JustJack wrote:I just added an Insteon wireless door sensor (triggerlinc) I expected that the device type would have been autodetected as a Contact device but it came up as a motion sensor.
Can you please post a data dump of that device so I can set up the auto config? Motion sensor is the fall back in case it cannot determine it is something else.
- Code: Select all
indigo.server.log (unicode(indigo.device[DEVICEID]))
JustJack wrote:I was not sure if I should have also selected invert state as I thought that the release notes said that this device type was one of the first to report state inverted
If ON = the sensor is engaged and, thus, closed then yes it should have. Can you post the above dump in both the closed and open states so I can make sure the logic is right? I don't have this so I can only go off what I think it will be. I know Different's contact sensors are spot on, so it's unique to your device type.
