jrickmd wrote:did the conversion from HBB and had some actions come over that I had not had in HBB. Didn't recognize any patterns to why it might have happened. Easy enough to fix with the delete option.
Given the nature of how that HBB migration works, I think that you may have just been unaware of them. The migration not only looks at the server and anything that was added directly there, but also if you used any Wrappers or Aliases too. I just looked at the code and the loop doesn't wander past those two points so I bet it's something that was hanging out there that you forgot about.
jrickmd wrote:my temperature sensors / thermostats were showing weird temps in home. Around 160s as current temp with a range of 71-95 as the heat / cool settings
That's a Fahrenheit-Celsius conversion issue that I didn't really handle in the migration. I'll see if I can do something about that, but the way HKB handles the conversion is a bit different than how HBB handled it and that got lost in translation apparently. The fix for this is to first make sure the server options are set to the measurement of your choice, but then you also need to edit each temperature sensing device on the list and make sure the checkbox for converting from Fahrenheit is checked or not depending on your preference.
jrickmd wrote:I never realized how much I missed HomeKit until I got a HomePod and HBB. HKB makes it even BETTER!
Glad you are getting use from it! Once HomePod dropped and I could "Hey Siri" through my house again without the slowness of my watch or carrying my phone I knew it was time to rewrite HBB to be better .
