Need Data Please: Security Devices
Sun Feb 11, 2018 12:37 pm
Colorado4Wheeler offline
If you are using something other than a door lock that the built-in Indigo Zwave plugin supported locks and any garage doors (I have a separate request for that) for your house security would you mind posting the output of this script here so I can see how other devices work? You can audit as much of the information as you want, I don't want any kind of users/passwords but rather the configuration of the device for auto detection.
I am not looking for things you use for security as much as I'm looking for devices that would be considered security devices such as locks, automatic windows, automatic doors, etc. If you are using a lamp for security it's not really a security device globally, only a part of your security. I don't consider motion sensors a part of security either because there are so many other users for them, I really want things that are pure security items.
While this is for HomeKit integration you don't need to be a HomeKit or plugin user, I just need data. If you are curious about how I'm using this data it's so that when the HomeKit server automatically manages all of your devices (this is really cool by the way, can't wait to showcase it) that you have the option to have your security devices hosted on a separate server so that you can toggle that server on and off to strengthen security.
indigo.server.log(unicode(indigo.devices[DEVICE_ID]))
Tue Feb 13, 2018 4:34 am
Coolcaper offline
Re: Need Data Please: Security Devices
Don't know if this is the kind of device you were looking for but it's for a DHS RFID Keypad which acts as a wall mounted alarm keypad for me.
This is the product: https://www.digitalhomesystems.com.au/d ... n%20v1.pdf
As of now it hasn't been incorporated fully into indigo but matt has promised it for 7.1.2 :wink:
   Interactive Shell               address : 52
batteryLevel : 5
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwLockType
displayStateId : onOffState
displayStateImageSel : Unlocked
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 75738408
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          IsLockSubType : true (bool)
          SupportsBatteryLevel : true (bool)
          address : 52 (integer)
          indigoObjVersion : 6 (integer)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 60 (integer)
          version : 0.28 (string)
          zwAppVersMajor : 0 (integer)
          zwAppVersMinor : 28 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
          zwAssociationsMapStr : 1:[1] (string)
          zwClassCmdBase : 0 (integer)
          zwClassCmdMap : (dict)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c37 : 1 (integer)
               c99 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 63v1 84v1 85v1 86v1 70v1 71v1 72v1 25v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 64 (integer)
               Item : 0 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Entry Control (string)
          zwConfigVals : (dict)
          zwConfigValsStr : - none - (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Not Supported (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, battery, beaming, waking (string)
          zwLibType : 3 (integer)
          zwManufactureId : 151 (integer)
          zwManufactureName : Digital Home Systems (string)
          zwModelDefnVers : 0 (integer)
          zwModelId : 1630622977 (integer)
          zwModelName : Entry Control (string)
          zwNodeNeighbors : (list)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 8 (integer)
               Item : 28 (integer)
               Item : 32 (integer)
               Item : 45 (integer)
          zwNodeNeighborsStr : 3, 4, 5, 8, 28, 32, 45 (string)
          zwProtoVersMajor : 2 (integer)
          zwProtoVersMinor : 97 (integer)
          zwShowDumpDevToLog : false (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : true (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : true (bool)
          zwShowWakeIntervalUI : true (bool)
          zwWakeInterval : 60 (integer)
lastChanged : 2018-02-13 17:26:23
lastSuccessfulComm : 2018-02-13 17:26:23
ledStates : []
model : Entry Control
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c37 : 1 (integer)
          c99 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 64 (integer)
          Item : 0 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 8 (integer)
          Item : 28 (integer)
          Item : 32 (integer)
          Item : 45 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
     batteryLevel : 5 (integer)
     batteryLevel.ui : 5% (string)
     lastChangedVia :  (string)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : 0.28
Tue Feb 13, 2018 8:17 am
I"m not sure where it might fit into a HomeKit universe but thank you, it does help to see how they are laid out. It'll help immensely if there is a device in HomeKit that works well with this so I can automatically map it. Thank you :).
Tue Feb 13, 2018 8:54 am
Coolcaper offline
No worries. Glad to help.
Tue Feb 13, 2018 8:59 am
In looking at this data, that appears to be a lock, but you say it's a Keypad? Oh and your battery is about to die :shock: :D .
Wed Feb 14, 2018 12:10 am
Coolcaper offline
Colorado4Wheeler wrote:
In looking at this data, that appears to be a lock, but you say it's a Keypad? Oh and your battery is about to die .
Yes, it syncs with indigo but apparently there’s no real definition I guess. It’s a zwave RFID keypad. Matt has said he’d add it in 7.1.2. So I guess it’s not showing properties correctly?
The battery info is wrong lol. It’s been like that since day one.
viewtopic.php?f=58&t=19651&p=150043&hilit=DHS+rfid#p150043
Wed Feb 14, 2018 10:58 pm
Shavano offline
Here is the output of my front door lock. Please let me know if I'm leaking any important data. Right now, I can only get it to lock and unlock from Indigo and it shows the correct state. But if manually or using the keypad to lock or unlock, the state, time, or the user ID doesn't update in Indigo.
   Embedded script executor host started
   Script                          address : 8
batteryLevel : 96
configured : True
description : Schlage BE469 front door lock
displayStateImageSel : Locked
displayStateValRaw : True
displayStateValUi : locked
enabled : True
errorState :
folderId : 0
          IsSchlageLock : true (bool)
          address : 8 (integer)
          modelNameAndFirmware : Door Lock (BE369/468/469), firmware 113.22 (string)
          propsPushTickler : 2 (string)
          tempAlwaysFalse : false (bool)
          version : 113.22 (string)
          zwAppVersMajor : 113 (integer)
          zwAppVersMinor : 22 (integer)
          zwAssociationsMapStr : - none - (string)
          zwClassCmdBase : 98 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c152 : 1 (integer)
               c32 : 1 (integer)
               c34 : 1 (integer)
               c93 : 1 (integer)
               c98 : 1 (integer)
               c99 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 62v1 63v1 85v1 86v1 22v1 70v1 71v1 72v1 98v1 7Av1 5Dv1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 64 (integer)
               Item : 3 (integer)
          zwClassName : Keypad Door Lock (string)
               c112 : true (bool)
               c113 : true (bool)
               c128 : true (bool)
               c133 : true (bool)
               c32 : true (bool)
               c93 : true (bool)
               c98 : true (bool)
               c99 : true (bool)
          zwEncryptClassCmdMapStr : 20 80 62 63 85 70 71 5D (string)
          zwEncryptionStatusStr : Enabled for Commands 20 80 62 63 85 70 71 5D (string)
          zwFeatureListStr : routing, battery, beaming, security, frequentWaking (string)
          zwLibType : 6 (integer)
          zwManufactureId : 59 (integer)
          zwManufactureName : Schlage (string)
          zwModelId : 1665224772 (integer)
          zwModelName : Door Lock (BE369/468/469) (string)
               Item : 12 (integer)
               Item : 14 (integer)
               Item : 17 (integer)
          zwNodeNeighborsStr : 12, 14, 17 (string)
          zwProtoVersMajor : 3 (integer)
          zwProtoVersMinor : 42 (integer)
          zwShowDumpDevToLog : true (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
lastChanged : 2018-02-13 16:09:23
lastSuccessfulComm : 2018-02-13 16:09:23
ledStates : []
model : Door Lock (BE369/468/469)
name : Front Door Lock
onState : True
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c152 : 1 (integer)
          c32 : 1 (integer)
          c34 : 1 (integer)
          c93 : 1 (integer)
          c98 : 1 (integer)
          c99 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 64 (integer)
          Item : 3 (integer)
          c112 : true (bool)
          c113 : true (bool)
          c128 : true (bool)
          c133 : true (bool)
          c32 : true (bool)
          c93 : true (bool)
          c98 : true (bool)
          c99 : true (bool)
          Item : 12 (integer)
          Item : 14 (integer)
          Item : 17 (integer)
protocol : ZWave
     batteryLevel : 96 (integer)
     batteryLevel.ui : 96% (string)
     onOffState : on (on/off bool)
     onOffState.ui : locked (string)
subModel :
version : 113.22
[MODERATOR NOTE: PUT DATA DUMP INTO CODE BLOCK FOR READABILITY]
Sat Feb 17, 2018 10:12 am
BeNoOne offline
Fwiw the output of my custom plugin for a Nuki lock.
Hope this helps to make your plugin better.
   Script                          address : 12345678
batteryLevel : None
configured : True
description :
deviceTypeId : myLockType
enabled : True
errorState :
folderId : 791041526
     nl.fuzzy-bizz.indigoplugin.riinuki : (dict)
          address : 12345678 (string)
          lockId : 12345678 (string)
lastChanged : 2018-02-17 17:02:38
lastSuccessfulComm : 2018-02-17 17:02:38
ledStates : []
model : Nuki Lock
name : Nuki (Lock) - Achterdeur
onState : True
ownerProps : nl.fuzzy-bizz.indigoplugin.riinuki : (dict)
pluginId : nl.fuzzy-bizz.indigoplugin.riinuki
protocol : Plugin
     batteryCritical : false (bool)
     lockState : 1 (integer)
     lockStateName : locked (string)
subModel :
version : None
Grt,
B
Sat Feb 17, 2018 10:51 am
Thank you! The Zwave locks are working but I didn't even know this was out there.
Fri Mar 16, 2018 11:32 am
Monstergerm offline
This is the output of the DSC plugin of an alarm keypad device, connected via Envisalink4 to a DSC alarm system. I can also send outputs for zones if interested.
batteryLevel : None
configured : True
description : partition 3
deviceTypeId : alarmKeypad
displayStateId : state
displayStateImageSel : SensorTripped
displayStateValRaw : armed
displayStateValUi : armed
enabled : True
errorState :
folderId : 1624294118
com.frightideas.indigoplugin.dscAlarm : (dict)
partitionName : Casita (string)
partitionNumber : 3 (string)
lastChanged : 2018-03-16 10:25:00
lastSuccessfulComm : 2018-03-16 10:25:00
model : Alarm Keypad
name : DSC Alarm Keypad Casita
ownerProps : com.frightideas.indigoplugin.dscAlarm : (dict)
pluginId : com.frightideas.indigoplugin.dscAlarm
protocol : Plugin
ArmedState : away (string)
ArmedState.away : true (bool)
ArmedState.disarmed : false (bool)
ArmedState.stay : false (bool)
KeypadChime : disabled (string)
KeypadChime.disabled : true (bool)
KeypadChime.enabled : false (bool)
LCDLine1 : Date Time (string)
LCDLine2 : MAR 16/18 10:24a (string)
LEDArmed : on (string)
LEDBypass : off (string)
LEDMemory : off (string)
LEDReady : off (string)
LEDTrouble : off (string)
PanicState : none (string)
PanicState.ambulance : false (bool)
PanicState.duress : false (bool)
PanicState.fire : false (bool)
PanicState.none : true (bool)
PanicState.panic : false (bool)
ReadyState : notready (string)
ReadyState.notready : true (bool)
ReadyState.ready : false (bool)
state : armed (string)
state.armed : true (bool)
state.disarmed : false (bool)
state.entryDelay : false (bool)
state.exitDelay : false (bool)
state.tripped : false (bool)
subModel :
supportsStatusRequest : False
version : None
