Battery Charting Script
Thu Apr 14, 2016 10:22 am
Re: Battery Charting Script
matt (support) wrote:
Great script!
Thanks Matt!
Thu Apr 14, 2016 10:27 am
Different Computers wrote:
This is pretty amazing work.
Do I have this right that I can just schedule Indigo to run this script in the middle of the night and it's done? Nothing else to install on a Mac running El Capitan?
Thanks for the kind words.
Yes; that's what I do. I run it only once per day because I figure that battery levels aren't changing that much each day. I combine it with another script that emails me a list of only those devices that fall below a set percentage which helps me remember to keep after replacing batteries.
The best way to tell whether you can run the script natively (I recommend using a linked script rather than embedding it) is to open an Indigo scripting shell from the plugins menu and trying to import the two key modules. If you can do this without throwing errors, then you should be fine. It will likely take some tweaking of the settings to work best for each install--number of devices, etc. I might add that I think its best to do this from the Indigo shell because a basic Terminal shell might use different paths depending on your setup.
import matplotlib
import numpy
Dave
Thu Apr 14, 2016 11:08 am
Different Computers offline
OK, that was freakin' amazing.
Never run a python script in my life before.
Tested matplotlib & numpy per your instructions, no problem.
copied script into pico, wrote it out as a .py file.
Pointed Indigo at it, ran it as a test.
Opened a control page, scrolled through the static images and THERE IT IS. Found all my battery devices perfectly. Tremendous. Thank you very much.
Thu Apr 14, 2016 11:13 am
Just wait. Once you get started with this stuff, you won't be able to stop.
The power is intoxicating....
Thu Apr 14, 2016 11:15 am
I'm sure.
But I'm still very much a copypasta, and a long long way away from trying to write any python myself. AppleScript, on the other hand...
Nah, there are a bunch of great ApplesScripts out there, it will be months before I'm doing more than copy/pasting those too.
Thu Apr 14, 2016 12:29 pm
Bite the bullet and learn Python (once you get ready to start writing scripts rather than copy/pasting). It's not hard, and it's MUCH better in almost every respect than AppleScript.
Fri Apr 15, 2016 9:26 am
stuartcolman offline
I have setup the script to run once an hour, however I am just getting a blank chart. Furthermore I am getting the following error in the event log:
Error parsing chart data: empty string for float()
I am also using the piBeacons plugin which appears to register the beacon devices with a battery, however these devices don't have a battery level, not even 0%. Is there a way to exclude devices based on their ID from being counted in this script?
Stuart
Fri Apr 15, 2016 11:32 am
This should be a pretty easy fix. Does it give you a line number with the error?
Fri Apr 15, 2016 11:39 am
No unfortunately not. The line is 'as is' from the event log.
Fri Apr 15, 2016 11:56 am
Thanks. That's a result of inferior code writing.
Fri Apr 15, 2016 12:10 pm
I have posted a new version of the script which coerces a battery level of zero for those devices that report a battery level as an empty string. This is a short-term fix.
For those that have devices that will always report as an empty string -- and thus you don't want them to appear on the chart -- look for the block of code that looks like this:
    for dev in indigo.devices.itervalues():
        if dev.batteryLevel is not None:
            device_dict[dev.name] = dev.states['batteryLevel']
and change it to this:
        if dev.batteryLevel is not None and dev.batteryLevel is not "":
and see if that works to your liking. I can't test the code as I don't have devices that meet the criteria. Also, I'm hesitant to add this to the "official" script until we get a sense of the consequences for the change (some folks may want these devices reflected...)
Cheers,
Dave
Fri Apr 15, 2016 12:12 pm
Thanks for the quick response. I'll give it a try and feedback.
Fri Apr 15, 2016 1:24 pm
Code changed and still get the same result.
Stuart
Fri Apr 15, 2016 2:30 pm
Hi Stuart - I'm just trying to understand what you're seeing--did you change to the code that's listed in the first post to this thread?
