HomeKit Scene Requires Two Taps
Tue Sep 21, 2021 10:46 am
ryandenver offline
Greetings
Is anyone else seeing this behavior in scenes created in HomeKit that include Insteon dimmers.
1) Scene created with multiple dimmers with dim levels <100% in the Home App
2) Tap scene in the Home App
3) Result is lights go to 100% and the scene in Home illuminates then is greyed out as being non active (lights are still on)
4) Tap scene in Home App again
5) Results in most or all (depends on instance) dimming to the proper levels with the scene now illuminated in the Home App
6) Tapping the scene in the Home App will turn the scene off as expected
Any insights on if this is a known issue or if I have an issue with my setup is appreciated.
Ryan
Sun Oct 03, 2021 12:30 am
durosity offline
Re: HomeKit Scene Requires Two Taps
Do the bulbs support starting at a lower % than 100? As in if in indigo you manually set the slider to 70% when they’re off, would it just go straight to 100 or would it go to 70?
Wed Nov 17, 2021 6:25 pm
ryandenver offline
The bulbs in question will dim to 5% using Insteon keypads/dimmers or the indigo application.
