Colorado4Wheeler wrote:but are the devices working in HomeKit?.
The server won't start (for reasons I can't tell, because I can't access the service logs remotely) so I don't know yet.
FlyingDiver wrote:MyQ here. I guess that one's kind obvious.
"description": "HomeKit configuration generated by HomeKit Bridge on 2018-02-13 13:13:00.979000 for device Testing"
2018-02-13 13:13:00.980 THREADDEBUG Plugin shellHBStartServer Running: "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS HomeKit Bridge.indigoPlugin/Contents/Server Plugin/bin/hb/homebridge/load" "/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.eps.indigoplugin.homekit-bridge/575372563"
2018-02-13 13:13:01.050 INFO Plugin shellHBStartServer Attempting to start 'Testing'
2018-02-13 13:13:13.555 DEBUG Plugin onAfter_runConcurrentThread Checking running state of all servers
2018-02-13 13:13:43.696 DEBUG Plugin onAfter_runConcurrentThread Checking running state of all servers
2018-02-13 13:14:01.218 ERROR Plugin shellHBStartServer HomeKit server 'Testing' could not be started, please check the service logs for more information, now issuing a forced shutdown of the service to be safe.
2018-02-13 13:14:01.218 THREADDEBUG Plugin shellHBStopServer Running: "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS HomeKit Bridge.indigoPlugin/Contents/Server Plugin/bin/hb/homebridge/unload" "/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.eps.indigoplugin.homekit-bridge/575372563"
2018-02-13 13:14:01.261 INFO Plugin shellHBStopServer Attempting to stop 'Testing'
HomeKit Bridge Error Server 'Testing' device 'Dining Room and Office Speakers' is trying to reference a HomeKit class of service_Dummy that isn't defined.
HomeKit Bridge Error Exception in plugin.onAfter_nonpluginDeviceUpdated line 339: 'Device' object has no attribute 'coolSetpoint'
CODE: o = getattr(origDev, w)
autolog wrote:Just installed B6.
Getting this error (a lot of):HomeKit Bridge Error Exception in plugin.onAfter_nonpluginDeviceUpdated line 339: 'Device' object has no attribute 'coolSetpoint'
No clue as to what device
autolog wrote:I have Nest Protects only - I don't have any Nest thermostats.
I do have Popp and Spirit thermostats that don't have cooling as the are Thermostatic Radiator Valve controllers.
Different Computers wrote:B 6 sure starts up fast.