Fri Apr 15, 2016 4:03 pm
I used the original code from the very first post of the thread, and then made the changes you just mentioned:
#! /usr/bin/env python2.6
# -*- coding: utf-8 -*-
    import sys
    import matplotlib.pyplot as plt
    import numpy as np
except ImportError, e:
    sys.exit(u"The matplotlib and numpy modules are required to use this script.")
# =================== User Settings ===================
output_file = '/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/controls/static/battery_test.png'
chart_title = 'Battery Health'
x_axis_title = ''
y_axis_title = ''
background_color = '#000000'
chart_height = 4.5
chart_width = 6
font_color = '#FFFFFF'
font_name = 'Lato Light'
font_size = 9
grid_color = '#888888'
grid_style = 'dotted'
show_data_labels = True
title_font_size = 9
battery_full_color = '#0000CC'
battery_caution_color = '#FFFF00'
battery_caution_level = 10
battery_low_color = '#FF0000'
battery_low_level = 5
# =================== kwarg Settings ===================
k_bar_fig = {'align': 'center',
             'alpha': 1.0,
             'height': 0.5,
             'zorder': 3
k_grid_fig = {'which': 'major',
              'color': grid_color,
              'linestyle': grid_style,
              'zorder': 0
k_plot_fig = {'bbox_extra_artists': None,
              'bbox_inches': 'tight',
              'dpi': 100,
              'edgecolor': background_color,
              'facecolor': background_color,
              'format': None,
              'frameon': None,
              'orientation': None,
              'pad_inches': 0.1,
              'papertype': None,
              'transparent': True,
k_title_fig = {'fontname': font_name,
               'fontsize': title_font_size,
               'color': font_color,
               'position': (0.35, 1.0)
bar_colors = []
device_dict = {}
x_values = []
y_values = []
# Create a dict of battery powered devices and their battery levels
    if device_dict == {}:
        device_dict['No Battery Devices'] = '0'
except Exception, e:
    indigo.server.log(u"Error reading battery devices: %s" % e)
# Parse the battery device dict into X and Y values
    for key, value in sorted(device_dict.iteritems(), reverse=True):
        x_values.append(float(value))
        y_values.append(key.replace(' - ', '\n'))  # This line is specific to my install, as I name devices "Room - Device Name"
        # Create a list of colors for the bars based on battery health
        battery_level = float(value)
        if battery_level <= battery_low_level:
            bar_colors.append(battery_low_color)
        elif battery_low_level < battery_level <= battery_caution_level:
            bar_colors.append(battery_caution_color)
            bar_colors.append(battery_full_color)
    indigo.server.log(u"Error parsing chart data: %s" % e)
# Create a list of values to plot on the Y axis, since we can't plot on device names.
y_axis = np.arange(len(y_values))
# Plot the figure
plt.figure(figsize=(chart_width, chart_height))
# Adding 1 to the y_axis pushes the bar to spot 1 instead of spot 0 -- getting it off the axis.
plt.barh((y_axis + 1), x_values, color=bar_colors, **k_bar_fig)
if show_data_labels:
    for ii in range(len(y_axis)):
        plt.annotate("%3d" % x_values[ii], xy=((x_values[ii] - 5), (y_axis[ii]) + 0.88), xycoords='data', textcoords='data', fontsize=font_size, color=font_color)
# Chart
plt.title(chart_title, **k_title_fig)
plt.grid(**k_grid_fig)
# X Axis
plt.xticks(fontsize=font_size, color=font_color)
plt.xlabel(x_axis_title, fontsize=font_size, color=font_color)
plt.gca().xaxis.grid(True)
plt.xlim(xmin=0, xmax=100)
# Y Axis
# The addition of 0.05 to the y_axis better centers the labels on the bars
# (for 2-line labels.) For 1 line labels, change 1.07 to 1.0.
plt.yticks((y_axis + 1.05), y_values, fontsize=font_size, color=font_color)
plt.ylabel(y_axis_title, fontsize=font_size, color=font_color)
plt.gca().yaxis.grid(False)
plt.ylim(ymin=0)
# Output the file
plt.savefig(output_file, **k_plot_fig)
plt.close()
Page 3 of 8 1, 2, 3, 4, 5, 6 ... 8
