Coolcaper wrote:ok, it was because 'Only show objects that are not being sent to homekit' was ticked. Once unticked, I could add again.
EddieJ wrote:I recall reading through the discussion leading up to the release of the beta that you were considering adding IP camera and Sonos ZP device capabilities. Are those still on the roadmap?
ZachBenz wrote:Installed Beta 11, and tried out the Window Covering device type without luck.
Colorado4Wheeler wrote:Not specifically on the roadmap of development only because the support for those kinds of things via other Homebridge plugins are in the form of mapping HomeKit devices to functions. For instance, the WUnderground plugin for Homebridge simply adds a humidity sensor and thermostat sensor to HomeKit with data from WUnderground, easy enough for us to do the same thing with our Indigo data. The iTunes plugin is a series of on/off switches that do things like skip tracks or change volume, again something we can map to Indigo devices to achieve the same thing.
That all being said I am building "complications" that sort of fill the steps out for you. It would detect that you selected, say, a Sonos device and give you the option of adding multiple HomeKit items to control that device that are pre-mapped for the purpose.
I cannot create a special "Sonos Device" in HomeKit because if HK doesn't already have the icons and controls to make that happen then I can't make it do what it won't do on its own.
Make sense?
Contact Sensor:
Works as planned with my contact sensors
Door:
I don't have an automated door so I used a lightbulb as my door and it seems to work right
Fan Version 2:
Works but I have to invert the On/Off to make it work - I'm using an Insteon FanLinc
Action Group (as a switch)
Battery Service (Unsupported)
Contact Sensor
Door
Fan Version 2
Garage Door Opener
Humidity Sensor
Leak Sensor
Light Sensor
Lightbulb
Lock Mechanism
Microphone (Unsupported)
Motion Sensor
Occupancy Sensor
Outlet
Smoke Sensor
Speaker (Unsupported)
Switch
Temperature Sensor
Thermostat
Window
Window Covering
Colorado4Wheeler wrote:Read a couple messages back. Uncheck the box.
ZachBenz wrote:Colorado4Wheeler wrote:Read a couple messages back. Uncheck the box.
Ah, missed that, thanks.
Note, though, that it doesn't appear back in the drop down list even after I use the Delete action unless I subsequently save, then reopen the settings. But perhaps this is simply a limitation of how Indigo populates the drop down menus?
Works as expected
(Unsupported by HomeKit currently, can't test)
Contact Sensor
Doesn't work - I tried adding a DSC Alarm sensor (indigo.Device.com.frightideas.indigoplugin.dscAlarm.alarmZone), but it doesn't have a standard 'on' state. For kicks I tried adding "indigo.Device.com.frightideas.indigoplugin.dscAlarm.alarmZone": "state_state.open" to the requiredv2 map in service_ContactSensor, but that didn't work - I'm guessing its because characteristic_ContactSensorState expects a 0/1 value, not true/false. Anyway, here's the relevant state information dump from this Indigo device type:
states : States : (dict)
LastChangedShort : 3m (string)
LastChangedTimer : 3 (integer)
bypass : nobypass (string)
bypass.bypassed : false (bool)
bypass.nobypass : true (bool)
state : closed (string)
state.closed : true (bool)
state.open : false (bool)
state.tripped : false (bool)
Door
I don't have any devices of this type
Fan Version 2
Doesn't function when trying with SenseMe Fan plugin devices (indigo.Device.com.pennypacker.indigoplugin.senseme.SenseME_fan). Relevant state info dump:
brightness : 0 (integer)
fan : off (on/off bool)
fan_motion : ON (string)
light : off (on/off bool)
light_motion : off (on/off bool)
motion : on (on/off bool)
smartmode : OFF (string)
speed : 0 (integer)
statusString : off / on (string)
whoosh : off (on/off bool)
Garage Door Opener
Works as expected
Humidity Sensor
Don't have one to test
Leak Sensor
Works as expected
Light Sensor
Lightbulb
Works as expected
Lock Mechanism
Motion Sensor
For me this is the same as Contact Sensor above, as it is the same device type in Indigo (a DSC Alarm Plugin Alarm Zone device)
Occupancy Sensor
Outlet
Smoke Sensor
Same story as Contact Sensor and Motion Sensor
Switch
Works as expected.
Temperature Sensor
Thermostat
Wonky. NEST Thermostat,
Window:
(don't have any devices of this type)
Window Covering:
Works as planned with my Z-Wave shades
Doesn't work (and didn't expect it to) with a Virtual Group of shades (com.perceptiveautomation.indigoplugin.devicecollection) - makes sense, since a Virtual Group doesn't have a brightness attribute, just a boolean onState; and, of course, a future Many-to-One complication would handle this just dandy
