Case Study: TV by Voice
Sun Mar 18, 2018 3:53 pm
Colorado4Wheeler offline
I've been controlling my TV by voice for a while but today I decided to play around with it a bit more and thought it might be nice to share what I did and how I got there. Just about anything I do anymore that requires me to push a button I'm trying to integrate into voice instead.
Ingredients
  • HomeKit Bridge (you could do this on Alexa-Hue Bridge also if you prefer)
  • iTach I/R Wifi Device
  • Cynical Cache (with all my TV remote codes as action groups in Indigo)
  • Device Extensions (this is optional as only my current dev build can do what I'm using it for)
  • Indigo variables
  • Indigo action groups
Serving Size
This will feed a lot of geeks for a good long time.
Cooking Time
Learning IR codes is the longest part and probably takes 15 minutes to get it done, the scripts and testing took me about an hour today. We'll say cooking time is about 1 hour 15 minutes.
Directions
Power
Power can be tricky because my Sharp Aquos TV doesn't feedback, so I never really know if the TV is on or off, so I have to do my best to keep it updated. I got the wife to start asking Alexa (now Siri) a long time ago to turn on the TV so she's pretty used to saying "Hey Siri, turn on the TV". In addition to the action that sends my remote codes to the iTach I tacked on a little script to update a variable that basically says "if the variable is True, the TV is on so another power command turns it off" and vice-versa:
# Update the variable to reflect the current TV state
var = indigo.variables[1877112539] # "tvOn"
varvalue = var.getValue(bool)
if varvalue:
   var.value = "false"
   var.value = "true"
var.replaceOnServer()
Volume
I have a new Device Extensions device that allows me to control my volume by voice just like a lamp. "Hey Siri, set TV to 35%". I won't go into details until Device Extensions releases with this cool new toy. It's not important for this case study anyway, but I wanted to throw this in there to show that there's little that you cannot do with voice commands.
Playing Xbox (Action Group Script)
My wife loves to play Civilization on Xbox when she wants something mindless. She's pretty good at it too! That being said, our old Marantz remote has the macros to turn on the TV, set it to the Xbox input and then she can play. But this puts the TV power outside of my control, I fixed that today.
What I needed to have is a script that would turn on the TV if it was off, wait for a bit for it to be able to change inputs, then send the input change. This required threading my script so I could have unlimited time to get the job done via this script that does that and then also puts into a variable that the TV is in Game Mode, I can use this in other scripts to trigger different actions:
import time
import thread
def runAction():
   tv = indigo.actionGroups[1077979551] # "IR - Sharp Aquos - Power"
   # If the TV is off then turn it on and switch inputs
   if not varvalue:
      indigo.actionGroup.execute(tv.id)
      time.sleep(30)
   indigo.actionGroup.execute(1986130616) # Input
   time.sleep(5) # Give it time
   indigo.actionGroup.execute(1070194149) # Up
   time.sleep(3)
   indigo.actionGroup.execute(1910590700) # Enter
   mode = indigo.variables[594459756] # "tvMode"
   mode.value = "game"
   mode.replaceOnServer()
thread.start_new_thread(runAction, ())
Notice that this works if the TV is on or off (can't confuse the wife with "you must have the TV on, stand on one foot, utter a special chant and...).
Watching TV (Action Group Script)
This works the same as the Xbox script:
import time
import thread
def runAction():
   if not varvalue:
      time.sleep(30)
   indigo.actionGroup.execute(1630437213) # Down
   time.sleep(3)
   mode.value = "tv"
Getting it To HomeKit
This was easy, just add my two action groups to a HomeKit server and the switches were in HomeKit waiting for me.
Voice Control
This is the fun part, getting all this done with voice commands. I simply set up two scenes called "Watch TV" and "Play Xbox" and linked those scenes to turning on the appropriate action group light switches that are in HomeKit. So, no matter if the TV is on or off I can just simply say:
Hey Siri, play Xbox
Hey Siri, watch TV
Dealing With Failure
As we all know, our complicated home automation stuff doesn't always work. In addition to these I have a script and HomeKit scene called "Fix the TV" that will reset my TV variable to false (off) and the tv mode to "TV", so the worst case is that I have to manually adjust the input of the TV and turn it off manually to match Indigo and then everything is right again. I've never had to do that with turning the TV on or off and don't anticipate having to use it for these new actions either. About the only time I would need this is if someone uses the remote control to do everything instead of voice or if there was a power outage that turned off my TV. Even if the wife forgets then it's not a big deal because my "bedtime" script that runs each night will reset the TV power to off anyway, so it's always going to be good the next day.
