HomeKit Bridge Closed Beta Discussion
Mon Feb 19, 2018 10:39 pm
Coolcaper offline
Re: HomeKit Bridge Closed Beta Discussion
Colorado4Wheeler wrote:
And here is Beta 10 (click here to download) that should fix the timeout issues, there could be some lingering as a result of the device not yet being fully supported but so far my tests everything works. Oh and this will come up as 0.9.9 even though it's beta 10 because, reasons. :lol: :shock:
Yup delays are gone.
Mon Feb 19, 2018 10:47 pm
Coolcaper offline
Have issues with contact and motion sensors not updating at all or being stuck open or closed all the time. They work fine in indigo but not the home app. I've listed them here: viewtopic.php?f=201&t=20199&p=155019#p155019
My garage door opener shows up inverted when I add it but I've changed the state using the Invert option.
Tue Feb 20, 2018 8:29 am
Colorado4Wheeler offline
I'll do some testing, they should be sending a status update to HomeKit when they change in Indigo but I'll see if maybe that's not happening.
Glad everything else settled down.
Tue Feb 20, 2018 8:40 am
Yea, the read-only devices, like sensors, weren't getting an instant update, the next beta will fix that. They would update eventually because HomeKit polls regularly, but it wasn't doing it in realtime unless it was part of a read/write system.
Tue Feb 20, 2018 11:13 am
What garage door opener are you using? myQ?
Tue Feb 20, 2018 6:43 pm
Coolcaper offline
An Aeotec Garage Door Controller ZW062
Tue Feb 20, 2018 6:44 pm
Big Update!
Ok, this is a pretty big update. Beta 11 is now up for downloading (click this link) and it's kind of the last big nail in the coffin for Homebridge Buddy as it rounds out the last few device types that HBB supported that HKB had not yet implemented plus it has a full migration from HBB to HKB! It will fully and automatically pull in Homebridge-Indigo and Homebridge-Buddy server configurations and create new HKB servers.
This was a marathon coding chore, I'm here to tell you.
Aside from one last big chore of fixing the new install server not starting issue, this is almost ready to bring in the last beta testers for a week or two of final closed beta before I open it up to the masses for public beta.
Tue Feb 20, 2018 8:08 pm
Coolcaper offline
On V0.11.0
Most of my contact sensors now update when changed to occupancy sensor even though some are just pure contact sensors. Don't know if there's a way to check what exactly they are, No issues as long as it works lol
Tue Feb 20, 2018 8:12 pm
Coolcaper offline
I get this in the log when I try the Automatic Server Wizard:
HomeKit Bridge Error            Exception in plugin.wizardServerBuilder line 2135: 'key not found in database'
                      CODE: if valuesDict["wizard"] == "folderdevices":listName = indigo.devices.folders[dev.folderId].name + " Devices"
   HomeKit Bridge Error            Exception in plugin.wizardListMethodDeviceTypes line 2223: object of type 'NoneType' has no len()
                      CODE: if len(typeDict) == 0: return ret
Tue Feb 20, 2018 8:21 pm
chobo offline
>> @Coolcaper & Colorado4Wheeler, Was just logging in to post the same report for v0.11.0.
Tue Feb 20, 2018 8:30 pm
The server wizard is not ready, I just forgot to exclude it from the build. The HBB migration is under the advanced menu option, not the wizard.
Tue Feb 20, 2018 9:00 pm
ZachBenz offline
Big Update!
Thanks for everything you're putting into this!!!
Installed Beta 11, and tried out the Window Covering device type without luck. I have Z-Wave Bali shades (which come up as a Z-Wave model type of "Motor Control Class C" in Indigo). Looks like the way Z-Wave devices are defined may not make for easy mapping. (It does work fine if I accept the default mapping to Lightbulb - that is, I can 'dim' the shade to set how open it is). Here's a device info dump in case its useful:
batteryLevel : 100
blueLevel : None
brightness : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : zwDimmerType
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 878776678
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          SupportsBatteryLevel : true (bool)
          address : 27 (integer)
          indigoObjVersion : 6 (integer)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 60 (integer)
          version : 11.01 (string)
          zwAppVersMajor : 11 (integer)
          zwAppVersMinor : 1 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
          zwAssociationsMapStr : 1:[1] (string)
          zwClassCmdBase : 38 (integer)
          zwClassCmdMap : (dict)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c37 : 1 (integer)
               c38 : 4 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c94 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 25v1 26v4 72v1 73v1 5Ev1 59v1 7Av1 5Av1 86v1 85v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 17 (integer)
               Item : 7 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Motor Control Class C (string)
          zwConfigVals : (dict)
          zwConfigValsStr : - none - (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Not Supported (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, battery, beaming, frequentWaking (string)
          zwLibType : 3 (integer)
          zwManufactureId : 622 (integer)
          zwManufactureName : Unknown (string)
          zwModelDefnVers : 0 (integer)
          zwModelId : 1129536049 (integer)
          zwModelName : Motor Control Class C (string)
          zwNodeNeighbors : (list)
          zwNodeNeighborsStr : - none - (string)
          zwProtoVersMajor : 4 (integer)
          zwProtoVersMinor : 33 (integer)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : true (bool)
          zwShowPollingUI : true (bool)
          zwShowSubmitModelInfoUI : true (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
greenLevel : None
lastChanged : 2018-02-20 17:23:53
lastSuccessfulComm : 2018-02-20 17:23:53
ledStates : []
model : Motor Control Class C
name : Back Door Shade
onBrightensToDefaultToggle : False
onBrightensToLast : True
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c37 : 1 (integer)
          c38 : 4 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c94 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 17 (integer)
          Item : 7 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
redLevel : None
remoteDisplay : True
states : States : (dict)
     batteryLevel : 100 (integer)
     batteryLevel.ui : 100% (string)
     brightnessLevel : 0 (integer)
subModel :
supportsAllOff : False
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : 11.01
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
ZachBenz's Plugins: RingForIndigo
Tue Feb 20, 2018 9:19 pm
Looks like a bug popped up in the build, mine stopped working also.
Tue Feb 20, 2018 11:36 pm
Coolcaper offline
I am having issues here trying to edit the migrated Homebridge devices. I have an 'Occupancy' sensor which is autodetected as a 'motion' sensor. After editing it in the migrated HomeKit Bridge server and then selecting 'Add to Homekit' I get 'is not a valid device id. Please verify your selection'. After clicking OK, the device is not present anymore either in the Device list or the Homekit list.
Tue Feb 20, 2018 11:44 pm
Looks like the device doesn’t populate, try selecting it again in the drop down.
Page 11 of 26 1 ... 8, 9, 10, 11, 12, 13, 14 ... 26
Users browsing this forum: No registered users and 18 guests
