Gnuplot Scripts
Mon May 18, 2015 7:06 pm
Re: Gnuplot Scripts
No problem!
I forgot to change the textcolor. (Also, there was a typo which I have fixed as well.)
#! /usr/bin/env gnuplot
# -*- coding: utf-8 -*-
reset
set terminal pngcairo enhanced background "#000000" font "Lato-Light,9" linewidth 1 rounded size 600,200
set output "/Users/TV/10DayForecast.png"
dataFileForecast = "/Users/TV/10DayForecast.csv"
set datafile separator ','
set timefmt "%Y-%m-%d"
stats dataFileForecast using 2:4 nooutput
freezeWarning = 32.
Yhigh = STATS_max_x + 10.
Ylow = STATS_min_y - 10.
freezeLabel = ((freezeWarning-Ylow) / (Yhigh-Ylow))
unset key
set border linetype rgb "#666666"
set boxwidth 0.25 relative
set style fill transparent solid 0.4
set style line 1 linetype rgb "#0066CC"
set style line 2 linetype rgb "#FFFFFF" pointtype 7 pointsize .5
set style line 3 linetype rgb "#666666"
set style line 4 linetype rgb "#FFFF00"
set style line 5 linetype rgb "#333333"
set label "°" right
unset mxtics
set tics textcolor rgb "#666666"
# X Axis
set xdata time
set xtics format "%a" nomirror
set autoscale xfix
set offsets 12*60*60,12*60*60,0,0
# Y Axis
set ytics format "%2f°" nomirror
set yrange [Ylow:Yhigh]
unset ytics
if (32 > Ylow) set label "32°" at graph 0.01,freezeLabel tc rgb "#FFFFFF" font ",8"
# Y2 Axis
set y2tics format "%2.0f%%" nomirror
set y2range [0:100]
plot dataFileForecast using 1:2 with lines,\
    dataFileForecast using 1:2:3 with labels texcolor rgb "white",\
     dataFileForecast using 1:4 with lines,\
     dataFileForecast using 1:2:5 with labels textcolor rgb "white",\
     freezeWarning with lines
Mon May 18, 2015 7:07 pm
Re: Gnuplot Scripts
No problem!
reset
freezeWarning = 32.
unset key
set label "°" right
unset mxtics
# X Axis
set xdata time
set autoscale xfix
# Y Axis
unset ytics
# Y2 Axis
set y2range [0:100]
    dataFileForecast using 1:2:3 with labels texcolor rgb "#FFFFFF",\
     dataFileForecast using 1:2:5 with labels textcolor rgb "#FFFFFF",\
Mon May 18, 2015 7:08 pm
ckeyes888 offline
Re: Gnuplot Scripts
Think we lost a line.
Carl
Mon May 18, 2015 7:11 pm
Re: Gnuplot Scripts
Yet another typo on my part, sorry!
reset
freezeWarning = 32.
unset key
set label "°" right
unset mxtics
# X Axis
set xdata time
set autoscale xfix
# Y Axis
unset ytics
# Y2 Axis
set y2range [0:100]
    dataFileForecast using 1:2:3 with labels textcolor rgb "#FFFFFF",\
Mon May 18, 2015 7:15 pm
ckeyes888 offline
Re: Gnuplot Scripts
Numbers!
Highs and lows on top of each other?
Mon May 18, 2015 7:19 pm
Re: Gnuplot Scripts
See that second to last line? Change "1:2:5" to "1:4:5". :D
Mon May 18, 2015 7:23 pm
ckeyes888 offline
Re: Gnuplot Scripts
Looking great. Any way to have that cool fill?
Carl
Mon May 18, 2015 7:33 pm
Re: Gnuplot Scripts
You have Gnuplot 4.6 I believe, so it should be possible.
Try replacing the last line with this and let's see what we get.
freezeWarning with filledcurves above y1=0
Mon May 18, 2015 7:35 pm
ckeyes888 offline
Re: Gnuplot Scripts
Better.
Mon May 18, 2015 7:43 pm
Re: Gnuplot Scripts
That's terrific. Are you seeing how this is coming together? The tweaking is easier now.
Let's replace the entire plot segment with this:
plot dataFileForecast using 1:2 with filledcurves above y1=0,\
     dataFileForecast using 1:4 with filledcurves above y1=0,\
Mon May 18, 2015 7:47 pm
ckeyes888 offline
Re: Gnuplot Scripts
Looks great to me. Hate to take up anymore of your time.
Carl
edit: Precip lines?
Mon May 18, 2015 8:00 pm
Re: Gnuplot Scripts
Truly not a problem. Don't worry about that at all! :D
     dataFileForecast using 1:4:5 with labels textcolor rgb "#FFFFFF",\
     dataFileForecast using 1:6 with impulses,\
Completely happy to continue with the help; I'm hoping that the thread will provide help to others, too!
Dave
Mon May 18, 2015 8:08 pm
ckeyes888 offline
Re: Gnuplot Scripts
Maybe one last tweek?
If the bottom fill could stay the cool blue for below 32 that would be perfect.
edit: I adjusted the sizing a bit.
Carl
Mon May 18, 2015 8:24 pm
Re: Gnuplot Scripts
You can change the colors any way you like!
line color:
linecolor rgb "#FFFFFF"
text color:
All you need to do is change the RGB value to whatever color you like.
http://www.colorpicker.com/
We haven't specified a linecolor, so Gnuplot is picking for us. To change that, all we need to do is ask, by adding it to the proper line (in this case, the last one):
     freezeWarning with filledcurves above y1=0 linecolor rgb "#0066CC"
Mon May 18, 2015 8:43 pm
ckeyes888 offline
Re: Gnuplot Scripts
Love it Dave! Working on the CP for it now.
Many thanks again, I do hope you're right in that others find it useful.
Carl
Page 4 of 10 1, 2, 3, 4, 5, 6, 7 ... 10