And, yes, you could easily do the same thing with Alexa too using this same basic case study ;).
Tue Mar 27, 2018 12:33 pm
new2me07 offline
Re: Case Study: TV by Voice
On TVs that don't remember their state when mains in disconnected I use the power monitoring properties of applicable devices to determine their real state. Ive used this method on my washing machine as well to get a notification that its done.
I'm so torn between TV set ups. Apple TV is great and pretty much what we solely use for the past year but I miss my PIP automatic camera call up I hacked together on WMC and robust network control. I feel like its the final frontier in terms of automation. You'd think apple would create a TV device for apple TVs and use HDMI CEC control to get volume and power control for the device into HomeKit. I hear they are hiring I know at least 100 people who would give you an awesome reference. Thanks for all the great work.
Tue Mar 27, 2018 1:07 pm
I do that if I can but most of my TV's don't report anything. I could easily throw on some of the Dome outlet devices to see what the power draw is (and now that I think of it I like that idea for $30) but so far it works pretty well. Some of my TV's stop pinging when they go offline, that has made it pretty easy, others I just have to hope it's in alignment but know that it'll reset at midnight anyway.
I would expect that will be in a future update as Apple TV becomes more critical - as it will since Apple is producing their own movies and TV shows they will want to make the ATV a pretty core piece of equipment IMO. That being said, have you investigated if your TV itself does PIP? Mine do and I used to have my Roku or even another ATV on a different input so I could do just that - but since my HomeKit shows me my cameras as well as my SecuritySpy apps on all my iOS devices I found I didn't need it anymore and stopped doing it.
I'm hoping to develop HKB to the point of doing photo/video notifications that I know are possible but just out of reach at the current stage of the plugins development.
I bet that's coming too. Heck, I'm just happy it's on the ATV so I have one tiny remote for everything.
Tue Mar 27, 2018 3:41 pm
RogueProeliator offline
Yours didn't have an Ethernet interface on it for IP control?
Tue Mar 27, 2018 4:03 pm
It's connected to Ethernet but I've not really looked into controlling it via IP. I looked at an API a while ago but it looked like more work than it was worth, perhaps that has changed.
Tue Mar 27, 2018 11:33 pm
I don't think I ever published to the Plugin Store but it's been around quite a while:
http://forums.indigodomo.com/viewtopic.php?f=64&t=10981
Not sure of your model, but it controls nearly all of Aquos that have been tried... and it does have most of the states including power (and can control power). You may have yours setup enough you don't want to bother, but might give you an option to read power even if you left your existing control in place.
Adam
Wed Mar 28, 2018 8:29 am
OOOOOOOOOOOOH! Thanks Adam!
Wed Mar 28, 2018 2:15 pm
Sadly, that plugin doesn't seem to like my TV :(
Wed Mar 28, 2018 8:39 pm
What model do you have? Most of the Aquos use the same protocol but there may be a few which do not conform...
Adam
Wed Mar 28, 2018 8:54 pm
The U1101191
Tue Apr 03, 2018 9:56 pm
The U1101191
According to the docs, that unit should be controllable by the plugin... up to you if you want us to investigate or just let it go for now.
Wed Apr 04, 2018 8:22 am
I would be open to investigating it, I think it would only serve to enhance my automation. What can I do to be helpful in this regard?
Thu Apr 05, 2018 2:00 am
Ramias offline
I can’t wake my Samsung over Ethernet but I wake it via hdmi cec on the receiver.
The Samsung does not respond to ping when off so I use fingscan to set a variable when it is on and long it every few seconds to confirm state.
So now I can turn on via network with the receiver (thus voice commands etc) or if I turn tv on via remote, Indigo finds out and turns the receiver on.
Thu Apr 05, 2018 10:27 am
Are you using a username/password on the TV? The API for control is pretty defined, but there is no official login - the plugin has to wait for a login prompt telnet-style. This is the most likely point of failure/something having changed. If you would, turn on high debug for the plugin and restart it so we can capture the connection attempt. Warning, this may put your username/password in plain text if you copy it in here, so be sure to blank that out.
Adam
Thu Apr 05, 2018 10:28 am
I didn't add a user/pass because I don't think my TV asked me to ever provide one, if it did then I don't remember what I would have put there.
