I suspect that there may be an issue with your terminal or with your version of Gnuplot.
Mon Jan 18, 2016 6:10 pm
ckeyes888 offline
Re: Gnuplot Scripts
No doubt you're right.
Thanks again for all the help!
Carl
Wed Jan 20, 2016 7:36 am
afulki offline
Re: Gnuplot Scripts
To get the fill I had to add (0)in the script:
plot dataFileForecast using 1:6 with impulses linestyle 4 axes x1y2,\
dataFileForecast using 1:2:(0) with filledcurves above y1=0 linestyle 5 axes x1y1,\
dataFileForecast using 1:2 with points linestyle 2 axes x1y1,\
dataFileForecast using 1:2:3 with labels offset 1.75,0.5 textcolor "#FFFFFF" font ",8" axes x1y1,\
dataFileForecast using 1:4:(0) with filledcurves above y1=0 linestyle 3 axes x1y1,\
dataFileForecast using 1:4 with points linestyle 2 axes x1y1,\
dataFileForecast using 1:4:5 with labels offset 1.75,0.5 textcolor "#FFFFFF" font ",8" axes x1y1,\
freezeWarning with filledcurves above y1=0 linestyle 1 axes x1y1
Any possibility of having the python script for the 24 hour forecast (write to csv) posted? (or did I miss it somewhere)
Wed Jan 20, 2016 8:46 am
Re: Gnuplot Scripts
Thanks for figuring this out. Here's my 24 hour forecast python script:
#! /usr/bin/env python2.6
filename: hourlyForecast.py
This file generates the necessary CSV file for charting the hourly
forecast. It plots the next 24 values for each data element.
import os.path
from os import system
import subprocess
csv_file_path   = '/Users/.../Dropbox/Public/hourlyForecast.csv'
path_to_gnuplot = '/opt/local/bin/gnuplot /Users/.../Dropbox/Indigo\ Scripts/'
dev             = indigo.devices[1322999615]
date_time       = str(indigo.server.getTime())
hour_1    = str(dev.states["h01_timeLong"])
hour_2    = str(dev.states["h02_timeLong"])
hour_3    = str(dev.states["h03_timeLong"])
hour_4    = str(dev.states["h04_timeLong"])
hour_5    = str(dev.states["h05_timeLong"])
hour_6    = str(dev.states["h06_timeLong"])
hour_7    = str(dev.states["h07_timeLong"])
hour_8    = str(dev.states["h08_timeLong"])
hour_9    = str(dev.states["h09_timeLong"])
hour_10   = str(dev.states["h10_timeLong"])
hour_11   = str(dev.states["h11_timeLong"])
hour_12   = str(dev.states["h12_timeLong"])
hour_13   = str(dev.states["h13_timeLong"])
hour_14   = str(dev.states["h14_timeLong"])
hour_15   = str(dev.states["h15_timeLong"])
hour_16   = str(dev.states["h16_timeLong"])
hour_17   = str(dev.states["h17_timeLong"])
hour_18   = str(dev.states["h18_timeLong"])
hour_19   = str(dev.states["h19_timeLong"])
hour_20   = str(dev.states["h20_timeLong"])
hour_21   = str(dev.states["h21_timeLong"])
hour_22   = str(dev.states["h22_timeLong"])
hour_23   = str(dev.states["h23_timeLong"])
hour_24   = str(dev.states["h24_timeLong"])
temp_1    = str(int(dev.states["h01_temp"]))
temp_2    = str(int(dev.states["h02_temp"]))
temp_3    = str(int(dev.states["h03_temp"]))
temp_4    = str(int(dev.states["h04_temp"]))
temp_5    = str(int(dev.states["h05_temp"]))
temp_6    = str(int(dev.states["h06_temp"]))
temp_7    = str(int(dev.states["h07_temp"]))
temp_8    = str(int(dev.states["h08_temp"]))
temp_9    = str(int(dev.states["h09_temp"]))
temp_10   = str(int(dev.states["h10_temp"]))
temp_11   = str(int(dev.states["h11_temp"]))
temp_12   = str(int(dev.states["h12_temp"]))
temp_13   = str(int(dev.states["h13_temp"]))
temp_14   = str(int(dev.states["h14_temp"]))
temp_15   = str(int(dev.states["h15_temp"]))
temp_16   = str(int(dev.states["h16_temp"]))
temp_17   = str(int(dev.states["h17_temp"]))
temp_18   = str(int(dev.states["h18_temp"]))
temp_19   = str(int(dev.states["h19_temp"]))
temp_20   = str(int(dev.states["h20_temp"]))
temp_21   = str(int(dev.states["h21_temp"]))
temp_22   = str(int(dev.states["h22_temp"]))
temp_23   = str(int(dev.states["h23_temp"]))
temp_24   = str(int(dev.states["h24_temp"]))
precip_1  = str(int(dev.states["h01_precip"]))
