srkinard wrote:A question...I didn't see in the current stuff or threads where RGB and RGBW devices are in there.
The only RGBW device currently supported is the Hue because of how each device uses completely different values for HSB. That will change but that's what we have for now.
spiv wrote:FYI, I also saw this problem with the previous version and had to delete my entire configuration and start over to get it working. I upgraded to the newest beta to see if something on my end by it is still happening. (I have not yet nuked the configuration and tried to start over.)
To have it once is pretty odd, it's not a bug because we aren't getting reports about the issue. To have it twice is extremely suspicious. Nothing changed in the last two releases that would impact the config folder in any way, so that makes me wonder if there is an OS issue of some kind. HKB is one of the few plugins that actively writes to your hard drive when you start your servers (not after that though). Blowing away those folders won't harm anything at all, they are made to be dynamically rebuilt and the plugin does not rely on them to run, only for Homebridge to work.
The one thing that would be different about HKB versus just about any other plugin is that the preference folder has some symbolic links, but that shouldn't make any difference. And for it to work and then break is highly suspicious since the only file, once the folder is created initially, that ever changes there is the config.json file that rebuilds each time the server starts.
What is the error you get? Just that it won't start and that you should try rebuilding? If you are getting startup errors then please post an issue on Git with your HB config and HB logs (both in the advanced plugin actions menu option).
