Colorado4Wheeler wrote:Monstergerm wrote:1) While arming, during the exit delay period, the HKB plugin times out. The device tile eventually refreshes with the correct alarm state in the Home app
GRWilde wrote:It works so well that I deinstalled my Rasberry Pi Homebridge.
durosity wrote:Colorado4Wheeler wrote:Monstergerm wrote:1) While arming, during the exit delay period, the HKB plugin times out. The device tile eventually refreshes with the correct alarm state in the Home app
I've not noticed this myself and i'm using the DSC plugin via a IT-100 but i doubt that'd make a difference. I'll see if i can replicate it when i get home. I have, however, noticed that DSC motion sensors don't seem to trigger when motion is detected. I'll post it as an issue on github when i get home with a dump of the simulation data.
durosity wrote:I'm curious as to what your plans are for the security camera option in HBK.
durosity wrote:In my tiny little mind i'd love to see it be able to read devices from the Security Camera and CynicalSecuritySpy plugins
GRWilde wrote:The installation and setup was quick and smooth, and the resulting server so far works flawlessly. It works so well that I deinstalled my Rasberry Pi Homebridge.
durosity wrote:I've not noticed this myself and i'm using the DSC plugin via a IT-100 but i doubt that'd make a difference. I'll see if i can replicate it when i get home. I have, however, noticed that DSC motion sensors don't seem to trigger when motion is detected. I'll post it as an issue on github when i get home with a dump of the simulation data.
Monstergerm wrote:I/O Linc error
I am controlling drapes with two I/O Lincs, both setup in momentary mode. One triggers the closing, the other triggers the opening. There is no feedback with this installation for whether drapes are closed or open.
First, do I have to select the garage door option? I don't really like to have the garage door icon in my Home app for drapes. I do not see any appropriate device for momentary relay activation.
Second, the log sends out an error after a while:
HomeKit Bridge Error Maximum time exceeded while setting the 'TargetDoorState' HomeKit characteristic for 'Drapes Master Bedroom CLOSE' (HomeKit device 'Drapes Master Bedroom CLOSE'), aborting attempt. This can happen if you try to set a device to a state is is already in (i.e., turning off a device that is already off).
Monstergerm wrote:I got DSC motion sensors, door and window contacts to work BUT only if you select the "Switch" device in HKB. Selecting Sensor, Door, Window does not work.
mortenkols wrote:Trying to add devices with Ø in the name, then i get this error and the device does not show up in home app on iphone.
Colorado4Wheeler wrote:Monstergerm wrote:Monstergerm wrote:I got DSC motion sensors, door and window contacts to work BUT only if you select the "Switch" device in HKB. Selecting Sensor, Door, Window does not work.
If you go to the HomeKit device references on the HKB wiki and do a search for 'dscAlarm', you'll see the exact places where a DSC is supported, there are a handful. This is one plugin that I'm hard coding into HKB so so long as I have the precise definition for what state or attribute to look at for each characteristic then it can be made to work within a single release quite easily.
16 Mar 2018 at 18:40:19
Error device "new device" state key onOffState not defined
HomeKit Bridge Error Exception in homekit.getStashRecordForObject line 877: 'key includedDevices not found in dict'
CODE: includedDevices = json.loads(serverProps["includedDevices"])
HomeKit Bridge Server 'new device' has changed ports or users, validating config
HomeKit Bridge Attempting to start 'new device'
16 Mar 2018 at 19:01:19
HomeKit Bridge Debug Plugin device 'new device' configuration field changed
HomeKit Bridge Debug Downstairs hall light started as a HomeKit Lightbulb
jmdraper wrote:In case it helps, I deleted the server device, turned on Debug logging in the plugin settings, then created a new server device and added first device to it exactly as per quick start guide. The logs show:
