Using an Indigo variable as STATUS for HomeKit
Tue Mar 27, 2018 8:17 am
Vangelis offline
I am reading the status of my alarm PIRs etc using Cynical Network Plugin - this in turn sets a variable depending on if the sensor is ON or OFF. I would like to represent this activity on the HomeKit UI, but unsure how to do this.. (am using HomeKit Bridge)
I have looked at using maybe a Virtual Device, however I cannot seem to Segway the function in as it seems to want to check if a Group Device is ON or OFF??
Any thoughts on how I can achieve this?
Vangelis
Tue Mar 27, 2018 8:30 am
Colorado4Wheeler offline
Re: Using an Indigo variable as STATUS for HomeKit
You can look at Masquerade or Device Extensions to see if either of those gets you where you need to be. Right now HKB doesn't do anything with variables. This feature is on the roadmap but the priority isn't very high given the other tasks ahead of it. Homebridge Buddy wrappers are also an extremely powerful way to do things like that, once things settle down with HKB I'll resume working on that functionality in Device Extensions but you can use HBB alongside HKB if for nothing more than wrappers.
Tue Mar 27, 2018 8:36 am
Vangelis offline
Will have a looks - Thanks!
Vangelis
Tue Mar 27, 2018 10:18 am
Masquerade won't do what you want, it doesn't deal with variables either.
I think you want to use a Virtual Device. Create a couple of empty Action Groups to be the on/off controls, then set the status to use the variable you want.
I just tested this, and it works fine.
Tue Mar 27, 2018 10:46 am
blysik offline
Yes, I use a Virtual Device, with actions and status variable, and then expose it to HomeKit via HomeKit Bridge. It works great.
Tue Mar 27, 2018 11:24 am
Because once you do that then the virtual device is no different than any other relay type device in Indigo, so HKB doesn't have an issue with it. The key is the status, which people often neglect, they set the on/off actions but neglect the status so HKB can't tell if it is on or off.
Wed Mar 28, 2018 4:12 am
Vangelis offline
Thanks Everyone
@FlyingDriver - I ended up working this out as you stated, once I got my head around what to do with the Virtual Device / Virtual On/Off
Vangelis