precip_2  = str(int(dev.states["h02_precip"]))
precip_3  = str(int(dev.states["h03_precip"]))
precip_4  = str(int(dev.states["h04_precip"]))
precip_5  = str(int(dev.states["h05_precip"]))
precip_6  = str(int(dev.states["h06_precip"]))
precip_7  = str(int(dev.states["h07_precip"]))
precip_8  = str(int(dev.states["h08_precip"]))
precip_9  = str(int(dev.states["h09_precip"]))
precip_10 = str(int(dev.states["h10_precip"]))
precip_11 = str(int(dev.states["h11_precip"]))
precip_12 = str(int(dev.states["h12_precip"]))
precip_13 = str(int(dev.states["h13_precip"]))
precip_14 = str(int(dev.states["h14_precip"]))
precip_15 = str(int(dev.states["h15_precip"]))
precip_16 = str(int(dev.states["h16_precip"]))
precip_17 = str(int(dev.states["h17_precip"]))
precip_18 = str(int(dev.states["h18_precip"]))
precip_19 = str(int(dev.states["h19_precip"]))
precip_20 = str(int(dev.states["h20_precip"]))
precip_21 = str(int(dev.states["h21_precip"]))
precip_22 = str(int(dev.states["h22_precip"]))
precip_23 = str(int(dev.states["h23_precip"]))
precip_24 = str(int(dev.states["h24_precip"]))
csv_file = open(csv_file_path, "w")
element = (
    hour_1  + "," + temp_1  + "," + precip_1  + "," + temp_1  + "°\n" +
    hour_2  + "," + temp_2  + "," + precip_2  + "," + temp_2  + "°\n" +
    hour_3  + "," + temp_3  + "," + precip_3  + "," + temp_3  + "°\n" +
    hour_4  + "," + temp_4  + "," + precip_4  + "," + temp_4  + "°\n" +
    hour_5  + "," + temp_5  + "," + precip_5  + "," + temp_5  + "°\n" +
    hour_6  + "," + temp_6  + "," + precip_6  + "," + temp_6  + "°\n" +
    hour_7  + "," + temp_7  + "," + precip_7  + "," + temp_7  + "°\n" +
    hour_8  + "," + temp_8  + "," + precip_8  + "," + temp_8  + "°\n" +
    hour_9  + "," + temp_9  + "," + precip_9  + "," + temp_9  + "°\n" +
    hour_10 + "," + temp_10 + "," + precip_10 + "," + temp_10 + "°\n" +
    hour_11 + "," + temp_11 + "," + precip_11 + "," + temp_11 + "°\n" +
    hour_12 + "," + temp_12 + "," + precip_12 + "," + temp_12 + "°\n" +
    hour_13 + "," + temp_13 + "," + precip_13 + "," + temp_13 + "°\n" +
    hour_14 + "," + temp_14 + "," + precip_14 + "," + temp_14 + "°\n" +
    hour_15 + "," + temp_15 + "," + precip_15 + "," + temp_15 + "°\n" +
    hour_16 + "," + temp_16 + "," + precip_16 + "," + temp_16 + "°\n" +
    hour_17 + "," + temp_17 + "," + precip_17 + "," + temp_17 + "°\n" +
    hour_18 + "," + temp_18 + "," + precip_18 + "," + temp_18 + "°\n" +
    hour_19 + "," + temp_19 + "," + precip_19 + "," + temp_19 + "°\n" +
    hour_20 + "," + temp_20 + "," + precip_20 + "," + temp_20 + "°\n" +
    hour_21 + "," + temp_21 + "," + precip_21 + "," + temp_21 + "°\n" +
    hour_22 + "," + temp_22 + "," + precip_22 + "," + temp_22 + "°\n" +
    hour_23 + "," + temp_23 + "," + precip_23 + "," + temp_23 + "°\n" +
    hour_24 + "," + temp_24 + "," + precip_24 + "," + temp_24 + "°")
csv_file.write(element)
csv_file.close()
proc = subprocess.Popen(path_to_gnuplot + 'hourlyForecast.gp', stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
out, err = proc.communicate()
if len(err) >= 1:
    self.errorLog(u"hourlyForecast.py: error = %s" % err)
    indigo.server.log(u"hourlyForecast.py: Hourly forecast charts data updated.")
It's also still awfully literal at this point. While this helps to make it easy to understand, from an elegance standpoint, a 1-24 counter would reduce the lines needed.
Dave
EDIT: "I'll probably update mine to remove the reference to the shell in the Curl command as I don't think it's needed here." Scratch that. Removing the shell reference causes the script to bomb.
Wed Jan 20, 2016 10:26 am
afulki offline
Re: Gnuplot Scripts
Thanks Dave,
one more fix :) if you change points to linespoints you get the solid line above the fill
e.g.
this dataFileForecast using 1:4 with points linestyle 2 axes x1y1,\
to dataFileForecast using 1:4 with linespoints linestyle 2 axes x1y1,\
